Ermahgerd! Ruh Roh's burgeye burld threard - Page 27
Page 27 of 48 FirstFirst ... 171819202122232425262728293031323334353637 ... LastLast
Results 391 to 405 of 716
This is a discussion on Ermahgerd! Ruh Roh's burgeye burld threard within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Ruh Roh some how managed to cut m finger and it wouldnt stop for like 5 mins. ...
  1. #391
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    Quote Originally Posted by Ruh Roh View Post
    Mark if this didn't happen you would not have been working on your car.
    glad to here everything else is working out.
    I wish my car would run like a raped ape. It usually runs like an upset orangutan.
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
  3. #392
    Dec 2011
    Pottstown PA
    Quote Originally Posted by pete25r View Post
    haha thanks! yea after fixing some boosts leaks with Zachs air leak tester i thought it was fine, couldnt hear anything. Did some logs and boost was around 15.5 psi then went and got her smoke leak tested, they said they tightened a clamp, did some logs and peak is almost 17psi now lol
    Marky Mark
    My bugeye build
    MinoskePhotography
  4. #393
    Dec 2011
    Pottstown PA
    so uhh continuing the morette work here are some updates
    getting ready for teh paint
    painting lights
    painted middle section black, psm grimmspeed paint will be here today and hopeuflly have them all painted tonight
    stuff i use for my fogs, and all that. works great each time, will have to get more cans of
    so this big crack i had i needed some plastic to fill in and patch up. this lid seemed to work from a zip tie containter
    too hard to cut with scissors or it wouldve cracked, cutting with a knife or razor blade was too hard so i heated up a razor blade with my little torch and then when the blade was hot sliced through the plastic like butter. jeenyus.
    good nuff'
    the housing curves..
    heat it up and use some redneck engineuity to bend er right up
    fixedish
    jb weld that in there and good to go. just had to drill a hole when it dried for the bolt to go in.
    dry fit
    done
    instead of watching paint dry i decided to do some organizing in my time.
    also got this bad boy at CVS
    been driving around like this because i didnt feel like undoing the wiring to take the lights off until i can get my covers painted. hopefully will be all done tomorrow night
    Marky Mark
    My bugeye build
    MinoskePhotography
  5. #394
    Palmyra, NJ
    Nice Mark. You're a pretty resourceful SOB, aren't ya?
  6. #395
    Dec 2011
    Pottstown PA
    i try :P
    Marky Mark
    My bugeye build
    MinoskePhotography
  7. #396
    Jan 2012
    Philly Area
    I like it!
    - Will
  8. #397
    Dec 2011
    Pottstown PA
    I like it!
    lol well theyre not quite done yet Willenium. Oh BTW i had the last homebrew of the few you gave me last night in my bugeye mafia stein
    Marky Mark
    My bugeye build
    MinoskePhotography
  9. #398
    Jan 2012
    Philly Area
    Nice! Glad to know it is being consumed during car-work.
    - Will
  10. #399
    Dec 2011
    Pottstown PA
    haha of course! prob got some paint fumes in it but tasted great as usual!
    Marky Mark
    My bugeye build
    MinoskePhotography
  11. #400
    Dec 2011
    Pottstown PA
    well all done. when i went to paint the silver i taped off the black section, painted silver, removed tape and it left behind a lot of adhesive. rubbing alcohol, soapy water-didnt seem to do the trick. had to use goo gone fml. the black got a little messed up on on spot from rubbing to hard. the paint was then sticky after... it has dried a little more but its not perfect so im not fully content. the silver/black tape line is also not perfect. i will get the covers repainted, maybe sooner than i think if rock chips the black and it peels or who knows. but theyre good for now until they get messed up.
    update-still tuning with matty, hopefully be done by the end of aug.
    fog lights and low beams
    fogs and high beams. i can also run only fog lights
    Marky Mark
    My bugeye build
    MinoskePhotography
  12. #401
    Jan 2011
    Maryland
    looks good, but these are not the droids you are looking for...
    pete25r's build
  13. #402
    Registered User Subaru-Mopar-Luv's Avatar
    Nov 2012
    Saskatchewan, Canada
    That's pretty much exactly what I want my front end to look like! Glad to see you finally found yourself some Morettes! Looks fantastic!
    Speed never killed anyone, suddenly becoming stationary, that's what gets you. -Jeremy Clarkson
    Bugeye Mafia Member #419
  14. #403
    Dec 2011
    Pottstown PA
    hahah thanks!
    yup finally got a pair since i missed out on the ones you got :P
    Marky Mark
    My bugeye build
    MinoskePhotography
  15. #404
    Dec 2011
    Pottstown PA
    thanks to dez for photochop. hyper black...hm. thoughts?
    Marky Mark
    My bugeye build
    MinoskePhotography
  16. #405
    slow no mo' ! Shoopster's Avatar
    Apr 2013
    Montreal
    hahah thanks! yup finally got a pair...
    -Stephanie 2004 WRB WRX | Blobeye Syndicate Member #104
    "I can't see the Shoopster from here; I'll wait for you outside."
    Shoopsterbuild 2.0: Better than it was before. Better, stronger, faster. And such JDM, yo.
