Ermahgerd! Ruh Roh's burgeye burld threard - Page 35
Page 35 of 48 FirstFirst ... 252627282930313233343536373839404142434445 ... LastLast
Results 511 to 525 of 716
This is a discussion on Ermahgerd! Ruh Roh's burgeye burld threard within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Mikie13 That's why you always email yourself critical documents. Or back everything up to flash drives or ...
  1. #511
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    That's why you always email yourself critical documents. Or back everything up to flash drives or external HDDs.
    A little late to the party, but use google docs or drop box. No need to send the file back and forth.
  3. #512
    Registered User Hold_Fast's Avatar
    Mar 2008
    Philly Burbs
    Quote Originally Posted by Ruh Roh View Post
    Knew you liked dat chocolate
    Karlton flares look awesome btw. much want. so stance. wow. just not practical for me now:/ maybe one day when shes a track only car or something lol
    once i get the front end appearance things done and my wheels powdercoated and on ill be looking next into coilovers for moar stancenation low and will do 2 autox days at least this sprig/summer. #SubieGoalsBrah after that thennn ill do some more powa modz. ewg, 16G, 255fuel pump, turbo inlet, tgv delete.
    Dat chocolate Thanks buddy, and let me know what events you plan on going to, I may take a trip up to your neck of the woods to try out some new areas if I have time & trailer.
    #MoarPOWAH
    ~Stan
    '04 WRB WRX Wagon (Build) - Hard Parked, AutoX Toy
    '08 WRX ~ Daily Beaten ~ '86 BMW 325es ~ "The Chump"
    "I was raised knowing there is a replacement for displacement, it's called engineering."
  4. #513
    Dec 2011
    Pottstown PA
    still gathering parts to put on in the spring, hoping to get some powdercoat samples for wheels (hyper black) and if i pick up a perrin alt shroud this weekend thatll be getting powder coated a chrome gold with the hella horn covers cant waitttttttttttttttttttt
    Marky Mark
    My bugeye build
    MinoskePhotography
  6. #514
    Dec 2011
    Pottstown PA
    went to get dinner with the Gf and noticed a pickup truck stuck in the snow in the parking lot. went over to pull him out and asked if a family could move their minivan and they said they were stuck too. got to pull out a minivan and a pickup truck out of the snow win.
    Marky Mark
    My bugeye build
    MinoskePhotography
  7. #515
    Dec 2011
    Pottstown PA
    prior to the install of my mishi rad i had an upper rad hose leak which was a hole in the hose, which i replaced with a new hose. when i installed the mishi rad i used the same oem replacement hoses and this upper rad hose was only a few months old. after install the upper rad hose started leaking where it attaches because the hose because loose because the clamp over time smooshed the rubber hose down. of course all my hose clamps i had at home were a larger size than i needed since i couldnt tighten the clamp i had installed any tighter..
    so a few days ago i went new hose clamps and why i was at it bought a new upper rad hose, OEM. ..$13ish so no big deal. installed, all good, no leaks. of course tonight it started to leak again while i let it warm up to go to work..
    when i put the clamp on i tigthened it firm enough so it wouldnt leak but soft enough where i didnt feel it was squishing the rubber down to cause the same problem as before?
    sooo question is, how do i deal with these POS hoses?
    A-get a silicone one?
    B- continue tightening it down until it full smushes down then buy a smaller hose clamp..
    C- unknown
    D-get a new wife
    getting tired of dealing with this stupid problem then having my belts squeak every derive because they have coolant on them..
    Marky Mark
    My bugeye build
    MinoskePhotography
  8. #516
    Palmyra, NJ
    Silicone hoses that are the right size.
  9. #517
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    silicone. because closest thing to boobs.
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
  10. #518
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Don't waste your money on silicone hoses. You're looking at 5-6x the cost of rubber.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  11. #519
    Jan 2011
    Maryland
    maybe some big fat t-bolt type hose clamps to spread out the pressure so they don't dig into the hose?
    pete25r's build
  12. #520
    Dec 2011
    Pottstown PA
    yea for the price of rubber and ease of installation i rather not the silicone. they do last longer(so i hear) before digging in, and look great but don't feel like spending the money on them.
    pete, i looked around and finally found bolt clamps at pepboys, went to install and they were about 1/4' too big fml. so i will be ordering smaller ones.
    Marky Mark
    My bugeye build
    MinoskePhotography
  13. #521
    Dec 2011
    Pottstown PA
    today after i wake up i shall interview for a new job, then take a bunch of engine bay bolts off, label each so i know where to put it back, go to lowes and use their nice little thread "screw in" chart thing and measure each bolt so i can then make a count of all the sizes i need to order in some goldddddd brah. **BLING BLING** t
    hen will order another front end piece tmmrw because i need it to get here to know what size holes it already has in it so i can order the rivets to attach it.
    because madJDMracecarpartsbro#illest
    next week should be going up with the gf to RT Tuning to get my Muteki sr48 open ended extended gold chrome lugs and dropping off my passenger side skirt for repaint -__-
    thennn after that going to drop off my wheels for powdercoating (hyper black) and perrin alt shroud (gold chrome) bling bling ka ching ching $$$$ **** $$$$
    thenn i move at the end of this month, bday on the 10th (getting car parts ), install all dat stuff i get and the new hella driving lights to replace the stock fogs (stock fogs will go on my winter bumper for next year) then be fully in sprig/summer mode!!!!
    Marky Mark
    My bugeye build
    MinoskePhotography
  14. #522
    Palmyra, NJ
    Wut?
  15. #523
    Wut?
    It was 4AM and Mark posted...he was wasted
    Resident Tuner @ WTF Tuning
  16. #524
    Mar 2008
    Philly Burbs
    This. Though I do appreciate his drunken ramblings about bling and such.
    Sent from my HTC One X using Tapatalk 2
    ~Stan
  17. #525
    Dec 2011
    Pottstown PA
    -__-
    i was saying my plans. was at work, not drunk :/
    Marky Mark
    My bugeye build
    MinoskePhotography
