Januch09's 2011 STi Build (PTE6266) - Page 35
Page 35 of 57 FirstFirst ... 252627282930313233343536373839404142434445 ... LastLast
Results 511 to 525 of 854
This is a discussion on Januch09's 2011 STi Build (PTE6266) within the Builds forums, part of the Tech & Modifying & General Repairs category; Here's a bit of an update. Went to head games yesterday and saw the actual damage on the heads. Heads ...
  1. #511
    Registered User Januch09's Avatar
    Jan 2012
    NJ
    Heads were starved of oil due to the spun bearing and lack of oil pressure after that. Almost everything was scored up from my recollection of metal that went through the heads. Cams and buckets are ruined. Guides were crooked/bent, scoring on the heads itself, etc.
    Valves were fine, springs were fine, port was fine.
    So after a long chat with Dave at Headgames, we decided to redo the heads mostly.
    -New GSC S2 Camshafts
    -New Beehive Springs and Retainers
    -New Guides
    -New Valve Seals
    -Plus the obvious cleaning and water tank work
    Heads should be done within the day or so and shipped back to Rallispec.
    As far as the motor goes:
    -Cosworth Rings
    -OEM Heat-Treated Crank
    -Pauter X-Beam Rods
    -King Main & Rod Bearings
    -Cosworth High Performance Head Gaskets .78mm
    -OEM Engine Gasket Kit
    -Deglaze Cylinder Walls
    Still no word from PTE about the turbo. Kinda getting aggravated about that.
    Other then that, everything should be coming back together shortly.
    2011 STi----------PTE6266--------Fully Built---------ETS--------E85
  3. #512
    Registered User Agron1979's Avatar
    Jul 2013
    Man good luck with everything bro...I'm still trying my best to sell my parts, down to some little stuff, the invidia catted Downpipe, the uppipe, tial 38mm red, and the crosspipe. Almost there with my downpayment money so I got my fingers crossed. Again, good luck with everything.
  4. #513
    Jan 2012
    NJ
    Quote Originally Posted by Agron1979 View Post
    Same to you dude. Thanks
  6. #514
    Jan 2012
    NJ
    BTW, if anyone has a hookup with Pauter Rods, please let me know!
  7. #515
    Palmyra, NJ
    Is that all still out of pocket though or was it somehow linked to an incorrect build since you barely made it through break in?
  8. #516
    Jan 2012
    NJ
    All out of pocket…. No one took responsibility.
  9. #517
    Palmyra, NJ
    Quote Originally Posted by Januch09 View Post
    Now that's some bull****...
  10. #518
    Jan 2012
    NJ
    Tell me about it….
  11. #519
    Jan 2012
    NJ
    So far none can really get their hands on Pauter X-Beam rods. They are in production right now for a new batch and are going to take at least 3 weeks…sigh.
    Second choice is going to be Manley Turbo Tuff I-Beams
  12. #520
    Jan 2012
    NJ
  13. #521
    Jan 2012
    NJ
    Just got an email from Grant at PTE. The turbo was shipped out today!
    Here's what the issue was:
    "Oil feed pin was removed by someone and o-ring was changed to green air-conditioning style"
    Not exactly sure who removed that but obviously this was an issue.
    PTE covered everything and replaced the wrong O-ring and pin and also paid for shipping which is much appreciated. It did take a long time for them to respond to me, but once they finally responded, it was checked over and fixed within a day and shipped out within a few hours after.
    Also, Manley Turbo Tuff Rods w/ ARP CA625+ Bolts were ordered and should be shipped to Rallispec early next week! Turbo should be here early next week also. Heads should be at Rallispec early next week too.
    Once the turbo comes in, I'll take a trip to Rallispec and give him my turbo. i also have to drain my gas tank of the E85 and bring 5 gallons of pump gas so that we can start the car up on the break-in tune. Mikey doesn't want to break the car in on E85 which is understandable.
  14. #522
    Jan 2012
    NJ
  15. #523
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Awesome. Hope she gets back up and running fairly soon...Good luck!
  16. #524
    Jan 2012
    NJ
    Thanks dude.
  17. #525
    Jan 2012
    NJ
    Okay, so the biggest question I have for my build is..
    What new battery do I get? lmao
    Optima yellow top or red top ahahahha
    Any good suggestions anyone?
