Results 1 to 15 of 16
This is a discussion on Project: Budget Bugeye Track Toy within the Builds forums, part of the Tech & Modifying & General Repairs category; I'm currently building my 02 WRX wagon into an auto x car as well as an occasional track day car. ...
    Registered User 012.5RS's Avatar
    Feb 2008
    PA
    I'm currently building my 02 WRX wagon into an auto x car as well as an occasional track day car. This is gonna be done on a fairly strict budget and wont be a stripped down racer but a weekend track toy that can also run and get groceries(since it is a wagon). This car is pretty much to allow me to auto x and road course and become a better driver as I build my 95L into a full blown time attack car.
    Current Power: Unknown
    Goal Power: 300whp
    Current Weight: Unknown
    Alignment Specs:
    Camber: -2* f/r
    Toe: 0 f/r
    Ride Height: 14.25" f / 13.75" r
    Coilover Settings: 10f/12r
    Current Mods:
    Exhaust:
    Perrin UP
    Perrin catted DP
    Borla hush cbe
    Steering & Suspension:
    BC Racing BR coilovers
    Perrin endlinks f/r
    Whiteline rack bushings
    Brakes:
    4/2 Pots
    Hawk HPS pads
    Powerslot rotors
    Goodridge lines
    Perrin m/c brace
    Wheels & Tires:
    17x8 +45 Enkei RPF-1
    235/40R17 Dunlop Direzza
    Planned Mods 2012:
    Air & Fuel
    APS CAI
    Probably making home made anti surge tank
    Suspension:
    Whiteline adj 22mm fsb
    Eibach non adj 19mm rsb
    Perrin stout mounts
    Whiteline R.O.C.K. kit
    MSI 1" correction trailing arms
    MSI lateral links
    TiC bushing kit
    Whiteline rear subframe bolts
    Engine:
    VF39
    STI tmic w/ splitter
    Exhaust:
    Tial 38mm ewg
    Electronics:
    Utec Delta
    Rallitek boost/oil press/egt gauges
    ATI gauge pod
    Exterior:
    JDM hood scoop
    Planned Mods 2013:
    Suspension:
    Whiteline ALK
    GT Spc 3 piece front subframe brace
    GT Spec fender braces
    GT Spec ladder brace
    GT Spec front lower tie brace
    GT Spec rear t brace
    GT Spec rear diff mount
    Cusco front bumper brace
    Cusco middle underside brace
    Cusco rear underside brace
    Brakes:
    Brembos
    Ferodo 2500 pads
    DBA 4000 rotors
    Quantum Motorsports brake ducts
    Exterior:
    Chargespeed brake duct inlets
    Morette headlights
    Prodrive replica lip
    4/2 Pots powdercoated lazer crystal/cream soda blue by LPC:
    My Old V6 STI 16x7 +53 TE37's:
    March 2012 Clubwrx Victory Meet:
    After the alignment I took the car for a little drive and stopped at Fort Washington Park for some pics(still need to raise it up unfortunitely the shop lowered it beyond my specs):
    Power Is Nothing Without Control.
    Bugeye Mafia #221
    Feb 2008
    PA
    saved for more updates
    Bugeye Mafia #221
    Feb 2008
    PA
    saved
    Bugeye Mafia #221
    Feb 2008
    PA
    last save
    Bugeye Mafia #221
    Registered User irvin787878's Avatar
    Jun 2009
    Milesburg / Near State College PA
    Sounds like you have a nice project going. Good luck. I have a question about your calipers. Did the calipers need torn apart in anyway to get done? I do understand they had to be taken off the car. LOL
    HAWK-EYE ALLIANCE #7878
    2007 WRX TR
    My work in progress. http://www.clubwrx.net/forums/off-to...ld-thread.html
    Feb 2008
    PA
    Thx man. Yes they need to be torn apart and remove the pistons and all seals.
    Bugeye Mafia #221
    Oct 2005
    Late Devonian
    Are your sway-bar sizes listed backwards?
    Oct 2011
    Santa Ana, CA
    Hey man, whats your opinion on those 4/2 pot brakes in terms of feel and stopping power?
    And no A/O separator?
    Feb 2008
    PA
    Mycologist no they are not backwards. And uedan they stop great and have great pedal feel with my Perrin mc brace. No a/o separator planned yet havnt decides which brand I wanna go with.
    Bugeye Mafia #221
    Oct 2005
    Late Devonian
    Quote Originally Posted by 012.5RS View Post
    I don't know from personal experience, but that is opposite from most Autox recommendations and the rear is way large for track use.
    JR had some decent titles, and a ton of knowledge on this:
    Swaybar & Endlink FAQ
    Feb 2008
    PA
    The issue is the wagon due to the narrow track width. Not too many people make bigger front sways for the wagons. So for auto x I'm looking at the adjustable 22mm fsb and thinking it will be set on full stiff. And use the rear 27mm to possibly be able to induce snap oversteer if needed for tight 180*s if there are any. For track days im looking into staying with stock rear. This is of course all just a general idea and I will have to sort out as I go and see how the car reacts. I also have a cusco 21mm non adjustable fsb from my old gc as I've read should bolt up since it's the same track width. I might go with the 21mm/17mm for now till I can afford sti lca's and then have more options for my front sway. If I do go that route which I probably will as long term goal is track days I'll prob pick up the sti lca's next year and go with a 24mm adj/22mm non adj.
    Bugeye Mafia #221
    The issue is the wagon due to the narrow track width. Not too many people make bigger front sways for the wagons. So for auto x I'm looking at the adjustable 22mm fsb and thinking it will be set on full stiff. And use the rear 27mm to possibly be able to induce snap oversteer if needed for tight 180*s if there are any. For track days in staying with stock rear. This is of course all just a general idea and I will have to sort out as I go and see how the car reacts and how I like the driving.
    I'd go with an adjustable 24mm; you can set it to 22, 24, or 26.
    I'd also recommend a larger front vs rear. Snap oversteer isn't something I want (I've seen it cause too many problems).
    Feb 2008
    PA
    Yea im kinda going back and forth in my head. It's just one of those things u gotta figure out by testing. I think I've decided to see if my cusco fsb will bolt up and if it does go with that till I can pick up some sti lca's instead of spending money twice.
    Bugeye Mafia #221
    Jun 2009
    Thanks for the info. I guess I will not be doing that anytime soon.
    2007 WRX TR
    Feb 2008
    PA
    its really not too bad, plus subaru sells the rebuild seal kits and all.
    Bugeye Mafia #221
