Maus bulids a Racecar because Racecar Build Thread - Page 8
Page 8 of 18 FirstFirst 1234567891011121314151617 ... LastLast
Results 106 to 120 of 266
This is a discussion on Maus bulids a Racecar because Racecar Build Thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by maus I do have a WB02. Do you think a 73mm maf housing is too big? No. ...
  1. #106
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by maus View Post
    I do have a WB02.
    No. Incidentally that's also what I have.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  3. #107
    May 2010
    Pittsburgh, PA
    I do have a WB02.
    I would just get the stock one. You'll lose resolution down low, where it is already picky as is. It's an exponential response, and I doubt you are hitting 4.5V now. Do a WOT pull logging MAF voltage. If you are above 4.8, I'd be concerned.
    2011 STi Build Log
  4. #108
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    You mean logging over 4.8 on the stock maf? What would a higher number indicate?
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
  6. #109
    May 2010
    Pittsburgh, PA
    Yeah. The MAF goes up to 5V. The ECU will only interpret it up to 5V I believe. Hence, people trick the MAF sensor by increasing the housing size. Hence, if you exceed that 5V... you need a larger diameter MAF housing or to convert to speed density. The MAF housing isn't really used to allow more air in... it's to allow the stock MAF sensor to decipher additional air. You basically have to apply a multiplier to your whole MAF scaling. While this allows higher amounts of air to be interpreted by the car... you squish the already cramped and touchy scaling down lower. I believe the difference between stock and 73mm diameter MAF housings in intake restriction of the stock intake is nominal when compared to the inlet plumbing... Either way, its worth noting.
    I guess in a nutshell, people upgrade the housing size because they run out of MAFV. If you are okay with the stock sized housing, stay with it to maintain your best resolution possible - similar to why you shouldn't oversize injectors normally. If you are going to run out of it, which I HIGHLY doubt you will without a significantly larger turbo, then you'll want to get the larger housing.
    2011 STi Build Log
  7. #110
    Mar 2012
    Palm Beach, FL
    Gotcha. Makes sense.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  8. #111
    May 2010
    Pittsburgh, PA
    Yeah. Another small difference is that the stock sized MAF housing will at least work if you put it on, right out of the garage. I'd apply a scalar to the tune before even starting it with the 73mm.
    Talk to your tuner about it - he'll probably have a preference.
    2011 STi Build Log
  9. #112
    Mar 2012
    Palm Beach, FL
    Will do. Don't know who I'm going to go with for etuning this time yet.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  10. #113
    May 2010
    Pittsburgh, PA
    Be prepared for quite a few iterations this time around. Equal Length headers really change your boost control tables, a lot. Between those and my EWG... it took me a TON of pulls to get my boost control dialed in. It isn't just your target boost/wgdc anymore =(.
    2011 STi Build Log
  11. #114
    Mar 2012
    Palm Beach, FL
    Things I hate. Pulls for Logging
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  12. #115
    May 2010
    Pittsburgh, PA
    If you use open source, make sure you set up stand alone logging. Leaving a laptop on is annoying.
    The recent firmware update kinda fouled mine up. It seems like I need to leave it connected to the laptop until after I plug it in now. It was supposed to allow time stamps on the logs (which it does)... but now I can't log unless I plug it in with my laptop connected. The thing has power even when the cars off, so it is only an issue when I actually pull the cable at least.
    2011 STi Build Log
  13. #116
    Mar 2012
    Palm Beach, FL
    No, I've thought about selling the AP and going to open source but I like to use my AP as a feedback knock gauge.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  14. #117
    Palmyra, NJ
    Things I love. Pulls for Flogging
    fixored.
  15. #118
    Registered User sjcurtis's Avatar
    Sep 2010
    Selma, Alabama
    Nice racekor!!!!
  16. #119
    zax
    zax is offline
    Nov 2008
    I approve this thread but mostly because of the flogging.
    Facebook me here
  17. #120
    Registered User etnpnys's Avatar
    Dec 2011
    Olympia, WA
    Subscribed. This thread has awesomesauce.
    "Ah, it is the fault of our science that it wants to explain all; and if it explain not, then it says there is nothing to explain."
    -Van Helsing, from Bram Stoker's ​Dracula
