My short block swap progress.... - Page 11
Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 151 to 165 of 178
This is a discussion on My short block swap progress.... within the Builds forums, part of the Tech & Modifying & General Repairs category; what turbo/injectors are you currently running?...
  1. #151
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Lead Wrench @ WTF Tuning, LLC
  3. #152
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Quote Originally Posted by T0rque View Post
    Apparently a deadbolt superzilla 18g and i put 650cc injectors in... Even though every picture I see of DB 16g turbos they all resemble my turbo...the guy i bought it from swears up and down its the 18g though.
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  4. #153
    Jan 2009
    Central PA
    I feel like my turbo takes forever to spool up....I didn't think I would have such turbo lag with just an 18g....
    Subaru Guide
  6. #154
    Registered User Meridius's Avatar
    Oct 2008
    PA, USA
    Thats another reason to go bigger, You will know whats on the car when you replace it.
  7. #155
    Jan 2009
    Central PA
    So I got another misfire in cylinder one today. I then used the AP to check roughness in cylinder one and I got a count of 1. Wtf..........if there is something wrong......I'm done. It seems to only happen when I'm filling up with gas. This time it happened after I had the cap off for a little bit trying to get my card to work. The network at sunoco was down so I had to recapture tank and go get cash and as soon as I turned car on it idled funny and misdirected in cylinder 1.
    Subaru Guide
  8. #156
    Oct 2008
    PA, USA
    It only happens when you get gas? Thats a little odd. Dumb question but how full are you filling the tank? If you overfill it you might be getting raw fuel into the charcoal canister and then the purge valve sucks it up into the intake and causes a misfire. Im just drawing at straws though but it something to start with. Maybe start by not filling it up the whole way next time and see if it helps. If you want me to come look at it sometime let me know and Ill come over.
  9. #157
    zax
    zax is online now
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Meridius View Post
    He should already know... he's the one that put it on!
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  10. #158
    Oct 2008
    PA, USA
    I know but hes unsure of what it is even though he put it on, it looks like one turbo when someone told him it is something different.
  11. #159
    Jan 2009
    Central PA
    I face spaced ya, this time it happened after i had the cap off for a few minutes. Didnt get gas cause they said the network was down so i had to leave and get cash...put cap back on...got misfire and weird idle as soon as i turned it on.
    Subaru Guide
  12. #160
    Oct 2008
    PA, USA
    I saw the facespace message. Its odd it only happens at that gas station. Did you clear the code out yet? Im curious to see if its a lean or rich misfire.
  13. #161
    Jan 2009
    Central PA
    YeAh i cleared it...
    Subaru Guide
  14. #162
    Oct 2008
    PA, USA
    Well the fact it happend and you didnt actually fill it throws my theory out the window. I will just have to take a little look and see whats going on. Next time it happens dont clear it so I can take a look at the freeze frame data and see what might be going on.
  15. #163
    Jan 2009
    Central PA
    Sounds good, even though i have no clue what you are talking about!
    Subaru Guide
  16. #164
    May 2010
    Pittsburgh, PA
    I know my sti hates closed loop now that I am catless. The rear o2 gets confused it seems. Went open loop 24/7 and don't have one regret. I heard that Cobb put out definitions lately that had rear o2 compensation tables in actually.
    ... Wouldn't cause a misfire though. Just a really goofy idle and generally would run very rich in my experience. Also the learning compensation was covering up some MAF and load comp mistakes.
    You run through donkeys suggestions? I'd look to make a separate post about it otherwise.
    2011 STi Build Log
  17. #165
    Jan 2009
    Central PA
    Hmm...i cant seem to find donkeys suggestions.
    Subaru Guide
