08wrx starts then shuts itself off..
Results 1 to 15 of 27
This is a discussion on 08wrx starts then shuts itself off.. within the Builds forums, part of the Tech & Modifying & General Repairs category; I took out the stock turbo, exhaust and air intake. I replaced the turbo with a AMR CXR550 for the ...
    Jun 2012
    POINT PLEASANT, NJ
    I took out the stock turbo, exhaust and air intake. I replaced the turbo with a AMR CXR550 for the 2.5L engine. I put on the Agency Power Cat-Back Exhaust and AP Cold Air-Intake. The installation took all of 4 hours.. Removing it however took us about 6 hours. I also installed a Cobb Tuning Access Port. I tried to start it up and after a second it goes off.. For that split second it sounded amazing... I tried un-installing the programmer just to see if that would do anything but as of 10pm last night alaskan time it is still not running.
    I am supposed to get on the ferry in a week and drive from Kodiak, AK to Point Pleasant, NJ!!
    Please help me! My name is Mike.
    KCCO
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Actually. Something similar happened to me the first time I flashed Stage 2. Try resetting the ECU by pulling the battery leads and stepping on the brake pedal for 20 seconds. Then, reconnect the leads, and attempt to start the car.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jun 2012
    POINT PLEASANT, NJ
    Thank YOU. I will give that a shot.
    Registered User xFalleNx's Avatar
    Nov 2010
    Voorhees, NJ
    Cobb's tune won't work with the aftermarket turbo.
    You need many more supporting mods to run a different turbo.
    To get it to run properly, you either have to:
    A) put the stock turbo back on
    B) spend more money on supporting mods and a pro-tune
    --Anthony 2011 DGM WRX stg2+sf intake WTFtuned ¯\_(ツ)_/¯
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    You're going to blow your motor using that turbo without a protune.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    Jun 2012
    POINT PLEASANT, NJ
    Where do I get a Pro-Tune? The current one that i have wont work?
    Nov 2010
    Voorhees, NJ
    Cobb's maps aren't deigned to work with aftermarket turbos.
    You'd need to find a local tuner and have it pro tuned. You'll also need more parts to successfully fun that turbo swap.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Jan 2012
    Philly Area
    As mentioned in your other thread, which is for the same issue: My 08 wrx won't start please help
    You're going to need more supporting mods to work with the aftermarket turbo. Even if you reset the ecu or figure out where there may be a vacuum leak from the install, and somehow it starts running, it is not going to be running correctly. Anthony and Maus are correct, you're better off putting the stock turbo back on until you learn what else you need to do and get yourself set up to do it.
    - Will
    Jun 2012
    POINT PLEASANT, NJ
    Damn.. Alright Thanks.
    Nov 2010
    Voorhees, NJ
    Idk about Alaska, but you should try to talk to a tuner that's local, if there are any, and discuss with them what you'd like to do, and they'll help you take the right path there.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    You don't have a down pipe? That turbo is doing you no good if that is the case. And normally people make their cars MORE reliable before going on long trips, not the opposite.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    zax
    zax is offline
    Nov 2008
    These guys are right, man. That turbo flows 52 lbs/min (nearly DOUBLE the flow of the TD04-19T). Without fueling modifications -- injectors and fuel pump -- you will undoubtedly run lean. Furthermore, without the tune, you will likely blow your motor.
    Facebook me here
    Jun 2012
    POINT PLEASANT, NJ
    Well there is no Kodiak Subaru guys on the island. If I can at least get it to run I'll be ok because there are some people in Anchorage which is where ill be getting off the ferry.
    Jun 2012
    POINT PLEASANT, NJ
    I have a downpipe.. Is the car still good if i just put the stock turbo back in? Keep the new programmer and air intake and exhaust on?
    Nov 2010
    Voorhees, NJ
    Yea, you'll be ok if you put the stock turbo back on for now, until you get get access to the other aftermarket parts you'll need and a local tuner.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
