Januch09's 2011 STi Build (PTE6266) - Page 39
Page 39 of 57 FirstFirst ... 293031323334353637383940414243444546474849 ... LastLast
Results 571 to 585 of 854
This is a discussion on Januch09's 2011 STi Build (PTE6266) within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Januch09 More bad news. So Rallispec gave me the car back with it running terrible and said ...
  1. #571
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Januch09 View Post
    More bad news.
    So Rallispec gave me the car back with it running terrible and said that there is a tuning issue, nothing about it running on 3 cylinders. Well the timing cover and everything was taken apart yesterday and we found out that the intake driver side cam gear was off timing by about a whole tooth. The cam gear is messed up because the pin hit it and now it's ovalized. Just ordered a new cam gear today.
    But aside from that, who knows if the motor will come back with good compression now that it was ran with timing off. They did a leak down test for me and it came back at 50% but they are thinking that may be because the valves aren't opening. So once the cam gear is replaced, they will re-time it and do another leak down to see if it's good or not.
    The oil leak seems to be coming from the avcs sensor on the passenger side. Could possibly just be the o-ring but if that's not it, then the cage is leaking from what I'm told.
    The dipstick o-ring was on completely wrong and oil was leaking from there. My one coil pack clip was broken off and just placed on and could fall off at any time.
    I just really want everyone to think twice before choosing certain shops. What has happened between me and Rallispec is done with. I just want to spread awareness of the lack of shops that actually want to help people and fix their cars rather then screw you and get their money. No, I am NOT saying all shops are like that and my case is definitely out of the ordinary, but it just really sucks to see that a shop would do something like this….
    It is unlikely you will have impact from one tooth of cam phasing, though with the STI AVCS up to 30 degrees of phasing, I can't stand by those words. It make sense that you will not have static compression in both cylinders in the bank. To properly determine if the piston/valves have been damaged, you should run a leakdown test.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  3. #572
    Registered User Januch09's Avatar
    Jan 2012
    NJ
    Yes I understand that and that's what I wrote. I'm waiting for a new cam gear to come in so that I can re-time the motor and start it up and do a leak down test.
    2011 STi----------PTE6266--------Fully Built---------ETS--------E85
  4. #573
    Registered User sky_night's Avatar
    Apr 2014
    Flagstaff, AZ
    Man I just read through this whole build thread and it really makes me question having a rebuilt motor vs. stock. My shop says I can push a lot more HP with a built motor and my current gt35r turbo but from your thread it looks like I'd be better off sticking with stock motor and lower HP.
    I'm super bummed to read about all the issues you are having with your car. I can't believe there is nothing you can do to get some money back from that shop that screwed you so many times. If I was in your position (not that my opinion is worth much) I would be having a stern talk with them about refunding a good chunk of the labor costs. If they gave me crap I would find the nearest lawyer....
    Once again I'm new to the whole tuning thing but man it seems like they took you to the cleaners. Especially when the engine blew after 1,000 miles. I can't think of any kind of rash/hard driving that would cause that. Since they were the only ones involved in your engine build (or putting the car together) I really don't see how they can claim no responsibility in the matter. If they say it's the built motor than I would go after the company who built the motor.
    Maybe you've already looked into some of this but I wouldn't take that beating without putting up a serious fight (I don't know maybe you make enough money that it doesn't kill you too bad). As every else has said I hope nothing but the best for you on this last bout with the engine but if you haven't already would seriously look into fighting to get some money returned.
  6. #574
    Jan 2012
    NJ
    Quote Originally Posted by sky_night View Post
    I appreciate all the advice and believe me, it's hurt my pocket big time!
    My situation has a lot more to it and I've decided I want nothing to do with the shop anymore and took my problems elsewhere. It's being felt with but who knows what else needs to be done now.
  7. #575
    Registered User devyn339's Avatar
    May 2011
    berwick pa
    You should have taken it to psi proformance they do awesome work and steve is an awesome tuner
    Sent from my XT1080 using Tapatalk
  8. #576
    May 2011
    berwick pa
  9. #577
    Jan 2012
    NJ
    That's a pretty bad ass setup.
  10. #578
    May 2011
    berwick pa
    Thanks first gr to be shaved tubed and tucked
  11. #579
    Jan 2012
    NJ
    Still no good updates for me.
    Ran into some more issues and just hoping it all fixable stuff. We were able to get the car to stay on time with adjustable pulley's. Now I'm having an issue with the passenger side cam gear. Compression came back low, so we'll see where we get with the cam gear issue.
    Oil leaks are still not yet resolved. Thinking maybe some good RTV will do the trick, but we'll see.
    Otherwise. Happy Mother's Day!
  12. #580
    Jan 2012
    NJ
  13. #581
    May 2011
    berwick pa
    You're having terrible luck man ..and ps is where ever you work hiring ;-)
  14. #582
    Jan 2012
    NJ
    Quote Originally Posted by devyn339 View Post
    Yeah, you're telling me. I just can't win. I think it's time to sell and just cut my losses.
  15. #583
    May 2011
    berwick pa
    I'm in the same boat well sorta we finally got my **** squared away after three motors
  16. #584
    May 2011
    berwick pa
  17. #585
    Jan 2012
    NJ
    Yeah I wish I could say the same thing. Good luck with yours dude. Looks so badass.
