Perrin vs Cobb Stage 2 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on Perrin vs Cobb Stage 2 within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by MainFrame Yeah.. if you blow your engine you can't just put the stock exhaust back on and ...
    Feb 2013
    North NJ
    Yeah.. if you blow your engine you can't just put the stock exhaust back on and expect to get away with defrauding the dealership into replacing it under warranty. More than likely they would see the downpipe bolts had been removed before and deny your warranty claim based on "indications of previous modification". Then again, some dealerships wouldn't care.. and some would deny the claim even if you had never modded by citing "indications of abuse". It's a crap shoot.
    Understandable... Anyone know of mod friendly dealerships in NJ? Specifically north Jersey.
    Quote Originally Posted by SuzyTheSubaru
    So if i was go get the Cobb Stage 2 package they would have a map already on the Access Port for the TBE that comes in the package correct? Also do you know what the maps might cost if you have them made for your specific parts on the car? Just a round number doesn't have to be exact.
    Maps may not be on there, at which point you download them free off Cobb site and load them on the AP.
    Custom tuning varies, but typically, you're looking at $400-500.
    Resident Tuner @ WTF Tuning
    Feb 2013
    North NJ
    Are there any EBCs that you recommend?
  6. #19
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by SuzyTheSubaru View Post
    The GM EBCS costs less than $30, but it does require splicing of two wires. Motive Autowerks EBCS is $85 and plug and play. Of course you might want to consider the fact that neither Cobb nor Perrin offer any free maps for the AP that are designed to work with any form of aftermarket boost control, so a custom tune would be required to run one.
  7. #20
    Feb 2013
    North NJ
    So Cobb's Access Port doesn't have maps that work with aftermarket EBCs. But if you ask them through the site to create you one they will but at cost correct? Also if I do get the Cobb Stage 2 package do I need to up the boost? Or will upping the boost just give better results?
  8. #21
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    You don't "up the boost." The stock EBCS is controlled by the ECU and complies with the boost control tables on the map. Cobb OTS maps do not support 3-port EBCS, as the 3-port requires further tuning of the WGDC and Turbo Dynamics tables. Interestingly, this applies even to support for Cobb's own EBCS. You can, however, purchase a 3-port EBCS and tune yourself using Cobb's free AccessTuner Race software.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  9. #22
    Palmyra, NJ
    You're in Northern NJ...you have quite a few tuning options that would probably be better for you than just contacting Cobb and asking them to make a map to use it.
    When you go Stage 2, the appropriate map that comes with it will already increase boost. Read the map notes.
  10. #23
    Feb 2013
    North NJ
    Please excuse my ignorance but what is OTS and WGDC mean. I even check the Acronyms thread and didn’t see either. So is it a must in the tuning process of the Stage 2 package that I will be purchasing, that I get a EBC?
  11. #24
            MainFrame's Avatar
    Austin, TX
    No, you would need to take your car to a licensed Cobb tuner in your area and they would be able to make a map for you. But then once you're paying for a custom tune, why even get the AP in the first place? Seems like a waste of $600 to me.
  12. #25
    Feb 2013
    North NJ
    Ok so in that case is there any need right away for ebc? Mt. Laurel? Is that close to Long Valley?
  13. #26
    zax
    zax is offline
    Nov 2008
    Your car HAS an EBCS stock!
    Facebook me here
  14. #27
    Feb 2013
    North NJ
    Haha alright sorry but what was the 3-port you were speaking of?
  15. #28
    zax
    zax is offline
    Nov 2008
    Please take the time to read:
    Boost Control FAQ: Read if you are thinking of buying one! - NASIOC
    There are two distinct types of electronic boost control solenoids: Interrupt type (3-port) and Bleed type Solenoids. The stock is a bleed-type solenoid that is less responsive than an interrupt type solenoid.
    Facebook me here
  16. #29
    Feb 2013
    North NJ
    Thank you
  17. #30
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    OTS = Off the shelf - refers to "canned" maps or one size fits all maps, such as the ones you get from COBB or PERRIN.
    WGDC = Wastegate duty cycle - a pulsing signal that makes your wategate actuator open (very simply put).
    Check out this blog...Explains a lot about how boost control works. Boost Control Systems Explained….. Part 1 » PERRIN Performance Official Blog
