Januch09's 2011 STi Build (PTE6266) - Page 4
Page 4 of 57 FirstFirst 123456789101112131454 ... LastLast
Results 46 to 60 of 854
This is a discussion on Januch09's 2011 STi Build (PTE6266) within the Builds forums, part of the Tech & Modifying & General Repairs category; There's really no reason to run coilovers on the street. Seriously, there isn't. If ride height is your goal there ...
  1. #46
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    There's really no reason to run coilovers on the street. Seriously, there isn't. If ride height is your goal there are other methods for that. Cheap coilovers ride like ****hole and dropping the car past one inch is actually detrimental to handling since it seriously pushes the geometry out of its sweet spot.
    Coilover's main purposes are ease of changing springs for better rates and the ability to corner weight the car properly. They're not for ride height.. they're not for "stance" .. well, at least the good ones aren't.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  3. #47
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by mangostick View Post
    It sounds like the OP intends to regularly track the car, Shawn. Also, the brands listed (KW, etc) are definitely the good stuff. Ordinarily, I'd completely agree with you on coilovers, but I think the OP is considering them for the right reasons (i.e. track setups, not stance).
    2007 Outback 3.0R wagon
  4. #48
    Registered User Januch09's Avatar
    Jan 2012
    NJ
    Quote Originally Posted by Rambo View Post
    To be honest guys, I am doing coils for both performance and to give the car some stance also! And yeah I'm not looking into doing cheap coils, hell I'm not even looking into doing like mid grade coils, from what I've heard and read Racecomp & KW's are the top brands and the top notch coils! I'd be lying if I said I wanted coils strictly for track purpose, I do wanna add an aggressive stance to my car, but I am by far 100% against the whole wheel tuck and crazy camber and what not. I'm more into "hellaflush".....I'm kidding! I want a nice aggressive setup that I can go into a turn and feel super confident that I'll make it out! lol And I want the car to have a nicer "stance" too
    2011 STi----------PTE6266--------Fully Built---------ETS--------E85
  6. #49
    Oct 2009
    I haven't heard tein in reference to "good" ever.. usually the bar is set right around the $1800+ range for "good" coilovers.
    Problem I see routinely is that people buy coilovers because they're cheaper than a good set of struts and springs. Which for drag racing/street use will be absolutely fine. Hell the STI actually has decent dampening vs the wrx.. so where we wrx folks have to upgrade everything the OP can get away with just a set of good springs. Now if he wanted to get serious about road course stuff then yeah a $2k+ set of coilovers would be justified.. but for steet/drag.... nah man why spend that much cash?
    Racecomp Engineering : Home Page : 410-846-5407
    OP: Call and talk to Myles.. he'll set you straight.
    SWP 2013 FRS
    SUCH IS MANGO!
  7. #50
    Jan 2012
    NJ
    I do plan on autox the car! I wanted to get my power mods straight before I start road coursing it! (by power mods I mean hp) I rode in a buddies STi and he had KW V3's and that car drove 1000x better than mine did. Not just handling but even just when cruising the car was smoother and a more comfortable ride imo. Grant it, I was in the passenger seat so that may be why, but I know that car drove better than mine! And I want coils also so I can adjust ride height depending on season! Winter setup I want like stock location and stock wheels. Summer/fall setup, bring er down an inch or so and a nice meaty tire with some nice 18x9.5+38 wheels!
  8. #51
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Januch09 View Post
    You've heard wrong. I would consider RCE and KWs to be the top brands of the mid grade coilovers. To me, there are junk coilovers no one should buy, then there are inexpensive ones that should be for looks only, then midgrade that have some good performance characteristics, and then there are top of the line competition coilovers. If you want competitive coilovers for the track from a good manufacturer, then Cusco Comp-X Tarmac Rally Coilovers are what you should be looking at. AND, I believe they recently went on sale.
  9. #52
    May 2010
    Pittsburgh, PA
    Re: 2011 STi Sedan Build Thread (400+whp)
    Keep in mind... height adjustment effects toe in our cars fairly significantly. Plan on getting touch up alignments when you adjust the height.
    2011 STi Build Log
  10. #53
    Jan 2012
    NJ
    When I said "top of the line" i meant like top of the line everyday car coils! I'm not gunna run race car coils for my everyday street car! I'm going to wind up going with KW's or RC Tarmac 2's. I'll be able to have great height adjustment and still an awesome performance coil on the track!
  11. #54
    Jan 2012
    NJ
    What do you mean by toe? Sorry no very knowledgable when it comes to suspension! And I know that it's necessary to do an alignment when I change suspension, well coils at least.
  12. #55
            MainFrame's Avatar
    Austin, TX
    Yeah, you should be fine with either of those (Cusco also makes a line of every day coilovers that are very good). Not many people are looking to drop over $10k on coilovers for a $30k car.
  13. #56
    Jan 2012
    NJ
    10k on coils would be rather overkill imo ahahha, well at least for what I'd be using it for ahhahaha.
  14. #57
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Ok but stay away from the Teins if you want anything worth a ****.
    Sent from my DROID BIONIC using Tapatalk 2
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  15. #58
            MainFrame's Avatar
    Austin, TX
    Tein actually has some decent coilovers, just not the cheaper ones.
  16. #59
    Jan 2012
    NJ
    I like the Tein Flex, but like I said, I'm gunan go with KW V3's or RCE Tarmac 2's
  17. #60
    Jan 2012
    New Jersey
    I knew I saw the car before when I saw it at the shop. Hope its working out well for you.
    CFLip2x 2012 WRB WRX Build
