My short block swap progress.... - Page 12
Page 12 of 12 FirstFirst ... 23456789101112
Results 166 to 178 of 178
This is a discussion on My short block swap progress.... within the Builds forums, part of the Tech & Modifying & General Repairs category; http://www.clubwrx.net/forums/genera...ease-read.html I'd check those out. They are a bit older I think, but should still apply....
  1. #166
    May 2010
    Pittsburgh, PA
    IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!!
    2011 STi Build Log
  3. #167
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    I do have the act street light flywheel....IIRC...oh and the plugs are brand new, injectors are basically brand new...i havent replaced the fuel filter since i put it in though....i cleaned the maf a few months ago but i am using an oiled filter. Hmm...i dont know if its a big deal but like i mentioned before i did get a rough count of 1 when i was checking cylinder 1 with the AP...not sure if that means anything...
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  4. #168
    Registered User Meridius's Avatar
    Oct 2008
    PA, USA
    is it actually setting a code or are you just seeing the misfire count with the AP? Can you feel it misfire or hear it like it was doing before the new engine? The reason I ask is it isnt to abnormal to count a misfire here and there especially with the light flywheel, changes in crank speed are how the ECM sees misfires and the flywheel lets the crank change speed at a faster rate. If you arent feeling it miss or setting a code it might be "normal" for your set up. I would still like to hook it up to a scan tool and get some fuel trim readings and see how its running in general.
  6. #169
    Jan 2009
    Central PA
    Quote Originally Posted by Meridius View Post
    Well then lets check it out! I saw you leaving walmart from a mile away!
    Subaru Guide
  7. #170
    Oct 2008
    PA, USA
    Let me know when you have off work in the evening. We can take it out to the dealer and Ill put the Select Monitor on it and see what we can find out.
    How did you know it was me? My car blends in pretty well.
  8. #171
    Jan 2009
    Central PA
    I have off Wednesday and Thursday next week! Oh and I heard a rice burner coming towards me and instantly recognized it as your car lol.
    Subaru Guide
  9. #172
    Oct 2008
    PA, USA
    Rice burner ehh? Let me check and see if I work Thursday, if not we can check it out then
  10. #173
    Jan 2009
    Central PA
    I wonder how much power I lost out on by only having the 650cc injectors. Hill said that he could have got more if I had bigger injectors......
    Subaru Guide
  11. #174
    Jan 2009
    Central PA
    http://www.clubwrx.net/forums/off-to...ml#post2893789
    WTF....I pulled a Jimmy...kinda...
    Subaru Guide
  12. #175
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Probably quite a bit. Bobby said he always recommends at least a 750 when just removing the tgvs on STi's. He was happy I had 840s
    Lead Wrench @ WTF Tuning, LLC
  13. #176
    Jan 2009
    Central PA
    Well I dried out the MAF and filter and put it all back together, dabbed up the little pool of water in my inlet. Cleared the codes and took it for a spin, it seems fine....it pulled the whole way to redline...didn't sputter or bog down....so yeah....I'm hoping its fine!! I did a datalog with the AP but not sure how to attach it....
    Subaru Guide
  14. #177
    Dec 2004
    Medford, Oregon
    It's probably just fine now dude. Probably bogging because the water in the maf and the filter. If the car can't breath it's going to bog.
  15. #178
    Jan 2009
    Central PA
    Yeah I hope so!
    Subaru Guide
