ej22
Results 1 to 3 of 3
This is a discussion on ej22 within the Builds forums, part of the Tech & Modifying & General Repairs category; im rebuilding my ej22 due to a bent valve. I found some ej 205 heads for pretty cheap. I have ...
    Apr 2012
    A, A
    ej22
    im rebuilding my ej22 due to a bent valve. I found some ej 205 heads for pretty cheap. I have sti heads now. would it be a redicules downgrade to throw the cheap ones on while I can take some time to rebuild the ones I have?
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Do you run AVCS?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    zax
    zax is offline
    Nov 2008
    If you are running AVCS on your block, the USDM EJ205 heads will not really work. You'd need to plug the oil lines and disable the AVCS in your ECU to run EJ205 heads. If you are not running AVCS, then you could go to the EJ205 heads. EJ205 cams are a little milder than the EJ257 cams and much milder than the EJ207 cams. However, EJ205 heads also flow more than either EJ207 and EJ257 heads, and with some valvework and aggressive cams have by far the most capability for flow.
    So. If you are going to build a set of heads, and you're not concerned with AVCS, then I would build the EJ205 heads. If you are running AVCS, the EJ205 heads won't work anyway.
    Facebook me here
