WRX Protuned by Agile Auto - Page 6
Page 6 of 6 FirstFirst 123456
Results 76 to 78 of 78
This is a discussion on WRX Protuned by Agile Auto within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by CharlieBronson08 2.0L?? Really. That's funny. it's actually the 08 STi. I was wondering why my torque was ...
  1. #76
    Quote Originally Posted by CharlieBronson08
    I was wondering why my torque was so low as compared to what I've seen others run. Hard to compare since I've rarely seen anyone run a 20G with the stock TMIC. But again, my experience is limited.
    Rebuild was with Cosworth pistons and rings, ARP head studs and connecting rods. I thought the engine should be near indestructible. Is the stock IC really that much of a weak point? Do I have to upgrade before adding more boost.
    Now don't get me wrong, the car feels fast... but definitely seems like I should be able to get more out of it.
    Your torque is low because you're not running more boost. The TMIC will limit you due to cooling ability and pressure drop (the 20PSI the ECU is reading is likely in the 23PSI range at the compressor). Get a better I/C, crank the boost/timing up a bit, and you'll see a significantly better plot.
    Resident Tuner @ WTF Tuning
  3. #77
    Registered User CharlieBronson08's Avatar
    Sep 2012
    Baltimore
    No Mikie's right. Unless you have headers with improperly matched primaries, 350whp/320wtq look like numbers that an EJ205 would make on a 20G.
    Not that I changed my headers at all but so I understand ... are you saying that improper primary pipe lengths or diameter, would change the tq? There is a sticky on this somewhere i'm sure.
    ... did the tuner tune your AVCS?
    Timing and valves right. I assume yes. Don't you have to when the engine is rebuilt? Maybe not. I guess these are questions I should be asking.
    Is it a single or dual AVCS on the 08 STi? Would a dual make it harder to tune? Are there specific things one should request re: AVCS when getting a tune?
    Maybe I should take a class for real.
  4. #78
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by CharlieBronson08 View Post
    Yes. If you have very large diameter header primaries, the exhaust gasses exiting the combustion chamber will slow as they expand to match the volume since the exhaust gas is losing energy: Expanding gasses cool (recall your thermodynamics). Lower exhaust gas velocity allows the turbo to spool quicker and the gasses to clear the exhaust in a more timely manner. However, at high-RPM and loads, smaller primaries can become a restriction in the the flow of exhaust out of the motor. It's a trade off: a larger primary will become more efficient at high-RPM and load, while a smaller primary will conserve EGV at low RPM and load. Therefore, the primaries should be properly matched to your heads and turbo.
    The 2008 STi has AVCS on the intake and exhaust (dual). This is different from the 2004-2007 STi which has AVCS only on the intake. A properly tuned AVCS will give the motor a fair bump in mid-range torque (on the order of 10-15 WTQ). It IS more difficult to tune compared to intake-only AVCS and definitely moreso than the EJ205 without AVCS, which is why many tuners don't touch AVCS,
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
