You can't just slap a turbo on a NA motor. 1.) The compression ratio is much higher for the NA motor 2.) The pistons, rods, and cylinder sidewalls are stronger on the WRX for turbo duty 3.) The ECU isn't suitable for turbocharging... you'll need a WRX ECU or go standalone 4.) You could get a bugeye wrx for the cost of 1-3
LinkBack URL
About LinkBacks
