Maus bulids a Racecar because Racecar Build Thread - Page 16
Page 16 of 18 FirstFirst ... 6789101112131415161718 LastLast
Results 226 to 240 of 266
This is a discussion on Maus bulids a Racecar because Racecar Build Thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by maus So I've been noticing abnormal AF learnings the last week or so. Today it hit a ...
  1. #226
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by maus View Post
    So I've been noticing abnormal AF learnings the last week or so. Today it hit a high of -10 in the C Range and -4.9 in the A Range. Took some time at lunch to try and diagnose. Noticed there was a light film on the bottom port of my aos. Removed the line and reattached. AF Learning A started learning way down at idle back to like -1. C range during my short trip back to work (3/4 of a mile) learned down to -4.5. I'm still going to boost leak check the car this weekend but I'll but some miles on my car and continue to monitor. I think I have fixed that issue though, hopefully.
    Could be. Just keep an eye on it I'd say. Especially in the low load/rpm area, I wouldn't be surprised to see some A/F Learning. Idle is pretty picky when you are aiming for 14.7 on the dot. In the higher load/rpm ranges, it should stabilize and your values should be lower. The C range, I am assuming, is your higher load/rpm range. I know in OS, we have both ranges (AFL A/B/C/D) and "factors/components" (AFL 1/2/3/4). I believe in OS, you want AFL #1 (AFL #3 is due to the rear o2 readings for example), regardless of what range/letter.
    2011 STi Build Log
  3. #227
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    Accessport Values correspond to this Brandon:
    0 - <5.6 g/s = "A" Range
    5.6 - <10 g/s = "B" Range
    10 - <50 g/s = "C" Range
    50+ g/s = "D" Range
    I can never populate the D Range, Zax tells me it would be best to try and populate it on hills and stuff but Florida is flatter than a 12 year old.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
  4. #228
    Mar 2012
    Palm Beach, FL
    Also the bottom port that I fixed the hose on leads back to the inlet, so I'm 99% sure/hopeful that it is it.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  6. #229
    Mar 2012
    Palm Beach, FL
    OP has had problems with his car the last few days. OP considering not going beyond current parts that are already installed.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  7. #230
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    OP is a pussay
    Truf.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  8. #231
    May 2010
    Pittsburgh, PA
    I believe the D range is the only range carried over into open loop fueling. Some guys actually choose to disable it to prevent goofy learned values screwing things up. Once you are WOT, fueling values are normally pretty close. I'll play around with it some more once I get my fuel stumble worked out.
    Truf.
    Agreed with zax. Although, OP is too stupid to install an intake, so it may not be a bad idea.
    2011 STi Build Log
  9. #232
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    2007 Outback 3.0R wagon
  10. #233
    Mar 2012
    Palm Beach, FL
    OP ran low on coolant, Car ran 10.0 AFRS, Car had no power, Coolant temp gauge spiked up, OP Panicked.
    OP took overflow cap off, and added coolant. Coolant was bubbling for a good few minutes then started pouring out of the overflow. Drove the car, car hit target AFRs at WOT and felt like normal. Still debating what to do.
    Notes: I had a leak from the coolant line on the AOS that I fixed earlier this week, and I also added coolant to the tank because it was really low. Summary, I just think I needed to burp it.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  11. #234
    Mar 2012
    Palm Beach, FL
    Also I know how to install a intake, I said I dont know if I want to because of heatsoak.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  12. #235
    Jul 2012
    Rocky Top
    Get a box with the short ram and reflective tape, run a k&n filter on stock intake, modify stock intake, run a cold air.
    Run meth or reflective tape on tmic. That big tmic is probably efficient enough that it would negate any hot air coming in through the intake and you wouldnt see higher temps than normal. Just a thought.
    Or just dont get an intake and save the money. (richest option haha)
  13. #236
    Quote Originally Posted by wreckingball man
    An intake is absolutely worth it at his level, and should be purchased. It's holding him back quite a bit (especially when he installs his ID1000s).
    The increased cooling of the TMIC won't make a damn of difference, since IAT (in stock form) is monitored at the MAF sensor. By having an unshielded filter element (and not relocating IAT), you're doing yourself a disservice.
    Resident Tuner @ WTF Tuning
  14. #237
    Palmyra, NJ
    Should change the title of this thread to "Maus builds his ******."
  15. #238
    Dec 2011
    Pottstown PA
    Next install: tampon.
    Marky Mark
    My bugeye build
    MinoskePhotography
  16. #239
    Mar 2012
    Palm Beach, FL
    I'm still confused, could the coolant sensor pick up that something was wrong and throw the car into some type of safe mode where it would run 10.0 afrs and have almost no power?
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  17. #240
    zax
    zax is offline
    Nov 2008
    I don't think ICT can throw the car into failsafe fueling... that's generally reserved for low IAM and the like.
    However, failsafe fueling tables generally do run very rich mixtures; actually it's exactly 10:1 on my map. I'm not saying that it's not possible, but I was under the impression that when the ECU resorts to failsafe OL tables, the boost is also pulled and the car should be running wastegate pressure. Then again, I know nearly nothing about the new CANbus ECUs, so hopefully Heide will make his way in here.
    Facebook me here
