Results 1 to 10 of 10
This is a discussion on Question about oil plug? within the Builds forums, part of the Tech & Modifying & General Repairs category; Is the oil plug a 17 mm 6 sided plug? I tried 14-21mm wrenches and it felt like it was ...
    May 2012
    Is the oil plug a 17 mm 6 sided plug? I tried 14-21mm wrenches and it felt like it was going to strip the plug. I think those wrenches were 12 sided metric wrenches. Oh.btw it's a 02 wrx
    Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
    I would not use a 12 sided wrench on a regular 6er bolt. Mine was a 17mm, yes. I no longer use a bolt at all; I use a Fumoto instead FYI
    QuickOilDrainValve.com
    However, you have a drain valve and it's 6 sided. Use the correct wrench. If you are concerned, you can order a replacement from a dealer for very little cost.
    May 2012
    Re: Question about oil plug?
    Okay I just wanted to clear things about about size of wrench and what not. I'll be sure to buy a 6 sided wrench next time. Might buy a new drain plug too.
    Apr 2007
    8000' up in Colorado
    On a car that old, it's very likely the drain plug is corroded and no longer the size it was when new. Getting a new plug is a good idea.
    Scott
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    + 1 to above. I have one of those drain plug valves and makes oil changes super easy, fast, and clean. It also makes lab analysis sampling a breeze.
    2011 WRX Limited Spark Silver (5 Door)
    Registered User Pylonpounder's Avatar
    Aug 2010
    Factoryville, PA
    I never really found it in myself to trust those. I've worked on cars with them on it, and the models I've played with seemed entirely too easy to open. I just don't trust it. But, I'm also young and nimble and don't have an issue using entirely too much time and energy crawling under my wrx, which is entirely too low for anyone sensible to want to deal with. But I never claimed to be sensible.
    KHP
    KHP is offline
    Oct 2010
    Reno, NV
    Quote Originally Posted by Pylonpounder View Post
    I had the same reservation when I first installed mine (maybe I'm crazy lol ). You have to follow two mechanical steps to open them and it seems to have good safe guards against accidental opening. You can lock the valve from opening using a clip if you're really paranoid. To open the valve requires compressing a spring above a step (this part is easy) and twist which I found to require some effort. I feel that the probability of it being sheared off by a random object is a lot higher than it accidentally opening. Just searched the net and haven't seen anyone complaining of it accidentally opening.
    A related thread regarding this: Fumoto Drain Plug Valve...
    One thing that I love about mine is that you can slowly open the valve to prevent splashes when changing the oil. I hate having to back out the plug not knowing where the end of the thread is then all of the sudden the plug pops out and falling into the drain pan. Tons of oil come rushing out having my hand in the way. Before I know it I have oil all over my arm. Then fighting to quickly re-center the drain pan, and making a mess all over the ground.
    Anyway I've had mine for 2 1/2 years running now and no issues(Obviously with anything in life your mileage may vary lol). Have grabbed a total of 6 samples and done 4 oil changes.
    Oct 2012
    woodbridge, va
    Drain valve ftw . I ran one on a truck that saw a lot of offroading and even going over brush and bottoming out I never had an issue
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
    2013 WRX
    Registered User OakFF252's Avatar
    Oct 2011
    Bergen Co., NJ
    Damn wish I saw this sooner. I just bought one of the magnetic ones to get free shipping from RSD. lol Seems nice, but its aluminum, so it'll be easy to strip.... Just have to be careful. Plus think of the weight I'm saving.
    It's Al with a magnet on the tip?
