Results 1 to 14 of 14
This is a discussion on Brad's 2011 SWP sedan build within the Builds forums, part of the Tech & Modifying & General Repairs category; Well, I've had the car for 6 months now, so I figured I'd go ahead and start a build thread. ...
    Dec 2008
    Well, I've had the car for 6 months now, so I figured I'd go ahead and start a build thread. Going to take my time with it and build it right. So for now, here's what I've got:
    Current Mods:
    Cobb SF intake
    Cobb shifter bushings
    Cobb AP Stage 1 + SF 91
    Nameless Axleback Exhaust
    Whiteline rear differential bushings
    Next on the list:
    Whiteline rear swaybar
    Kartboy endlinks
    Whiteline shift kit bushings
    Pitchstop & Transmission mount
    dash gauge cluster
    boost, a/f, and oil pressure gauges
    After that:
    Downpipe
    Built block
    GT35r
    E85 conversion
    '11 SWP WRX: Cobb front/rear shifter bushings, Whiteline rear diff front bushings, Nameless axleback
    Registered User Chance1218's Avatar
    Mar 2012
    Washington
    nice!
    do you have the STI STS?
    Dec 2008
    Thanks! And, yes I do!
    Mar 2012
    Washington
    quick question then, do you notice anything different with the cobb shifter bushings?
    Registered User jdubya's Avatar
    Mar 2012
    Round Rock, TX
    Thoughts on lowering it? I have the base SWP WRX and have been thinking about lowering it an inch or so. I haven't researched enough to speak much about it, but I think it would look good.
    Mar 2012
    Round Rock, TX
    ... what is STI STS?
    Dec 2008
    Quote Originally Posted by jdubya View Post
    I would love to lower it. Forgot to put that on there. Will probably go with some full coilovers well before I get to the built block. Its the best way to go. Lowering springs will wear your stock shocks out faster.
    Basically just a subaru brand short shifter. Shortens the distance traveled by your shifter for quicker shifts. Personally I don't like the STI version.....shifting still feels a tad sloppy even with the bushings. Eventually I want to replace it with the Cobb.
    Dec 2008
    Quote Originally Posted by Chance1218 View Post
    The STI shifter still feels a tad sloppy, but definitely not as bad with the bushings.
    Mar 2012
    Washington
    can't speak for OP but I am looking at the Koni Yellow Struts with Eibach Pro-kit springs.
    from the reviews and testings I have seen online, the H&R springs perform a tiny bit better on the track, but the Eibach Pro-kit's are a tad bit better on the street...
    I am sure you can ask a bunch of people about it, but I found them here:
    Front: Koni Yellow Sport Shocks 08+ WRX Only / Front Only [8610-1453SPORT] - $190.00 : Kronos Performance, Fueling the Car Lover Within
    Rear: Koni Yellow Sport Shocks 08+ WRX Only / Rear Only [8010-1055SPORT] - $180.00 : Kronos Performance, Fueling the Car Lover Within
    Springs: Eibach Pro-Kit for 09-10 Subarua WRX 4 & 5 Door 2.5L Turbo [7721.140] - $280.00 : Kronos Performance, Fueling the Car Lover Within
    or: H&R 08-up Subaru Impreza Sedan/ Hatchback Sport Spring H&R 08-Up Subaru [54460] - $286.00 : Kronos Performance, Fueling the Car Lover Within
    Mar 2012
    Washington
    Quote Originally Posted by bradboyd80 View Post
    I dont have any AM bushings, and I never drove the non-STS wrx to get a comparison, but I do notice that sometimes it feels hard to get into gear, locked out, etc. with the STI shifter.. I was thinking the COBB one as a good upgrade too.. I just couldnt find if there was a difference between the COBB and Kartboy STS, and between the bushings.
    Mar 2012
    Round Rock, TX
    Ah - Short Throw Shifter (STS) .....duh
    Mar 2012
    Round Rock, TX
    I'd definitely like to add a STS to my car, interested to know the difficulty level though.
    I think I need a 2nd job to fund my wish list! :S
    Dec 2008
    I've heard a lot of good things about the Koni's also. Personally I want to go with the Tein basic or BC. Affordable, yet good quality.
    I wouldn't know the difference in the Cobb and Kartboy STS either, but both are great companies, so you probably can't go wrong either way.
    Install on a STS can't be all that bad. I haven't had to do it on a WRX, but in several other cars I've done, it was only difficult because you're working with tight spaces. If you have access to a lift it would make things a lot easier too.
    Mar 2012
    Washington
    lol ya I am in the process of trying to get a promotion to get more car money. :P
    2011 WRX Short throw shifter install - YouTube
