Z06 LOL Track Build - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
This is a discussion on Z06 LOL Track Build within the Builds forums, part of the Tech & Modifying & General Repairs category; UPDATE! Just got a box in from Tom @ Kartboy! What do we have in there? Kartboy T-SHIRT SHIFT KNOB ...
  1. #31
    May 2013
    UPDATE!
    Kartboy
    T-SHIRT
    SHIFT KNOB
    FRONT STAY (6MT )
    REAR STAY
    OIL FILL CAP
    PITCH STOP
    OUTRIGGER BUSHINGS
    LOCK BOLTS
    FRONT ENDLINKS & SPACERS
    REAR ENDLINKS
    CRANK PULLEY
  3. #32
    May 2013
    MORE PARTS!!!!
    What came in:
    • OMP TARGA: Flat 330mm | Black suede Steering Wheel
    • Joes Racing MOMO STEERING WHEEL QUICK RELEASE ASSEMBLY
    • Sabelt Steel frames for side mounting 3 mm thick
    • G-Force PRO 6PT PD- LAP IND-SHLD CAM;SFI 16.1& FIA - Red
    • Longacre BSI RB Padding, Black
  4. #33
    Registered User Terminal Kuz's Avatar
    Aug 2012
    SoCal
    Jealous, I love reading about rs track builds. Read a nice one in an old import tuner I found out here.
    2005 WRX (Silver) SoCal Subie
    Blobeye Syndicate #1093
    http://www.clubwrx.net/forums/builds...al-05-wrx.html - Build Thread
    http://www.flickr.com/photos/34009765@N06/ - For whatever pics i take.
    Mikie13-Spend money on hookers and blow. That's a better intake.
  6. #34
    May 2010
    Pittsburgh, PA
    Great thread! Jealous!
    2011 STi Build Log
  7. #35
    May 2013
    Up on jack stands she went (I think that she will be this way for a little while)
    Started ripping the rear suspension out.
    Charcoal canister emissions BS not needed here.
    More removal to come soon but I had to tuck her in for the night!
  8. #36
    May 2013
    After this post you guys are all caught up!!!
    If you guys wish, I can continue to give updates as progress is made on this car.
    Rear suspension part 2
    Got the car back in the air and FINISHED ripping the rear of the car apart.
    Stock RS tank was not going to cut it.
    Dropped the whole rear subframe
    Rear is ALL empty
  9. #37
    Registered User 11blackwrx's Avatar
    Sep 2011
    Akron, OH
    need moar!
    2011 Subaru WRX Premium
    1988 Ford Mustang GT
    2000 Jeep Wrangler TJ
  10. #38
    Palmyra, NJ
    I know I'd love to keep seeing updates!
  11. #39
    May 2010
    Pittsburgh, PA
    +1
    2011 STi Build Log
  12. #40
    May 2013
    Bushings!
    Got some free time to press out the factory bushings and press in Turn in Concepts Graphite Impregnated bushings!
    The factory bushings are SOOOO SOFT! (I am sure all of you already know this)
    The factory STi trailing arms were not going to cut it for this build, so I deicided to go with MSI 4130 Chromoly tubular trailing arms. (Was not sure if I should install these on the car or hang them on my wall as art)
    I used MPT Silicone lube for all of these bushings (works wonders)
    Turn in Concepts Forward Bushings installed!
    Where the trailing arm attached are some more soft bushings!
    Out with the OLD and in with TIC!
    Factory lateral links were very dirty so I quickly cleaned them up and painted them
    Turn in Concepts shore 95a Lateral Link Bushings Installed!
    The STI rear dif mounts were just pathetic!
    Again Turn in Concepts bushings were used here to stiffen everything up!
    A few more things to do and then the whole rear end gets to go back in!!!!!!
