The BrownBat Build - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 57 of 57
This is a discussion on The BrownBat Build within the Builds forums, part of the Tech & Modifying & General Repairs category; Winters are on. Oh by the way, I got an STI wing. Haters gon' hate!...
  1. #46
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    Winters are on.
    Haters gon' hate!
    ¯\_(ツ)_/¯
    Kunal - Ordered 2015 DGM WRX
    Photographer | Dancer | Tech Nerd | The Stink-Eye Mob #7
    First Mods: What and what not to do
    2011+ Big Mod Thread
    How to Buy a Used WRX or STI
    Complete USED WRX Buying Checklist
  3. #47
    Palmyra, NJ
    Oooo you have a saggy butt!!!
  4. #48
    Nov 2012
    Lansdale, PA
    **Update**
    I am officially on Stage 1 by WTF Tuning. Thanks Matty.
    My favorite part about this tune is definitely the Throttle Response and the Instant Boost around 2500RPM. This tune should definitely be delivered from manufacture, in my opinion. If you like to receive a more depth analysis of the stage 1 tune, definitely check out Calvinball's thread. He provides GREAT feedback.
    In terms of logging, I had one successful log, where 100% of the throttle was applied from 2500RPM to redline. There was no knock at all, which was a big relief. However, I was hitting 21PSI. This was not very surprising to me since I did have some overboost issues with my stock tune. I was hitting 18psi with stock. After speaking to Matty, this definitely seems like a mechanical issue.
    We suspect it could be one the following
    1) Vacuum Leak...I left my car on idle for about 20-30 minutes and at 30 minutes, my A/F Learning #1 was 8.59.
    2) Boost Creep
    3) TBA
    Also, from what others have said and from my speculation, the previous owner of my car was on stage 2. Since he was on stage two he might have tweaked the WGA. Im not too sure. Once this is fixed, I will go logging more.
    Here is the log where the overboost occured.
    https://drive.google.com/file/d/0B90...it?usp=sharing
    ¯\_(ツ)_/¯
  6. #49
    Quote Originally Posted by kprugbyplaya
    2) Boost Creep
    3) TBA
    I don't remember you mentioning the overboost issue on the stock tune, or else I wouldn't have sent you the initial map.
    1) Check the vacuum lines from the boost control solenoid
    2) Check the BCS itself (is it stock?)
    3) Swap with known good parts
    As I mentioned to you on the phone, you should either flash the stock map or the one with zero WGDC until you can get your issue resolved.
    Resident Tuner @ WTF Tuning
  7. #50
    Nov 2012
    Lansdale, PA
    **UPDATE**
    Just as Mattypants predicted, the overboosting was caused by my faulty stock BCS.
    I took the car into RT tuning to diagnose the overboost condition.
    They did a smoke test via the Intake System and found low pressure leak at the TB to IC coupler(which is a common issue for my generation). So I will need to fix that in the near future.
    The WGA was tested with air pressure. Actuator appeared to move freely, but it is rubbing on my turbo blanket, but full range of motion was correct. I may have to move the blanket a little, so it does not cause rubbing. Stock boost pill remains intact. Stock BCS is installed correctly
    So, in order to be safe they disabled my BCS and directly ran the manifold pressure to the internal wastegate actuator. They tested my car with this setup and boost was at 9 psi through full RPM range, as it should be. This basically means that it is my BCS, since my actuator is working perfectly.
    All the vacuum lines are zip tied to prevent blow offs and the turbo nipple is capped to prevent leakage.
    Now, to find a working stock BCS. Anyone have one?
    ¯\_(ツ)_/¯
  8. #51
    Jan 2012
    Philly Area
    Quote Originally Posted by kprugbyplaya View Post
    I seem to recall reading that some 3rd gen folks did something along the lines of removing the coupler, and just clamping the hose directly to the IC nice and tight.
    - Will
  9. #52
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    **UPDATE**
    You could also think about going aftermarket. GrimmSpeed's EBCS is supposedly really good and It's only $119.99 before taxes.
    Electronic Boost Control Solenoid 3-Port - Subaru - GrimmSpeed
    I have no idea how much a stock BCS is but I could imagine it's not too far off from those numbers GrimmSpeed has. I've also heard that the stock BCS is not the greatest. It may be a good opportunity to upgrade.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
  10. #53
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    I've got a stock BCS. It came off my 02 though.
    The GM BCS is around $30 and gives good results. You'll need to be handy with a soldering iron though.
    Edit:
    Looks like mine won't fit. This might though SOLENOID VALVE for SUBARU |16102AA380
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
  11. #54
    Nov 2012
    Lansdale, PA
    So major update to my thread.
    I officially sold my car today.
    But will be getting the 2015 DGM WRX, soon! So until then, I will be driving around a pedo van as a daily, i mean a cargo van.
    The wait...will now be....brutal.
    ¯\_(ツ)_/¯
  12. #55
    Dec 2011
    Pottstown PA
    most kids just get the munchies on 4/20. kunal sells his car. newb.
    didn't even let me drive it again thats alright as long as i can whip the 15'!!
    oh and you still better come to VM and my meat on may 10th.. idc if in the pedovan or get a ride lol
    Marky Mark
    My bugeye build
    MinoskePhotography
  13. #56
    Jan 2011
    Maryland
    I'm hear for the free candy.
    pete25r's build
  14. #57
    Dec 2011
    Pottstown PA
    Quote Originally Posted by pete25r View Post
    here*
    y u disappoint me?!?!
    Marky Mark
    My bugeye build
    MinoskePhotography
