Results 1 to 8 of 8
This is a discussion on Stage 3 on 2011 wrx vs new car? few questions on the power.. within the Builds forums, part of the Tech & Modifying & General Repairs category; Is stage 3 going to make the car that much more enjoyable? What would I be able to run against ...
    Registered User 2011REXRoyalBlu's Avatar
    Oct 2010
    Plantation, Florida, United States
    Is stage 3 going to make the car that much more enjoyable? What would I be able to run against and beat? the new m3's? s4's? thanks in advance!
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    Stage 3 what? What exactly are you trying to do?
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    really??? .. Kidding right? .. Seriously?
    You need to do more research before asking rather open ended and somewhat silly questions like that. There are literally hundreds of mods you can do past a dp/tune (commonly known as stage II) to make improvements in hp. All are going to change the cars characteristics and driveability. "enjoyable" is a relative term... hard to say what you might find "enjoyable". What exactly is it you want from the car? You'll need to know exactly that before you start a path of modification.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Mar 2010
    Akron Oh
    stages are just a word someone picked to kinda classify something. beyond a stage 1 flash and stage 2 DP there are no more stages. can you beat an M3, S4? yes. how deap are your pockets? do you want easy power or work for it? Motor trend has the 11 M3 at only 12.8 at 110 MPH. my 09 stock was 13.3 at 100 MPH and 12.8-12.9 at 107 MPH with FMIC, TBE, 19psi running 313hp on a dynojet. so its pretty easy to tie a M3! im shooting for 11.9 and i went the "work for it" route. a much easier and cheaper route would just be a large turbo and injectors.
    Registered User Eric05mx's Avatar
    Oct 2010
    PA
    Some people have been referring to stage 3 because Torqued Performance has a "stage 3" package which requires a TMIC or FMIC and EBCS. Fuel pump and colder plugs recommended.
    2012 WRX ice silver metallic
    Protuned by Agile Auto 315whp/342wtq @ 20.5psi
    May 2010
    Pittsburgh, PA
    Not to be a jerk - but why the 'builds' forum?
    Anyhow, when you refer to 'stage III', it isn't really a closed issue as it's been said. Some people refer to it as a turbo swap, some just an intercooler, down pipe, and tune. Regardless, you may not be 'running with' the m3's even with a jet engine on the back of your car. There are many things that go into lowering track times - some way more drastically than some added power. For example: good tires, better brake pads, some better springs or sway bars, and most importantly - experience. If you are just talking about the drag strip exclusively - save the cash and put it away in prep for a new transmission/axles/clutch/whatever fails first. A running car always beats a paperweight =).
    Just some food for thought.
    2011 STi Build Log
    Registered User xFalleNx's Avatar
    Nov 2010
    Moorestown, NJ
    this thread needs more stg5 turbos
    --Anthony 2011 DGM WRX stg2+sf intake + custom front end deer mod!
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Registered User Ticopain's Avatar
    Apr 2011
    Québec, Canada
    need more stage fourged
