Januch09's 2011 STi Build (PTE6266)
Page 1 of 57 123456789101151 ... LastLast
Results 1 to 15 of 854
This is a discussion on Januch09's 2011 STi Build (PTE6266) within the Builds forums, part of the Tech & Modifying & General Repairs category; Frank’s 2011 STi Limited (SWP Sedan) Build Link to full build: Frank's 2011 STi Sedan Full Build Hey guys just ...
    Registered User Januch09's Avatar
    Jan 2012
    NJ
    Cool Januch09's 2011 STi Build (PTE6466)
    Hey guys just a little background. I have an 2011 STi sedan with roughly 20k miles on it. Currently on motor number 6. Not going to get into why I've been through that many motors or anything, so basically I'm starting fresh on this one.
    Here's the specs:
    Short Block:
    Built by Prime Motoring in East Rutherford NJ
    -New EJ257 Case Halves
    -Darton Sleeves O-ringed
    -OEM Nitraded Crankshaft
    -Cosworth 99.5 / 8.2:1 CR Pistons
    -Cosworth Oversized Headgasket
    -Manley Turbo Tuff I-Beams w/ ARP Bolts
    -King XPG Main and Rod Bearings
    -Killer B Oil Pick-Up & Baffle
    -11mm High Volume Oil Pump
    Heads:
    Built By Headgames
    -Pocket Port
    -O-Ringed
    -Ferrea Exhaust and Intake Valves +1mm
    -Ferrea Guides & Locks
    -GSC Beehive Springs & Retainers
    -GSC S2 (272) Camshafts
    -Cosworth Head Gasket
    -ARP CA625+ Headstuds
    -Denso IKH24 Spark Plugs (2 steps colder)
    Fueling:
    -ID2000 Injectors
    -DW65c Fuel Pump In Tank
    -Radium Engineering Fuel Surge Tank w/ 2 walboro 485 submerged
    -Vibrant -6an feed and return lines w/ vibrant fittings
    -Aeromotive Fuel Regulator (red)
    -Agency Power Fuel Rails (red)
    -Aeromotoive inline fuel filter 6 Micron
    Induction/Turbo/Cooling:
    -ETS Rotated Turbo Kit
    -Precision Gen2 6466 V-Band Turbo, hot side ceramic coated, compressor cover powder coated Perl White
    -ETS Black Anodized FMIC 4’’ Core, 3’’ Black Piping (AIT bung and tial flange) (white powder coated clamps) (speed density)
    -AEM AIT Sensor
    -Tial QR BOV
    -Grimmspeed Electronic Boost Controller
    -Crawford FMIC Rotated AOS
    -Koyo Radiator & Cap
    -Samco Radiator Hoses (black)
    Exhaust:
    -Killer B Holy Header (ceramic coated)
    -ETS Rotated Up-pipe w/ Tial 44mm EWG (red)
    -ETS Catless Rotated Down-pipe
    -Invidia Q300 Rolled Titanium Tips CBE (kartboy extra long exhaust hangers)
    Drivetrain:
    -Clutchmaster FX400 6-Puck Clutch
    -Kartboy STS w/ all Bushings
    Gauge Setup:
    +SMY Clustermaker
    -AEM Air/Fuel Ratio Wideband Gauge
    -AEM Boost Gauge
    +JCS 3 Gauge A-Pillar Pod
    -AEM Oil Pressure Gauge
    -AEM Fuel Pressure Gauge
    -3rd hole closed for now but eventually ECR Gauge
    Tuning:
    Pro-Tuned by JR @ Prime Motoring
    *Pump Gas- 450whp/420wtq
    *E85- 575whp/540wtq
    Wheels/Tires/Suspension/Brakes:
    -Airlift V2 Performance Air Ride Kit w/ Dual Viaar 380c Compressors, single 5 gallon tank & water traps (tank paint matched)
    -Whiteline Front and Rear 24mm Adjustable Sway Bars
    -Kartboy Front and Rear Endlinks
    -Whiteline Steering Rack Bushings
    -Whiteline Rear Dif Positive Power Kit Bushings
    -Whiteline Rear Positive Traction Kit
    -SBC Rear Control Arms
    -18x9.5+30 Enkei Kojins (Powder Coated Copper)
    -Sumitomo HTZIII 265/35/18
    -Muteki SR34 Neo-Chrome Closed End Lugnuts
    -Hubcentric Rings 56.1 to 76
    -Stoptech Drilled & Slotted F&R Rotors
    -Hawk HPS Pads
    -Stoptech SS Lines
    -Grimmspeed master Cylinder Brace
    -Motul SP600 Brake Fluid
    My PTE6266 vs. my old Blouch Dom4.0XTR
    2011 STi----------PTE6266--------Fully Built---------ETS--------E85
            MainFrame's Avatar
    Austin, TX
    I hope you're going to be running e85 or race fuel on such high compression. Most people I've seen try over 9:1 compression lots a considerable amount of power.. 9.8:1 is crazy high for these cars.
    Jan 2012
    NJ
    not running E85 yet. Maybe by next summer, I'll beef up the fueling a little more and run E85 as my daily . Thing that sucks about E85 for me is, there ar literally only like 4 E85 stations in NJ. Luckily I live 20 min from 2 of them. But still don't know if I wanna run it all the time.
            MainFrame's Avatar
    Austin, TX
    With that high CR you're probably going to have to run really conservative timing to prevent detonation on 93 octane.
    Jan 2012
    NJ
    idk I dont tune my own car lol. It's getting retuned by Jr in a couple days, so we'll see what happens. It made over 400whp on pump before I did the TGV deletes so well see what it actually makes soon.
    Apr 2012
    this thread is useless without pics.....
    Jan 2012
    NJ
    Quote Originally Posted by 90crxfreak View Post
    I wouldn't say it's useless. But this forum rejects like every single picture I try to upload. I'll add links to photos from my photobucket account for you to click on!
    There ya go, pictures added!
    May 2007
    orlando flawduh
    Quote Originally Posted by Januch09 View Post
    you need to use the [img] link from photobucket for the pics to show up
    desiree
    Apr 2012
    Each picture should look like this.... [img]thelink[/img]
    Apr 2012
    When is the next time your going to New Brunswick? I've been wanting to show you my lights.... and I thought I saw your car in TurboTrix last Friday when Kronos was dynoing his tunes...
    Jan 2012
    NJ
    Ahhhhh I see, pictures added! Thanks
    Jan 2012
    NJ
    Whenever my car is done lol. Yes it was at Nightshift* and still is there. Getting more work done :/. But anyways, who are ya lol, what car?
    Apr 2012
    your second pic down.... the only one with no lights on... :P
    Jan 2012
    NJ
    Ooooo ahhahah thats you! lol. When I get my car back, I'll start going to the Tuesday night meets more often, so I'll see u there!
    Jan 2012
    NJ
    Got my new Exhaust today! Invidia Q300 Ti-Tips.
