Results 1 to 11 of 11
This is a discussion on 2012 STI first mod help within the Builds forums, part of the Tech & Modifying & General Repairs category; Hi, I just bought a 2012 STI sport tech and I am doing the following mods. Invidia Catted Downpipe Invidia ...
    Feb 2012
    Invidia Q300 Cat-back Exhaust
    COBB Accessport
    Tomei Headers (Unequal Length)
    Cobb SF Intake and Airbox
    ProTune with Dyno
    What else can I do to get more HP and TQ with out melting pistons or braking the bank?
    thanks
    Registered User J_Maher_WRX's Avatar
    May 2011
    Newfoundland
    Welcome to the forum and congrats on the new STi!
    If you're getting upgraded headers, may as well upgrade the up-pipe to an EWG setup. Also prob want to look at an upgraded fuel pump, and a EBCS will allow your tuner to be more aggressive. I'd suggest going the Nameless Performance TBE route though, dyno proven to show better gains. And its nice to know that they are all hand made quality parts in the USA, as opposed to mass produced chinese parts that are made for next to nothing and then sold for a billion times profit. Jus sayin
    Good luck on the build! P.S get some pics up!
    Justin ~ 2011 WRX (WRB Sedan) ~ 275whp/299wtq
    Build Thread Beloww:
    http://www.clubwrx.net/forums/builds...-2011-wrx.html
    Feb 2012
    ok, thanks. With all of that done what can I expect for HP?
    Registered User xFalleNx's Avatar
    Nov 2010
    Moorestown, NJ
    Quote Originally Posted by waytofast View Post
    That all depends on your tuner/dyno.
    May I ask why you want to replace the headers and not go with an EWG set up? Or even go with headers/ect over other mods such as EBCS/IC/Fuel upgrades?
    --Anthony 2011 DGM WRX stg2+sf intake + custom front end deer mod!
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Feb 2012
    Well I want the entire exhust done and it sounds sweet. Whay is an EWG set up? I want all of the upgrades in time.
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    The 2.5 motors are tough motors and pistons really don't melt...if people have any issues, its usually piston ring oriented. If you're melting pistons, something is majorly wrong with what you're doing.
    An external wastegate setup allows for better boost control and will help improve spool up capability because there is less turbulence in the exhaust side of the turbocharger vs. an internal setup.
    Whenever you're ready to get those parts, let me know. If you want some more advice, feel free to PM me.
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    Feb 2012
    awsome, thanks a lot. I am new to the tuner world but we have always wanted a STI. Can I do the headers and catback and the EWG?
    Nov 2005
    Bordentown, NJ
    Yes you can. It can be a little pricey to do the EWG setup and you of course would need a professional tune afterwards.
    I know you want to do everything but you want to be realistic as to what you want to start with and progress to. All these parts you're stating could easily cost you a few thousand so it really depends on what you're aiming to do.
    If you want to talk more, let me know.
    [/SIZE]
    Registered User sjcurtis's Avatar
    Sep 2010
    Selma, Alabama
    Yep GrimmSpeed has a bolt up EWG for your car but you will not be able to use the Tomei header because there uppipe will not bolt to it. You will have to buy a header with a factory up pipe flange or you could get your exhaust manifolds ported and a cross pipe from GrimmSpeed. But I would say with the mods that you have listed you should be right at 300awhp and 340+awtq
    Nov 2005
    Bordentown, NJ
    Quote Originally Posted by sjcurtis View Post
    What he said.
    [/SIZE]
    Feb 2012
    ok, thanks
