Maus bulids a Racecar because Racecar Build Thread - Page 10
Page 10 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 136 to 150 of 266
This is a discussion on Maus bulids a Racecar because Racecar Build Thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by 99pgpgt Wrapping holds moisture... That's why I don't wrap. Plain and simple. I ceramic coat the inside ...
  1. #136
    Quote Originally Posted by 99pgpgt
    I ceramic coat the inside and outside of headers.
    That's why you seal it, or buy a wrap that doesn't need sealant.
    Wrap insulates against airflow, where coating doesn't.
    Again, pros/cons...
    Resident Tuner @ WTF Tuning
  3. #137
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    Wrap them before you put them on (wrap the individual runners, don't be lazy). Also, while they're not on the car (and before you wrap), tap them for EGT...
    For injectors, ID1000s
    Yep, will be wrapping them individually. It's cheaper than Ceramic coating so I'll go that route.
    Definitely going to go with a ID1000s and going to go one step colder plugs.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
  4. #138
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Both have their pros/cons. I prefer wrapping.
    Give me a con to cerakote.
    Lead Wrench @ WTF Tuning, LLC
  6. #139
    Mar 2012
    Palm Beach, FL
    Quote Originally Posted by T0rque View Post
    Price! -_-
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  7. #140
    Palmyra, NJ
    Only person I trust to do it is Teh Bosef and dat sexy ass is millions of miles away
  8. #141
    May 2010
    Pittsburgh, PA
    As per a suggestion torque gave me a while ago... Look into using CV clamps and the little tool you use with them to help hold the wrap on. They work much better than the traditional "stainless steel" zips.
    Good luck. My Invidia EL were welded in between the runners at a few points so I had to wrap them together. The wrapping was the worst part of the install.... Along with slicing my finger open on a heat shield (through the nail). Wear gloves when breaking bolts loose down there.
    You running the stock wastegate?
    2011 STi Build Log
  9. #142
    Mar 2012
    Palm Beach, FL
    Looking to get a 38MM wastegate and uppipe.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  10. #143
    Dec 2004
    Medford, Oregon
    PM'd back
  11. #144
    Mar 2012
    Palm Beach, FL
    PM'd back
    Now I have to find a tape measure -_-
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  12. #145
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by maus View Post
    Cool. Just make sure it'll fit with your down pipe.
    I bet you can find some used ones. I'd aim for a 1bar/14psi spring combo. Since I got mine new, it came with all of the various springs. You combine whatever springs you need to get your preload. I'd just touch base with your tuner regarding it - he may have preferences.
    2011 STi Build Log
  13. #146
    Dec 2004
    Medford, Oregon
    Use the one you measure your peen with.. You just have to add up all the 3".. Basic math
  14. #147
    Mar 2012
    Palm Beach, FL
    Yep. How hard is it to change the springs with the EWG on the car?
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  15. #148
    Mar 2012
    Palm Beach, FL
    I can't multiply that high.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
  16. #149
    May 2010
    Pittsburgh, PA
    I would NOT recommend it. It was a pain to change them off the car to be honest. 14psi is a lot tougher than you realize, haha. I'd put it somewhere between impossible and extremely miserable, even after a six pack.
    The EWG is in a tight area. It's probably my most hated place to work on as well. Fighting with the v-bands on my 44mm is not fun at all.
    2011 STi Build Log
  17. #150
    Dec 2004
    Medford, Oregon
    Measure it yet?
