Ermahgerd! Ruh Roh's burgeye burld threard - Page 20
Page 20 of 48 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 286 to 300 of 716
This is a discussion on Ermahgerd! Ruh Roh's burgeye burld threard within the Builds forums, part of the Tech & Modifying & General Repairs category; ill see if i can borrow my friends tactrix and computer otherwise have to buy one and use my moms ...
  1. #286
    Dec 2011
    Pottstown PA
    ill see if i can borrow my friends tactrix and computer otherwise have to buy one and use my moms pc
    Marky Mark
    My bugeye build
    MinoskePhotography
  3. #287
    May 2010
    Pittsburgh, PA
    I wouldn't bother. Just get the MBC and EBCS and let's get to tuning...
    I agree. Get everything squared away as is first and then add the fueling changes. If you were getting a dyno tune or don't have access to a small change later, I would advise doing it all before hand.
    2011 STi Build Log
  4. #288
    Dec 2011
    Pottstown PA
    i dont have a boost or AFR/WB02 gauge as well
    Marky Mark
    My bugeye build
    MinoskePhotography
  6. #289
    Quote Originally Posted by Ruh Roh
    Boost can be read from logs, and no WBO2 isn't ideal, but for S2, we can likely have you close. Worse comes to worse, you get the WBO2 later and we touch up OLF at that time.
    Resident Tuner @ WTF Tuning
  7. #290
    Dec 2011
    Pottstown PA
    oh okk.
    Marky Mark
    My bugeye build
    MinoskePhotography
  8. #291
    Dec 2011
    Pottstown PA
    so it looks like thats the plan matty since i want the best for my little bugeye.. going to borrow a tactrix from a friend, use moms little netbook thing and download ECUflash and romraider, probably order a WB02 for safety sake and can later get a boost gauge...or should i get boost as well? and order a grimspeed EBCS since i already have the hallman rx and then can run hybrid boost control.
    Marky Mark
    My bugeye build
    MinoskePhotography
  9. #292
    May 2010
    Pittsburgh, PA
    I am big on wb02s. It is easy to miss something wrong with the car otherwise. I would move that up in priorities, personally.
    2011 STi Build Log
  10. #293
    Dec 2011
    Pottstown PA
    what about boost? i think we posted at weird times so u just may have missed my last post lol
    Marky Mark
    My bugeye build
    MinoskePhotography
  11. #294
    May 2010
    Pittsburgh, PA
    Normally if your boost gauge points out anything wrong... It is too late. Your ecu will be a more reliable source anyhow.
    Wb02 I use a lot actually while driving. It narrows down anything funny feeling to an ignition issue or detonation issue. Just my opinion.
    2011 STi Build Log
  12. #295
    WBO2, GM EBCS ($70 cheaper), and get the boost gauge whenever you can.
  13. #296
    Dec 2011
    Pottstown PA
    soo didnt get to the spark plugs this week. maybe next weekend. will use stock heat NGK iridiums.
    had a little leak where DP and catback mate. so unbolted, brushed as much rust as i could off, added the grimmspeed x2 thick gasket since i didnt have any gasket in there, tightened up, stil the same amount of leak -__- its just like a tiny pin hole but i want it to not leak...sooo idk may get some of that exhaust stuff that can seal it..not quite sure yet. heres a pic before cleaning
    i plan on ordering a WB02 gauge, perhaps AEM UEGO or innovate lc-1 in red but not sure and not sure how ill mount it yet. would just like to have so i can install and then get a tune very soon. so should be ordering that this week. and hopefully getting a tune soon also have to order the GS EBCS so i can run hybrid with the hallman rx
    Marky Mark
    My bugeye build
    MinoskePhotography
  14. #297
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    I have a hallman pro (not the rx) that I will sell you for $40 shipped if you want it. I want to get the RX.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
  15. #298
    Dec 2011
    Pottstown PA
    i already have one i forget which it is though, bought it used so not looking for that. need EBCS was looking at the GM one
    Marky Mark
    My bugeye build
    MinoskePhotography
  16. #299
    Dec 2011
    Pottstown PA
    Marky Mark
    My bugeye build
    MinoskePhotography
  17. #300
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    we must me listening to the same advice Mark.
    I've got a WBO2 waiting to be installed, need bung welded on, and have plans on a GM solenoid.
    I had no gasket on my down to mid pipe joint either. Well previous owner did use some of that copper gasket crap. Mine wasn't half as rusty as your's though.
    If your mom's netbook deal doesn't work out for you I've got a netbook and tactrix and can meet you halfway.
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
