2003 ej257 swap help!
Results 1 to 7 of 7
This is a discussion on 2003 ej257 swap help! within the Builds forums, part of the Tech & Modifying & General Repairs category; I'm considering buying someone's project off of them but had a couple questions for the forum. All the project needs ...
    Jan 2013
    I'm considering buying someone's project off of them but had a couple questions for the forum. All the project needs to have a running wrx is a turbo, wiring harness, and ecu.
    I'm pretty unfamiliar with the spectrum of turbos that often find their way under the hoods of wrxes. Can someone give me a list of stock ej257 compatible turbos or maybe a really good link to a wiki type page about the range of turbos? I'm trying to see the scope of this project and any information can help. Thanks.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
    Jul 2012
    Rocky Top
    Probably a lot more info than what you need, but hopefully it helps.
    VF series turbo comparison - Subaru Impreza GC8 & RS Forum & Community: RS25.com
    Jan 2013
    Thanks man, this is perfect!
            MainFrame's Avatar
    Austin, TX
    Why go with a stock turbo? You can get aftermarket turbos that will cost less (new vs. new) and will out perform a stock turbo.
    Jan 2013
    Well as far as I know it has all the stock components, ie injectors, fuel pump ect. That's why I asked for a link about compatible turbos to see what my options were. If I can get an aftermarket turbo with the stock set up than I will.
    If I get this car I'm not looking to build a monster, just a dd. In the future I will Prolly tear it back down and build everything, fmic, six speed, axles, and the works. Just looking to finish the swap and drive it currently.
            MainFrame's Avatar
    Austin, TX
    What year model is your longblock?
    Jan 2013
    07
