Januch09's 2011 STi Build (PTE6266) - Page 29
Page 29 of 57 FirstFirst ... 192021222324252627282930313233343536373839 ... LastLast
Results 421 to 435 of 854
This is a discussion on Januch09's 2011 STi Build (PTE6266) within the Builds forums, part of the Tech & Modifying & General Repairs category; New fuel fittings and lines ordered. ETS shipped out a bracket that was missing for the up-pipe and tuner will ...
  1. #421
    Registered User Januch09's Avatar
    Jan 2012
    NJ
    New fuel fittings and lines ordered. ETS shipped out a bracket that was missing for the up-pipe and tuner will be sending me a break-in tune! Seems like it's coming together.....
    I'm going to lose my mind if it's not done by this week.
    2011 STi----------PTE6266--------Fully Built---------ETS--------E85
  3. #422
    Jan 2012
    NJ
    Motor is in the car as well as turbo setup! Just need some more buttoning up and a break-in tune and I'll be putting some break-in miles on her!
  4. #423
    Jan 2012
    NJ
    Does anyone know what has to be done to make the walbro 465 fuel pump fit? It doesn't seem to fit and I'm not sure how to modify it. Any help would be nice.
  6. #424
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Quote Originally Posted by Januch09 View Post
    Supposedly, "it won't." Walbro 465 fitment - NASIOC
    .....okay, so it will? - http://forums.nasioc.com/forums/show...3&postcount=23
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
  7. #425
    Jan 2012
    NJ
    Quote Originally Posted by lokey View Post
    .....okay, so it will? - NASIOC - View Single Post - Walbro 465 fitment
    Yeah, I read both of those too lol. So it will work if I leave the bottom part off? But is that okay to leave off?
  8. #426
    Jan 2011
    Crofton, MD
    I don't like the idea myself...
    Greg
    Build Thread
  9. #427
    Jan 2012
    NJ
    I just got an email from Rallispec saying they got it, so I guess cool. I'll see how it made it work and share with everyone.
  10. #428
    Jan 2012
    NJ
    Okay so update:
    Car was running Friday. No leaks, no problems. Break-in tune needs a little adjusting so I can safely break the car in on that tune. Also found out ETS doesn't provide a bung on the down-pipe for AFR. So we are drilling a hole in the down-pipe and adding a bung so we have AFR gauge working. Other then that, that car seems to be pretty good.
    Hopefully the down-pipe gets finished tomorrow and the new tune put in and I'll go pick it up and start breaking in!
    The fun part begins....
  11. #429
    Jan 2012
    NJ
    Welp, I got the car today. Everything is good except for a couple things.
    1. Small oil leak coming from the valve cover at the bottom on the passenger side. Noticed some smoke coming from the header, stuck my hand down there and whatta ya know? It's a very tiny little leak dripping onto the header. I'm thinking the gasket got folder or ripped or didn't seal properly. The car will be going back to get that fixed ASAP!
    2. The turbo oil line was rubbing against the hotside of the turbo, so I'm going to metal zip-tie it away form that and put a rubber grommet around it so it doesn't cut through anything.
    3. The coolant line to the Crawford AOS is a little too long and is pretty close to the turbo, so I'm going to cut about an inch or two of it and get it away from the hot turbo.
    4. The fuel pump wasn't hard wired, I guess he forgot to do that. So I'll be hardwiring it when I get a chance.
    5. The electronic boost controller was replaced by the manual boost controller instead of running both which is what I wanted for "hybrid" setup. So I'll be adding the GrimmSpeed EBCS that I already have to the Grimmspeed MBCS to complete the hybrid setup. Not exactly sure how to do it, or how it works, but any input from you guys would be nice.
    6. Lastly, the tune needs some adjustments. Will be meeting up with STi Mikey some time next week for him to give me a solid break-in tune rather then him try to guess what needs to be changed with out and data or having the car in front of him. I wanna make sure the car is broken in properly and safely.
    Other then those few problems everything seems fine! Dave did an awesome job with the motor build and the fuel setup and everything else. It's pretty common for someone to forget a thing or two when your doing 100 things to a car at once. The new setup has roughly 150 miles on it and seems to be holding pretty strong. Grant it, it is only 100 mile but the drivability of the car is amazing compared to my previous builds. Overall I'm pretty satisfied as long as I can get all those things fixed in the next week. I want to tune the car in the same condition that I broke it in as. Hopefully the oil issue is fixed by next week as well as the few smaller things.
    I'll keep everyone updated with what goes on. Any input on the "Boost Controlling Hybrid Setup" is welcome!
    P.S. Pics soon to come!
  12. #430
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Jan 2012
    NJ
    Sweet! Thanks dude! Hopefully I can give it a shot today!
  14. #432
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    I want to give one cautionary warning... there is a downside to running Hybrid BCS. If plumbed properly, you will have a small vacuum leak at idle.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  15. #433
    Jan 2012
    NJ
    How so? Please explain. I'm not familiar with hybrid setup. I went with it because my tuner and builder recommended it and I heard a little better spool comes out of it.
  16. #434
    Registered User blee5192's Avatar
    Aug 2013
    Bay Area
    Got my new Exhaust today! Invidia Q300 Ti-Tips.
    Did your tips turn different color over time?
  17. #435
    Jan 2012
    NJ
    Quote Originally Posted by blee5192 View Post
    They got a bit darker from carbon build up but as soon as I polish them, they come right back.
