Go to my build thread it's all there.
Before you bolt the rear brackets on male sure you have a good tool to cleanly cut the rear heat shield. Also grind the rear knuckle. The KNS brake adapter does not fit correctly without grinding the nuckle.
Did you break the calipers apart or leave them as a unit? If you busted them apart make sure he doesn't bead blast the area where the calipers mount together.
LinkBack URL
About LinkBacks
