Maus bulids a Racecar because Racecar Build Thread - Page 7
Page 7 of 18 FirstFirst 1234567891011121314151617 ... LastLast
Results 91 to 105 of 266
This is a discussion on Maus bulids a Racecar because Racecar Build Thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Just get some CE28's...
  1. #91
    Registered User Terminal Kuz's Avatar
    Aug 2012
    SoCal
    2005 WRX (Silver) SoCal Subie
    Blobeye Syndicate #1093
    http://www.clubwrx.net/forums/builds...al-05-wrx.html - Build Thread
    http://www.flickr.com/photos/34009765@N06/ - For whatever pics i take.
    Mikie13-Spend money on hookers and blow. That's a better intake.
  3. #92
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    Quote Originally Posted by michaelwfox View Post
    What about PF01s?
    Sent from my Nexus 7 using Tapatalk 2
    Do not come in 5x100 in 17x9.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
  4. #93
    Mar 2012
    Palm Beach, FL
    Quote Originally Posted by Terminal Kuz View Post
    YOLO SWAG
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  6. #94
    Mar 2012
    Palm Beach, FL
    Just bought some used Perrin EL Headers. Going to get a EBCS and an intake and retune. Not sure if I am going to upgrade the injectors yet :/
    Also I am pretty sure I am going to go with the Rota Titans.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  7. #95
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by maus View Post
    You should upgrade the injectors at this point.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  8. #96
    Registered User Ampliified's Avatar
    May 2012
    Warren Twp, NJ
    Y u get EL headers?
    Y u no lik subie rumble?
    2012 DGM WRX - Stage Two 93 - Stink Eye Mob #908
    The Epic Life of Emily the WRX
  9. #97
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by Ampliified View Post
    Y u get EL headers?
    EL headers are vastly superior to the stock uel headers.
    Sent from my Nexus 7 using Tapatalk HD
    Facebook me here
  10. #98
    May 2010
    Pittsburgh, PA
    I'd be more concerned about getting a wideband and keeping an eye on it.
    Unless the tuner pushes him under 11AFR, I wouldn't expect over 90% duty cycle. That being said, its not a bad upgrade regardless. From my reading, I'd jump all the way up to ID1000s. While I understand the value in injector matching... the quality of the ID1000s is fantastic compared to other injectors, even at the lower output from what I have seen.
    2011 STi Build Log
  11. #99
    zax
    zax is offline
    Nov 2008
    He already has a wideband
    Facebook me here
  12. #100
    May 2010
    Pittsburgh, PA
    Missed that. My bad. I'd plan on injectors, as you suggested, regardless in the future. While the ones he has I think will be fine for now, he'll need them for any further upgrades. Also, it makes tuning a bit easier/safer when you have the headroom to calibrate the MAF safely (more of an issue if he did a turbo swap or something drastic).
    2011 STi Build Log
  13. #101
    Mar 2012
    Palm Beach, FL
    I don't plan on swapping the turbo. I'm actually planning on just running the ELH, ebcs and intake. No EWG. You think I'll run out of headroom on the injectors? What size injectors would you recommend going too? 750s?
    Brandon you have EL Headers right? What are you IDCs and are you on stock injectors? I don't believe the stock STI injectors are any bigger than the WRX injectors.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  14. #102
    May 2010
    Pittsburgh, PA
    I think you'll be okay as is, personally. Unless my piston rings are all cracked and I'm way down on power from what I should be... In which case you are screwed, haha.
    My IDCs are about 95% on a full throttle pull in cold weather. After I do my TGV deletes and hard inlet, I'm considering them a priority. This is a run where I was running a bit rich (around 10.9 or so - I normally aim for 11.1 or 11.2):
    Keep in mind, after about 5k RPM or so, the IDCs flatten off quickly with that stock snail.
    Your experience may differ. My car is kinda weird I've found for whatever reason. You'll just have to see.
    2011 STi Build Log
  15. #103
    Mar 2012
    Palm Beach, FL
    Thanks Brandon.
    I'm also hesitant on an intake. I'm worried my IATs are going to be much higher with an intake than without one and whatever intake I get the gains would be minimal because of this. It's hot and humid as fak down here right now
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  16. #104
    May 2010
    Pittsburgh, PA
    Thanks Brandon.
    I run a KSTech CAI. I'm not thrilled with it - the fitment was a bit off. I found slightly higher IDCs afterwards, however, which is a positive indication it helped.
    Keep in mind, even in florida, the air under the car will be colder than the air higher up. However, when it rains there, it pours. I had issues with my CAI picking up water after a car wash and messing with the MAF as soon as I hit boost. I had to get a filter sock to prevent it (I believe zax had a similar issue, actually). It would happen during heavy rain as well. If you go with a CAI... get the water repellent sock.
    If you have a wideband and don't mind doing the tuning (or having it done, in your case), I'd give the nod to either a CAI or a SRI. Personally, I'd say CAI. The only reason I normally advise not getting an intake is due to people not running a wb02. Given the price of the intake, compared to other upgrades at your point, you'd be kinda silly not to.
    Get the stock size MAF housing if you don't want a turbo swap. Even if you are hitting 4.5V, the difference between 4.5V and 5V is a huuuuge difference.
    2011 STi Build Log
  17. #105
    Mar 2012
    Palm Beach, FL
    I do have a WB02.
    Do you think a 73mm maf housing is too big?
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
