Fox's 06 TR Thread :) - Page 10
Page 10 of 16 FirstFirst 12345678910111213141516 LastLast
Results 136 to 150 of 231
This is a discussion on Fox's 06 TR Thread :) within the Builds forums, part of the Tech & Modifying & General Repairs category; Today I put gas in my car!! Lol Really though, there will be updates to the actual build in about ...
  1. #136
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    Really though, there will be updates to the actual build in about a month. I promise!
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
  3. #137
    Banned for Ageism 96accord's Avatar
    Mar 2007
    Baltimore, Maryland
    Re: Fox's 06 TR Thread :)
    Gas is pricey...
  4. #138
    Palmyra, NJ
    Quote Originally Posted by 96accord View Post
    Gas is pricey...
    Least you're not in Cali...it's over $5 out there.
  6. #139
    Oct 2011
    Santa Ana, CA
    Ugh, thanks for the reminder man. My tank is about to touch the 1/4 mark(my fill up level).
    Donations accepted.
    Posted from a fone.
  7. #140
    Nov 2011
    North GA
    Picked the car up today after having some service done. I had my friend from NASIOC who works at the dealer do the work and he sent me this update:
    "Michael,
    Thanks for bringing you car in today. Just wanted to go over a few things in more detail for you.
    Your Subaru appears to be in very good condition, no abnormalities in the fluids I drained and no metal particles other than the normal “fuzzies” on the trans and diff magnets. In fact your car had less metallic splinters (fuzzies) than an average vehicle the same age and mileage. Diff and trans were refilled with Subaru Extra-S 75w90
    The struts and other suspension components are dry and do not exhibit any leaks or excessive play. However at this mileage the internal seals and valves tend to start wearing in struts and performance does slowly degrade due to this. You may wish begin budgeting for strut replacement or upgrade in the future. Chad and I put a set of Koni cartridges and STI springs on his n/a bugeye so there is no problem if you would like to install aftermarket cartridges that require some cutting and minor fabrication.
    Tire wear looks good - no cupping or uneven wear except some minor variances from over inflation. Definitely want to get some tires before we get into the wetter weather later in fall. Hopefully those tire prices were in the ballpark of what you are seeing elsewhere. If not there might be some room to haggle.
    As noted by your service advisor the front inner axle boots are seeping but not broken. With age and heat the grease in the joint breaks down and becomes thinner. Because the inner joints slide in and out the grease starts pumping around the axle shaft. This seeping will worsen and at some point the grease will get thin enough to make a bigger mess or the boot will break. We quoted the repair to make you aware of the situation and let you know it is something to keep an eye on. As long as the joint does not run dry, get contaminated or start making noise replacing the boot and grease is an economical and sound repair.
    Your alternator and A/C belts are starting to show cracks in the grooves from age. I didn’t note any shredding or delamination but once we start seeing cracks anything is possible.
    I did not perform the coolant service as your history shows that was performed within the last 6000 miles. I also did not replace your cabin filter as it appeared to be relatively clean if not new. Those items should not be on your invoice and I had them deduct ½ hour (our normal single line charge for the coolant service) from the maintenance labor.
    While performing the induction service I did not see any abnormal oil or sludge in the Y pipe, intercooler or compressor exit passage. Crankcase breather system is operating normally as well. No DTCs were present and all parameters appeared normal during pre and post service road test.
    Thanks again and if there is any other area you have questions about please ask .
    David"
    I am very happy with this report! Also Extra S is a miracle fluid. My transmission has never been this smooth.
    Next up is the Cooper RS3-A's. They will be installed on Thursday!
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
  8. #141
    Dec 2011
    Pottstown PA
    glad to hear everything is well, post in like a week on how the trans feels. when i changed my fluid it felt super smooth and then the next day it felt how it was before i changed it
  9. #142
    Nov 2011
    North GA
    Quote Originally Posted by Ruh Roh View Post
    Uh oh....well I will keep that in mind. I do feel that anything is better then the Mobil 1 I did have in there lol.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
  10. #143
    Nov 2011
    North GA
    I had the Cooper Zeon RS3-A's put on Thurdasy and I will 100% recommend these tires to anyone. Great traction in the wet and dry.
    I went with 225/45/17's and I really think that size is far better on the stock wheels then 215's were. The "stance" is little bit beefier than before and on stock ride height the tires fit the wheel well better.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
  11. #144
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Wow, that had to be the most in depth service report I've ever seen, haha!
    On my wife's car, I'm used to "tires good, belts squeak. That will be $150, please."
    2007 Outback 3.0R wagon
  12. #145
    Nov 2011
    North GA
    Quote Originally Posted by Rambo View Post
    Lol yeah, it would have been the second one but, I know the mechanic from our local NASIOC thread.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
  13. #146
    Nov 2011
    North GA
    This will be going on this weekend hopefully.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
  14. #147
    Nov 2011
    North GA
    Update:
    I got the shifter installed today! The bushings will probably wait a little bit so I can use the lift at my brother in laws work. This will also give me time to order the rear bushing.
    Picture time!
    Stock
    Comparison
    Kartboy installed
    Finished product
    The install is super simple, the hardest part is getting the shifter back in the cup. I ended up going over to the passenger side and basically standing up so I could use all my weight to force it back in :giggity:. Other than that a baby could do the install.
    I love the feel of it already. Shifting is much easier and I see myself grinding less now since I don't have to hold the clutch down as long. Not that I grinded much anyway, I can just see this helping with that.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
  15. #148
    Dec 2011
    Pottstown PA
    id like to grind on your knob and new shaft.
  16. #149
    Mar 2007
    Baltimore, Maryland
    Bump for updates!
  17. #150
    Nov 2011
    North GA
    Bump for updates!
    Okay :-)
    This happened tonight:
    I left work to find a screw in my tire. Luckily my bro in law said he could fix it for free!
    In other news my fiancé and I bought a house so I now have a garage and I plan on trying to do some paint correction as the weather gets better.
    No real mod plans right now though. Money is still pretty tight after buying the house and saving for the wedding. I still love driving it in stock form though!
    Sent from my Nexus 7 using Tapatalk 2
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
