Januch09's 2011 STi Build (PTE6266) - Page 31
Page 31 of 57 FirstFirst ... 212223242526272829303132333435363738394041 ... LastLast
Results 451 to 465 of 854
This is a discussion on Januch09's 2011 STi Build (PTE6266) within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by anpato How much boost are you running, the stock recircs are good till about 20-21psi. And Idk ...
  1. #451
    Registered User Januch09's Avatar
    Jan 2012
    NJ
    Quote Originally Posted by anpato View Post
    And Idk what setup your running making 400whp with only 21psi of boost using a stock bpv.
    Quote Originally Posted by Agron1979 View Post
    Congrats on finally getting the car back and good luck with everything in CT and don't forget to post new dyno results.....
    Thanks man!
    I just got back from The Shop CT and Mikey did an awesome job on my "break-in" tune. The drivability is fantastic! Car seems to be extremely healthy also.
    I do have one concern. The car is smokey a little bit of very light blue smoke. Yes, oil. But the oil level is fine, the car seems totally healthy. I'm thinking maybe oil is gunked up in the catback from the last motor that spun a bearing. Any input?
    2011 STi----------PTE6266--------Fully Built---------ETS--------E85
  3. #452
    Jan 2012
    NJ
    I do have one concern. The car is smoking a little bit of very light blue smoke. Yes, oil. But the oil level is fine, the car seems totally healthy. I'm thinking maybe oil is gunked up in the catback from the last motor that spun a bearing or the Crawford AOS is hooked up improperly. Any input?
  4. #453
    Jan 2012
    NJ
    Here's a couple quick shots of my setup from yesterday. THE SHOP CT
  6. #454
    Registered User i8buffalowings's Avatar
    Sep 2013
    Louisiana
    oh god... need to change pants...
  7. #455
    Registered User Agron1979's Avatar
    Jul 2013
    That's my man...he definitely knows how to hook up a rex. Thing is sweet man!!!
  8. #456
    Jan 2012
    NJ
    Quote Originally Posted by i8buffalowings View Post
    Bahahhahahaha I'll take that as a compliment....
    Thank you! It's still a work in progress.
  9. #457
    Jan 2012
    NJ
    Just went outside during sunset to take a few pics. I'm no pro at using my DLSR, nor am I a great editor, so don't judge.
  10. #458
    Registered User teddy37's Avatar
    May 2010
    Garrett County Maryland
    This is one mean sti. Very clean. This is a weird question but whats the aos mount to on rotated setups? The pitch stop?
    2011 Wrx DGM TP Stage 3
    Stink-eye mob #3737
  11. #459
    Palmyra, NJ
    Looks good man. That is a HUGE intercooler!
  12. #460
    Jan 2012
    NJ
    Quote Originally Posted by teddy37 View Post
    Dave at Rallispec made a custom bracket to make it mount to the pitch stop. It came out really good and I'm super happy with the mounting because it's the highest possible spot.
    Thanks dude, and yeah it fills up the whole front end pretty well. lol Now hopefully it performs as well as it looks! I have a lot of faith in ETS!
  13. #461
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    I love your attention to the small things, such as coating the cold side of the Turbo and painting the alternator cover. Well done sir.
  14. #462
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Great work on this build man. Looks beautiful. Can't wait to hear what the numbers are after break in!
  15. #463
    Jan 2012
    NJ
    Quote Originally Posted by A265 View Post
    It's the little things that make a difference. lol Thanks man!
    Thanks dude! So far the car made 400 on 17psi. We plan on going for 30-35psi on E85. As long as we have no limitations.
  16. #464
    Jan 2012
    NJ
    Anyone have nay issues with the front O2 sensor going bad (low voltage)? I get a code about every 50 or so miles saying: P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2). Ever since the code popped the car is running pretty ****ty and it almost feels like the old tune is back on the car. I understand a bad O2 sensor will make the car run a bit off but my whole fueling and what not seems totally different and off.
    Also, the blue smoke doesn't seem to be appearing anymore, so I'm guessing it was either gunked up oil from last motor in the mufflers, rings weren't fully set, or I'm just not seeing the smoke from where I'm sitting. From what I've read, PTE turbos have been known for the seals not working properly and letting oil pass into the exhaust side causing blue smoke. So I'll keep a good eye on it, worst case scenario, I'll contact ETS and PTE and go from there.
  17. #465
    Jan 2012
    NJ
