Page 1 of 5 12345 LastLast
Results 1 to 15 of 64
This is a discussion on pete25r's bugeye progress (pic heavy) within the Builds forums, part of the Tech & Modifying & General Repairs category; Short story: 2002 WRX Sedan Mods: 3in TBE exhaust – cat welded in downpipe, Borla muffler wrapped upipe silicone inlet ...
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    Short story:
    2002 WRX Sedan
    Mods:
    wrapped upipe
    silicone inlet
    silicone afta MAF
    COBB SF (short ram)
    PNP TD04
    Deatchswerks fuel pump - DW200 / 255LPH
    Kartboy Short Shifter
    tint
    radio & speax (kenwood HU/pioneer sp)
    DIY aluminum radiator shroud
    DIY aluminum air box
    Kartboy Front and Rear Endlinks
    Whiteline Adjustable Swaybars - 24 front on softer and 22 Rear on middle (might adjust stiffer later)
    Stock:
    everything esle
    Long Story:
    I'm a Subaru fanboy. I've had 3 80's models, loved each one. I wanted to get a turboed car so heck, I'll go find myself a WRX. Here's what I found (Feb 2011) License plate is photoshopped, dealer tag was there and ugly.
    Underhood - TurboXS atmos. BOV, COBB SF with beatup, dirty filter, exhaust leakS
    yeh, filter was supposed to be blue...
    A week after I brought it home I replaced the air filter with a K&N that was longer. I stuck a piece of old tshirt between the filter and the inner wall so it wouldn't rub the paint off since is was touching. That didn't help all that much... And yes those are legit JDM zipties relieving some strain on the intake tubing. And notice the silly STI stick-on came off.
    So you wanna see some wierdness? Someone welded a largish cat on the 3" downpipe. You might not be able to see in these pics but man-o-man them welds ain't pretty. The welds are structurally sound looking but more of the "bigger the blob, better the job" category.
    From the downpipe back its 3" and looks like Borla, resonator in midpipe and dual tipped Borla embossed muffler. Sounds good, not to loud but sounds like it has a pair.
    Paint looked good, somewhat fresh. Interior was ok, carpet was beat up, wholes under floormats. It was missing the clock, had a stock 6disc/tape radio, stock speakers, no guages, stock fog lights, wholes drilled in most of the "blanks" by the cruise switch. There was also an off brand remote start unit in it, still wired up just no fuse in the 12v+ line. There were also some other various rat's nests wired in under the dash. When I took it on a test drive I noticed there was a Cobb AP USB dongle-thing on the OBD-II port, no AP though.
    I didn't know this until I went to a meet but it's got a short throw shifter with a kartboy sticker on it under the boot. And the boot trim has an STI on it and doesn't quite fit right, it's always falling down off the part that's supposed to hold it up.
    N.E.R.D. # 3.579545 MHz
    my build thread
    Jan 2011
    Maryland
    done?
    Here's what I've done so far...(not in order)
    replaced the radiator with an aluminum CX racing one (ebay special)
    replaced TurboXS BOV with stock BPV - wasn't for me hated the backfire on shifting
    cusco turbo heatshield, don't think it helps all that much but I got a deal on it and bling!
    silicone between Cobb SF and TD04
    CD/MP3 headunit (Kenwood?) and some pioneer speakers - they sound a good bit better than stock but not awesome enough to go into detail
    installed sound deaden-ing material in front doors (doing back soon), used fatmat. its ok, it did cut down a good bit of noise
    Logged, logged, and read some, logged, read more.. and tuned my ecu a little. It had a map that wasn't stock on it when I bought it. Didn't know anything about the tune that was on it, who did it what were they trying to do.... I'm OS tuning it now. Got it running ok, got some knock that I think is bogus but need to do a little more logging and looking, then I'll push it a little.
    tinted the windows 35% front and rear - that sure did help in the SC heat
    I made two things out of a sheet of aluminum for under the hood. A radiator shroud cover, that was easy, and an airbox, not so easy. The airbox didn't turn out exactly like I wanted it too but I'm sure it helps a little as it blocks some of the heat coming off the engine. When I go to remake one I'll make it a little taller so it can have a lid or something put on it and also find a way to move cool air into it, fan or route the under hood air diverter thing.
    I also made a switch to make reading/flashing my ECU easier. When I get un-lazy I'm going to install it in one of the pre-drilled blanks near the cruize button...
    A couple of weeks back I installed a Deatschwerks DW200 (255lph). --One tip, for noobs like me, on the install process is after everything is plugged in and dropped into the tank, bolt and cable everything up BUT the fuel delivery line running to the engine. Get a piece of vacuum tubing or whatnot and attach one end to the fuel delivery coming out of the take and run the other end into an empty container that can hold fuel. Secure the tube to the container, you don't want fuel spraying all in your backseat do ya? Turn the car to the "ON" position, no need to start it, just want to turn the pump on. Turn to "ON" once or twice just to make sure its pumping. You should hear the pump whir and spray in the container. That's called priming I believe.
    --another side note, I put the DW sticker that came with the pump on top of the access cover for the fuel tank pump assembly, the piece in the trunk. I wrote the date I installed it on, on top of the sticker so if I ever loose my mind and sell/trade it dude won't have to dig in the tank to know what's in there.
    my build thread
    Jan 2011
    Maryland
    Goals
    What I want to do with the car is have a fun, reliable DD.
    I haven't really set a horsepower goal.
    Plans
    injectors 650-720 depending on turbo I choose
    VF39 or similar - I want a quick spooler, haven't done all that much research. It'll be a little while before I drop a bigger turbo in.
    I have some TD04s that need some TLC, well one is need of a new turbine shaft and other parts so it's just a compressor and turbine housing donor. The other is in good shape except it needs a rebuild. I've gasket matched and cleaned/polished up the broke one and working on the rebuild one's housings. I'm going to pick the better of the two and rebuild then swap with my stock TD04. I know I won't be making mad HP but I needed a fun project.
    Pics of the first TD04
    DSC_7027 | Flickr - Photo Sharing!
    DSC_7019 | Flickr - Photo Sharing!
    DSC_6994 | Flickr - Photo Sharing!
    DSC_6993 | Flickr - Photo Sharing!
    my build thread
    Jan 2011
    Maryland
    One of the bearings on the for the timing belt has gotten rather noisy.
    I've got a Gate's belt kit w/pump on order. When I was dropping my headers(stock) to replace the gaskets I noticed a couple of spots where there was some oil seeping out of the camshaft areas. I've got some new camseals on order too figured, hey while I'm there....
    I'm also contemplating swapping out my stock TD04 for a DIY rebuilt, DIY PNP TD04.
    my build thread
    Jan 2011
    Maryland
    fix one, find two...
    Today I changed my timing belt and pullies. Took me a while, cleaned parts as I went. It wasn't that hard though. Search on youtube and NASIOC for Meaty/Meatball's howto. It rocks.
    Got the belt changed no probs. I found out that I have a tear in my front pass. CV boot. Grease on my cat/downpipe too. Sux.
    Either my A/C tensioner pulley or A/C's clutch has gotten quite noisy. Hopefully it's the pulley. Sounds kinda like plastic scraping/rubbing on metal.
    my build thread
    Jan 2011
    Maryland
    Fixed the A/C tensioner, horrible noises stopped. Also got the C/V boot fixed. The boot was quite easy after I found a little clip-wire was holding the shaft in the part that mates up to the tranny.
    Been trying to find a good time to put this PNP(mildly) and rebuilt TD04 on. My current TD04 is no where near eating itself yet but I want more spool and needed a DIY project.
    The gaskets on my ride look horrible. The only set I haven't replaced yet is the turbo up and down pipes. And I"m missing a stud on my installed turbo.
    my build thread
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    You said this was pic heavy :P
    My "Build" Thread!
    2006 WRX TR
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Jan 2011
    Maryland
    It was pic heavy to start. I'll get more pics up. Not much has changed though. Didn't want to bore anyone to death with nothing fun to look at.
    Maybe a shot of how clean my timing belt cover is? hmmm....
    not really a pic but here's a video of me playing with the PNP TD04.... took a shop vac and blew in the up-pipe flange...
    TD04 (off of a Subaru, 13T) - YouTube
    my build thread
    Dec 2011
    Pottstown PA
    looks good, i like the airbox heat shield ya made!
    Registered User iamlongbeard's Avatar
    Jan 2013
    looks good
    AEM cai
    mishimoto radiator
    GReddy exhaust
    sti short shifter
    Jan 2011
    Maryland
    thanks gentleman, I was wondering when someone was going to comment on my thread here...
    making the airbox was one of those I need a DIY project things. I get that itch every couple months. Same with the radiator shroud thing. The radiator shroud was way easy. I found a piece of cardboard to pre-fab/measure and then transfered it to the leftover sheet aluminum from the airbox.
    Next up I'm swapping my TD04 for the rebuilt PNP one. I'll post up some pics too just for making it heavy's sake.
    my build thread
    Nov 2011
    North GA
    That video was pretty cool!
    My "Build" Thread!
    2006 WRX TR
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Facebook me here
    Registered User 11blackwrx's Avatar
    Sep 2011
    Akron, OH
    nice pics, looks like whoever had that before was a real genius
    2011 Subaru WRX Premium
    1988 Ford Mustang GT
    2000 Jeep Wrangler TJ
    Mt. Laurel, NJ
    Nice Pete! Figured I gotta get in here and say something. How much was the Cobb intake pipe? I have the intake too (thanks Zachy-poo).
    I've also wanted to make myself an airbox.
