Zax Bugeye "Shaggin' wagon" Build thread - Page 20
Page 20 of 37 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 286 to 300 of 543
This is a discussion on Zax Bugeye "Shaggin' wagon" Build thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Rambo So aside from replacement, is there anything you can do about the MAF turbulence? The Banish ...
  1. #286
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Rambo View Post
    So aside from replacement, is there anything you can do about the MAF turbulence? The Banish book mentioned extra mesh screens (in addition to the OEM one) could help without significant flow restriction. You could also go to Speed Density, I guess...
    A little turbulence is normal. I won't jump to this conclusion just yet. The MAF and fueling system does funny things when the scale is very far off (>8-10%).
    FWIW, I'm going to start performing CL MAFv scaling, which should really focus in that 15-30g/s airflow range:
    http://forums.nasioc.com/forums/show....php?t=1427448
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  3. #287
    zax
    zax is offline
    Nov 2008
    You can see the affect the Fujita intake had on my LTFT:
    With stock airbox, injectors scaled:
    With Fujita CAI installed, injectors same scale:
    LTFT ranges are -14.99 to 14.99, so you can see column C is pegged and relying on STFT to bring the mixture to stoich for CL.
    Facebook me here
  4. #288
    May 2010
    Pittsburgh, PA
    Plot your AFR errors over RPM at various loads. I bet you'll find it's RPM dependent and not MAFv. Fuel system resonance ftl.
    Never know... That's just at weird place to have such a sharp spike.
    2011 STi Build Log
  6. #289
    zax
    zax is offline
    Nov 2008
    I thought about fluid resonance in the rails. I might go back to the stock airbox to see if the same issue is present.
    Facebook me here
  7. #290
    May 2010
    Pittsburgh, PA
    You should see it there. It may have gone unnoticed. Not a bad idea though.
    2011 STi Build Log
  8. #291
    Cheeky Bastage! spirited09wrx's Avatar
    Oct 2009
    Dirty Jerz
    Bro, do you even LTFT
    Zach
    Teh Intern @ WTF Tuning, LLC
    2009 WRB Subaru Wrx Sedan: Torqued Performance Stg2
    Stink eye Mob #287
    N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
    "It's not turbo-lag, it's foreplay"
  9. #292
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by spirited09wrx View Post
    2007 Outback 3.0R wagon
  10. #293
    zax
    zax is offline
    Nov 2008
    Given the fact that my MAFv peaked at 4.6 volts during my untuned run, I made the decision to move to a 73mm MAF housing, which I purchased off NASIOC.
    Facebook me here
  11. #294
    zax
    zax is offline
    Nov 2008
    Well the 73mm MAF housing and enormous ridiculous filter is installed!
    Because the diameter of the new MAF housing is 73mm while the stock is 65mm, the new housing has (75^2)/(65^2) = 1.26x more crossectional area. As such, I scaled the MAF sensor by 126% to account for the slower intake velocity per relative air mass. This was a rough approximation since there are other factors involved in the actual MAFv scaling (turbulence, fluid dynamics, etc.). I tell you guys and gals, as an engineer by profession and a physicist by education, I have NEVER seen a rough calculation prove so accurate in the world off-paper:
    Game on.
    Facebook me here
  12. #295
    Registered User Phobic's Avatar
    Aug 2012
    Boston, Ma
    that filter is enormous.
  13. #296
    zax
    zax is offline
    Nov 2008
    And REALLY REALLY ugly!
    Facebook me here
  14. #297
    May 2010
    Pittsburgh, PA
    Holy crap zach - I am shocked that is as close as well. Awesome.
    2011 STi Build Log
  15. #298
    Jan 2012
    Philly Area
    Game on indeed!
    - Will
  16. #299
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    ugly and big. it works though right?
    +1 to zax for shooting from the hip and hitting real darn close to a bullseye
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
  17. #300
    zax
    zax is offline
    Nov 2008
    Compression test results:
    Cylinder 1:
    Cylinder 3:
    Cylinder 2:
    Cylinder 4:
    Motor was only lukewarm, unfortunately. Compression in cylinder 1 dropped a few PSI, but still well within healthy limits. Still excellent compression for a 2003.
    149 - 155 - 157 - 152
    Facebook me here
