tirerob's MBP WagonX build up ball of thread. - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 73
This is a discussion on tirerob's MBP WagonX build up ball of thread. within the Builds forums, part of the Tech & Modifying & General Repairs category; The pulleys, I heard from a Subaru master tech, wear out before the belt lol. Either way they're not commonly ...
  1. #31
    Jul 2012
    Rocky Top
    The pulleys, I heard from a Subaru master tech, wear out before the belt lol. Either way they're not commonly replaced and its actually dangerous if you don't replace those along with the belt for the reasons already mentioned.
  3. #32
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    Rob, I dig your mods.
    You might want to see about getting your tune on, if you haven't already. You can make alright/nice gains with what you've got on there.
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
  4. #33
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    Quote Originally Posted by pete25r View Post
    thanks man! for happy hour today we have on order a tatrix cable and a uego. TUNES COMING BABY!! well, baby steps and we really have to figure out whats wrong/messed with/ tuned with kTwn's wagon. id say his boost gauge is busted but his car pulls alot harder than mine and i hit target stock boost levels, well like a stock car. 14psi. kTwn?peaks at 18-19 and comes in at 35-3700 like a rifle. bang, speeding.
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
  5. #34
    Nov 2012
    Quote Originally Posted by Monk_Knight View Post
    This thread is sweet! Bringing this car back to life!
    I had the same thing happen, but at 70mph. Previous owners replaced the belt but not the pulleys. Luckily the pulley didn't break, just seized briefly and then unseized. Tore a good hole in the belt but not enough to make it snap. I was told that not only is it not terribly common to replace them, but that a lot of mechanics don't even mention or recommend it because it drives up the overall cost of the timing belt change and the pulleys are good to 150k or so vs 100k for the belt.
    AAGH!! gods ya i must have been right there too. the squeeking i was hearing had to have been that pulley begging to me replaced. when the bearing let go the belt slapped the upper guides and dug that grove. all three(belt, pulley, and guides) managed to stay operating till i crawled into the garage. so close to mashing a piston. whew
    Rob
  6. #35
    Nov 2012
    well heck whats next. man i just want to throw in the stuff i just did but better keep it straight or ill get all confuzzed.
    oh heck ya! suspension! at this point i was running clean and strong and fighting the snow was getting to be one sided. lots of fixes fixored and a few mods thrown in for good luck and happy driving. about this time i start reading the alignment threads and think, hey, i have access to a alignment rack. bout time i put all that old schooling to use!
    well, not quite. our machine in school definitely did not have laser beams. it had string. not kidding.
    so what the heck, i grab the alignment tech and tell him what i want to do. custom alignment numbers. he looks at them and nods his ok. says, "good numbers for your car." for him, roughly equivilant to a hour long lecture at a college. he doesnt say much, but we listen when he does!
    first up, suprise! locally available upgrade parts!
    had to order the smaller rear anti sway bushings, it came with 20mm and mine is factory 17mm. begin bushing thrashing....tomorrow yawnz!.
    Rob
  7. #36
    Nov 2012
    lots to this kit. let see if i remember without looking it up.
    sway bar and end link bushings front, stock bar
    sway bar 20 mm rear, no end link bushings
    front lower control arm bushings
    rear trailing arm bushings
    add in the kit for the rear 17 mm bar and end link bushings
    jar of super sticky bushing grease
    kind of instructions. better on the website. best on the club.
    first up was the rear sway. mainly ease of access and time constraints. whoops, time. this is where i learn about pb blaster and small bolt failure from rust and torque lol. i was glad i had decided to do this in stages from the beginning, every set fought in its own special way.
    bolts came out fine, see rust and begin to coat Everything thats possibly coming out in pb. a bit of wire wheel and primer to keep the rust at bay for easy install. kinda lol.
    till here anyway. saved the bolt frozen in the bushing. continued the beat down, the car was winning it too!
    getting these in was a ...not so bad. had trouble right off the bad and looked it up. most everybody cut these in half and i did to, until our alignment tech showed me a neat trick for the larger ones that should remain solid.
    first fight is over. win and noticed right out of the bay a difference. cant wait to do more!
    Rob
  8. #37
    Nov 2012
    on to the front sway bar. this time i had More time, more pb, more prep and some new tricks!
    it was a good thing to. i had more busted! what a mess. and thats really a tight fit to replace without dropping the sub frame but it works. again, new hardware after chipping off the factory welded and rusted stuff.
    much better.the end links proved to be easy this time. used a vise and a really small bearing race to press them in. worked like a charm, the race just guides the bushing right in.
    and done! front sway bar. really notice difference now. car feels good and starting to narrow down what i want from my alignment. have like three threads going on at the same time about it and got great responce back. at one point, near real time answers on my threads while wrenching. cant tell you how cool that is working solo!
    Rob
  9. #38
    Nov 2012
    ok on the the really tough stuff. rear trailing arm bushings. knew i was in for the night and planned accordingly. boss tells me if im still here working in the morning i can take a break and run home for a few hours. i laughed then....
    these absolutely sucked to get out. That is a old(really old) exaust pipe expander and a twenty ton press.it was the only way i could get onto that skinny pressed in steel sleeved bushing and get purchase. stil wound up with a several hour fight for four bushings to be removed. the new? with the same bearing race trick and good lube like ten minutes for all four to be re-installed. the aftermath looks something like this
    hissssssss......but the new looks like this!
    yay new! again, can feel the new, but feeling the new wasnt so hot this time. started to make the car feel heavy, turning became a bit harder. already new parts were making for the need to align. posted and was reminded of that. of course the car felt weird, your not done with parts(finish the system upgrade!) nor are you aligned. finish up already!!!
    Rob
  10. #39
    Nov 2012
    time to get deep. last job under here, front lower control arms. ive heard some have to remove the sub frame for this because of a bolt location. i must have been lucky..
    just a plastic panel to move aside. couple of bolts and the lower ball joint...pop
    since the importance of the lower c-arm i did a bit of reading up. went to the local steel yard and had custom press tools made. got the measurements from energy suspension actually and had a solid(top piece) chopped of a raw blank and a carefully measured lower piece of heavy wall pipe. measured to fit in the rack like so.
    the rear bushing was strangely the tightest fit but the simplest to press out. bout maxed out the press doing it too!
    Rob
  11. #40
    Nov 2012
    old stuff and the press pieces i made.
    Rob
  12. #41
    slow no mo' ! Shoopster's Avatar
    Apr 2013
    Montreal
    holy cow, kid kodak! this thread needs moar pics
    -Stephanie 2004 WRB WRX | Blobeye Syndicate Member #104
    "I can't see the Shoopster from here; I'll wait for you outside."
    Shoopsterbuild 2.0: Better than it was before. Better, stronger, faster. And such JDM, yo.
  13. #42
    Nov 2012
    lol, you should see the amount left out
    Dang-it! pull road is blocked again...
    Rob
  14. #43
    Apr 2013
    Montreal
    Quote Originally Posted by tirerob View Post
  15. #44
    Nov 2012
    Quote Originally Posted by Shoopster View Post
    THAT IS AWESOME! Couldn't say it better myself! I'm going to go :ROFL: now.
    Made my day
    Rob
  16. #45
    Nov 2012
    yay another box of goodies came.!
    tic clunk killer, both the tic and kartboy parts. all awesome
    tic rear transverse mount bushings(due to frozen bolts, yet to be installed)
    torque solutions pitch stop
    group n rear shifter bushing to go with the energy suspension front
    spt battery tiedown. hey...i never had one so i splurged. ok not really. its just about the same price as the factory unit .
    ready..GO!
    got this
    and this
    whoops forgot about these
    so i could do this(pardon the glare)
    easy mod. love the directions from tic as well. good stuff
    and do this...
    these were so soft i pushed them out by hand!
    same with this one. just popped out with thumbs. marked improvement lol.
    the energy suspension replacement.
    and this guy. bit of a squeeze to do without removing anything else but i got it in and good shifting is now Good Shifting!
    Rob
