Zax Bugeye "Shaggin' wagon" Build thread - Page 15
Page 15 of 37 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 211 to 225 of 543
This is a discussion on Zax Bugeye "Shaggin' wagon" Build thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by mangostick forums need dislike buttons... can you pinpoint where? Guess this means you're pulling the intake again ...
  1. #211
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by mangostick View Post
    forums need dislike buttons... can you pinpoint where? Guess this means you're pulling the intake again eh?
    I have to pull the intake manifold. I have never pulled the intake manifold before. Looks like I'll be learning some new tricks! The good news is (since it was tuned with the boost leak), there is no potential for damage to the motor. However, the crap idle and power loss is irritating. Not to mention the frequent misfire codes.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  3. #212
    Banned for Ageism 96accord's Avatar
    Mar 2007
    Baltimore, Maryland
    Hi
    ^_^
  4. #213
    zax
    zax is offline
    Nov 2008
    This weekend I installed the PTP Turbo Blanket and further attempted to track down the massive boost leak haunting my motor.
    To start the Turbo Blanket install, I needed to remove the Cobb Heatshield:
    To completely remove the heatshield, you must remove your TMIC if you have installed a larger TMIC like I have. However, it is possible to install the turbo blanket without completely removing the heatshield. In my circumstance, the TMIC had already been removed to track down my boost leak
    Here is the PTP Turbo Blanket installed:
    And again with the Cobb heatshield installed over the Turbo Blanket:
    My impression of the Turbo Blanket:
    While I do not have a heat gun to accurately determine the difference in underhood temps before/after the blanket installation, I can actually TOUCH the heatshield after driving the car, something I could never have done before the blanket installation.
    Also, here is a picture of my "boost leak tester" in action:
    Facebook me here
  6. #214
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    So no luck finding the leak?
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
  7. #215
    Dec 2011
    Pottstown PA
    quite a little nerdy redneck boost leak contraption ya made up there
  8. #216
    zax
    zax is offline
    Nov 2008
    Facebook me here
  9. #217
    Jun 2011
    Hella, SoCal
    Hi there, just want to say cool build and I have one question, hopefully it's not a noob question; your valve-cover vents hoses seem to go over to the oil filler cap before they go into the intake; is this so you don't get oil in the intake? And how do I do this or where do I buy one of these?
    This is something I have noticed and have been wanting to "fix" for some time now.
  10. #218
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by super13pill View Post
    You're 75% correct! The cyl. head vents don't run to the oil cap, they run to my Oil Catch Can:
    This removes the oil blowby from the cylinder head vents. Though honestly, I haven't had a single drop of blowby since I installed the catch can. I do, however, have some amount of oil blowby from my PCV valve...
    Facebook me here
  11. #219
    Dec 2011
    Pottstown PA
    cool zipties, becauseJDM
  12. #220
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    Zax mah-man.
    You wrapped up your turbo twice, blanket, steel, added a catch can..etc.
    When you going to mod the battery? Looks like you are still rocking a factory battery. Shame, shame.. you need to step up your game.
    *had to say something stupid. I dig the build. I like the heat retention/prevention strategy you have going on in the turbo area. I might have to copy-cat a little.
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
  13. #221
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by pete25r View Post
    When turn the key in my car, the car starts. Beyond this, I see no reason to replace what is currently not broken. Incidentally, I also have no reason to believe that it is not the original battery. At the very least, I have not replaced the battery in the 6 years/60K miles in which I've owned the car.
    It's quite simple really. Heat is energy. Energy is good whilst in the Turbine. Energy is bad whilst in the ingested air. I try to keep as much of the heat IN the exhaust and OUT of the ingested air.
    Facebook me here
  14. #222
    zax
    zax is offline
    Nov 2008
    Re: Zax Bugeye "Shaggin' wagon" Build thread
    Next stop: BPM TMIC
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Facebook me here
  15. #223
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    I can haz the STI TMIC?
    2007 Outback 3.0R wagon
  16. #224
    zax
    zax is offline
    Nov 2008
    Four parts on order:
    1.) KSTech TGV-Blockoffs
    2.) Grimmspeed Phenolic spacers (3mm)
    3.) Gates timing belt kit
    4.) Tactrix OpenPort2.0 to replace my Cobb AP
    Facebook me here
  17. #225
    Oct 2010
    Portland, OR
    Me too.
