Zax Bugeye "Shaggin' wagon" Build thread - Page 28
Page 28 of 37 FirstFirst ... 1819202122232425262728293031323334353637 LastLast
Results 406 to 420 of 543
This is a discussion on Zax Bugeye "Shaggin' wagon" Build thread within the Builds forums, part of the Tech & Modifying & General Repairs category; dem wheelz doe....
  1. #406
    Dec 2011
    Pottstown PA
    dem wheelz doe.
    Marky Mark
    My bugeye build
    MinoskePhotography
  3. #407
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Ruh Roh View Post
    dem wheelz doe.
    Yeah, despite being Rotas and being heavy, the GR-As are quite attractive. Based off the Prodrive P1s.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  4. #408
    Jan 2012
    Philly Area
    *Checks into thread. Sees no Evo. Leaves*
    - Will
  6. #409
    zax
    zax is offline
    Nov 2008
    Sees no Evo; hears no Evo.
    Facebook me here
  7. #410
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    You're such a ricer Zach!!
  8. #411
    Palmyra, NJ
    It runs!
  9. #412
    Jan 2012
    Philly Area
    Fear no Evo??
    - Will
  10. #413
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by A265 View Post
    Your such a ricer Zach!!
    ZOMG?! Canadian grammars FTL!
    Facebook me here
  11. #414
    Mar 2009
    in a igloo
    Grammar? wat iz dat?
  12. #415
    Contributes Nothing ShiftingLanes's Avatar
    May 2013
    Riverdale, NJ
    You can keep the Rotas. I'll take your OZs. DIBS. I CALL DIBS.
    http://shiftinglanes.com
    '14 DGM WRX Limited Hatch
    I'm a build thread?
    Stink-eye Mob #49
  13. #416
    zax
    zax is offline
    Nov 2008
    Just a word of warning to those who stumble upon this thread:
    After installing the ID1000s, I was a bit curious that the LTFTs were consistently 8-10%. This was also reflected in the OL fueling. Since I reverted back to the stock airbox to scale my injectors, latency, and TIE, I thought it was unlikely that my stock MAFv scaling could be that far off. However, after some research, this is what I've found.
    The industry standard for testing injectors is using the fluid n-Heptane. When installed in your car, the injectors flow gasoline. The viscosity of n-Heptane is 0.684 g/cc vs. the 0.75 g/cc viscosity of gasoline. As such, n-Heptane flows 0.91x that of gasoline. The value in Rom-Raider is compared to the stock injectors and the stock injector's flow rate is calculated using n-Heptane. InjectorDynamics uses gasoline for flow testing. There is nothing wrong with this method -- in fact I prefer that ID uses the intended medium for flow testing. However, this means that the flow rate defined in RR should be 0.91 * the advertised flow rate of 1015cc/min. In RR, you shoud enter the injector flow rate of approx. 925cc/min.
    Facebook me here
  14. #417
    Palmyra, NJ
    Becausephysics.
  15. #418
    Jul 2012
    Rocky Top
    Becausephysics.
    #Bernoulli Boyz
  16. #419
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    Thanks for sharing your find Zax.
    I feel slightly less nerdy now. Zax-nerd > Pete-nerd.
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
  17. #420
    zax
    zax is offline
    Nov 2008
    Tuning the TIE has been a bit of a journey. The tough part is adjusting all the comps IMO. The boost-error compensation does not make much sense to me on the MBC, but zeroing the tables doesn't seem to help the overall TIE. Perhaps it's because I'd have to adjust the throttle TIE after zeroing out the comps.
    Here is my main point of frustration: since the Injectors are 220% larger than stock, the added IPW for the TIE is very short at the low throttle angles. This makes capturing the event much more difficult and I find myself bumping into logging resolution.
    For the most part, the starting TIE map is set to 45% of the stock additional IPW with an additional 20% of IPW for other modifications. This is 54% of the stock additional IPW.
    The transient response is much improved.
    Facebook me here
