Maus bulids a Racecar because Racecar Build Thread - Page 17
Page 17 of 18 FirstFirst ... 789101112131415161718 LastLast
Results 241 to 255 of 266
This is a discussion on Maus bulids a Racecar because Racecar Build Thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by zax However, failsafe fueling tables generally do run very lean mixtures; actually it's exactly 10:1 on my ...
  1. #241
    Quote Originally Posted by zax
    However, failsafe fueling tables generally do run very lean mixtures; actually it's exactly 10:1 on my map. I'm not saying that it's not possible, but I was under the impression that when the ECU resorts to failsafe OL tables, the boost is also pulled and the car should be running wastegate pressure. Then again, I know nearly nothing about the new CANbus ECUs, so hopefully Heide will make his way in here.
    10:1 is rich, not lean
    Send me your map to my email, Matt...
    Resident Tuner @ WTF Tuning
  3. #242
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Thanks for the correction. Rich obviously. Something I'm not.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  4. #243
    Something you are is tired...go the hell to bed
  6. #244
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Where is the header
    Lead Wrench @ WTF Tuning, LLC
  7. #245
    May 2010
    Pittsburgh, PA
    The cars will resort to a failsafe fueling & timing map if needed... I'd assume they run pretty rich stock. I think I normally set them the same, to be honest. I will start setting them to be a bit richer eventually, as it is a good idea.
    ...And yup... a lot of things tell the ECU to run wastegate boost. Overboost being the main culprit. I believe running your solenoid above 100% is another quick & easy way. I bet most CELs that aren't emissions related cause boost cuts.
    Maus, sounds like you hit the nail on the head with the coolant issue. I'm not familiar with every CEL that causes the car to go to limp mode... but that could have been your issue. I'd take it easy for a few days and make sure everything is good to go under normal driving.
    2011 STi Build Log
  8. #246
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    I've since driven the car a few hundred miles and no problem, no loss of coolant. Things seem good.
    Bo, header will be here on Thursday thanks.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
  9. #247
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by maus View Post
    Cool. And again, stop worrying about heat sink issues with the intake. You are being a woman and it'll be fine. It's aluminum. It's pulling in air from lower than the stock intake. Just be prepared for the (rather significant) MAF scaling with that bugger.
    2011 STi Build Log
  10. #248
    Dec 2004
    Medford, Oregon
    Werd
  11. #249
    Dec 2004
    Medford, Oregon
    If you are scared of heat sink ill cerakote the intake tube too. Don't be a sissy.. You need an intake on a 3G at stage 2 levels
  12. #250
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by T0rque View Post
    When's the last time aluminum has created heat sink issues? I use it in the oven so I don't even need gloves to pull my pizza/sammich out after I cook it.
    ...If his intake isn't aluminum, my point is mute. In all fairness though, it probably has less thermal mass than the plastic the stock intake is made of.
    2011 STi Build Log
  13. #251
    Dec 2004
    Medford, Oregon
    It doesn't, but if he wants it even better than normal he can cerakote it. I do it to mine..
  14. #252
    Dec 2004
    Medford, Oregon
    The plastic intake is a ****in joke
  15. #253
    Dec 2004
    Medford, Oregon
    Where da heada
  16. #254
    slow no mo' ! Shoopster's Avatar
    Apr 2013
    Montreal
    (speaking of which...)
    Where da heada
    Inquiring minds wanna know!
    -Stephanie 2004 WRB WRX | Blobeye Syndicate Member #104
    "I can't see the Shoopster from here; I'll wait for you outside."
    Shoopsterbuild 2.0: Better than it was before. Better, stronger, faster. And such JDM, yo.
  17. #255
    Mar 2012
    Palm Beach, FL
    UPDATE
    Bought some new wheels because my stock tires are closed to shot. Work CR Ultimates 17x9 +38
    Still need to order tires.
    On another note while changing my oil this weekend I noticed that there was all sorts of nasty **** spewed on to the front driver wheel, back of the brake caliper, axle, and parts of the frame. Looks like a ****ed up CV boot. Car will be going into the dealer this week, I hope the warranty it as I don't think you can change just the CV boot.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
