MY '11 WRX 5-door...Progress - Page 9
Page 9 of 13 FirstFirst 12345678910111213 LastLast
Results 121 to 135 of 188
This is a discussion on MY '11 WRX 5-door...Progress within the Builds forums, part of the Tech & Modifying & General Repairs category; But you would be incredibly surprised how well your power band will smooth out with a Stage 1 tune......
  1. #121
    Palmyra, NJ
  3. #122
    Registered User Jonny1106's Avatar
    May 2012
    Albuquerque, New Mexico
    Re: MY '11 WRX 5-door...Progress
    Are they the silverstars or just original model?
    Sent from my Galaxy Nexus using Tapatalk 2
    2012 SWP 5door Premium!!!
  4. #123
    Registered User GOMEZ's Avatar
    Jul 2011
    San Francisco, CA
    Original model.
    '11 WRX 5-door Premium - Satin White Pearl
    http://www.clubwrx.net/forums/builds...-progress.html
  6. #124
    May 2012
    are the h9s whiter, or just brighter?
  7. #125
    Registered User Dgmftw's Avatar
    Sep 2012
    Ormond Beach
    Good build! gets me excited to start doing my mods on my 13. To be honest I think id do sways and endlinks first coupled with a TP Stage 1 tune
  8. #126
    Jul 2011
    San Francisco, CA
    Right you are, Mikie. I picked up a used Accessport for $400 and WOW! What an improvement!
    I've been wanting to try out the Karboy short shifter for a while now. I've always thought the STi Factory short shifter was too tall and the throws weren't as short as I hoped. So I bought the KB shifter and installed last night. The install is pretty easy just make sure you have a set of mini precision pliers or better snap ring pliers.
    KB shifter vs. STi OEM short shifter
    Installed
    The throws are noticeably shorter than the STi shifter. I like it, however my arm now has to reach a bit further to shift which is slightly uncomfortable but i'm sure i'll get used to it.
    Side note: I purchased the SPT heat shield and was looking at it last night. If you've installed one, did you use the supplied bolts/washers? Or did you just use the bolts that are on the OEM heatshield?
  9. #127
    Jul 2012
    Webster, MA
    I used the ones that came with the OEM heatshield for the Cobb install. I think (I could be wrong on this one, but I read it somewhere on the interwebz) that the SPT can also fit over the OEM heatshield...
    Nice build btw.
  10. #128
    Jul 2011
    San Francisco, CA
    Thanks Tanker! Yes I've also seen that the SPT fits over the OEM and it's what I plan on doing. It also came with a longer bolts and washers which seemed unecessary. I'll try to use the existing bolts over the OEM heatshield.
  11. #129
    Palmyra, NJ
    Nice! Glad you're liking Stage 1...now imagine Stage 2
    Shifter looks good...and yes, definitely makes shifting much better as well.
  12. #130
    Jul 2011
    San Francisco, CA
    I'm not 100% on the shifter yet. The throws are shorter than the OEM STi shifter but just by a hair. The height is definitely shorter, but as I stated my arm is reaching a bit further now. It may or may not be for sale soon. We'll see.
    Stage 1 is very nice. I have the AEM CAI waiting to be installed, so stage 1.5 should be nice as well! Stage 2 will definitely be in the picture eventually.
  13. #131
    Registered User bpeters87's Avatar
    Nov 2011
    Harrisburg, PA
    Check out my thread for pics on the spt heatshield. It just fits over the oem shield to dress up the engine nicely. Pretty quick/simple install.
    Bryan | Stink-Eye Mob #265
    07 Impreza Outback Sport, 5spd
    Sad I don't have this anymore:
    2012 WRX Premium, Plasma Blue Pearl hatch, Stage 1+
    check out my build thread
  14. #132
    Jul 2011
    San Francisco, CA
    Finally got around to do the front and rear shifter bushings. So good news and bad news. The good news is the front bushing went in without any issues.
    Installed
    But the rear, I had a snafu. Trying to install the COBB rear, one bolt went in smoothly. But the other bolt did not go in straight and I was bolting it at a weird angle. So I decided to stop and put in the STi bushing instead (which is not that much better than stock). But as I was tightening down the bolt the bolt broke in half and now the bolt is stuck inside the hole.
    OEM vs. STi vs. COBB
    So now the bushing is half bolted. What to do? Drill out the screw? Re-thread the hole, etc???
  15. #133
    Registered User Chance1218's Avatar
    Mar 2012
    Washington
    That sux dude. :/ my friend and I installed the front and rear kartboy bushings. The driver side went in easy for the rear. Passenger side sucked tho. Had to like pull the bushing over super hard for there to be enough room. Hope u get it fixed.
  16. #134
    Jan 2012
    Thats bad luck man... ya you are going to need to get the bolt out. Shouldnt be too bad but just a pain to deal with. Good luck with that!
  17. #135
    Jan 2012
    Oh by the way dont drill it out! They have tools to get a bolt like this out at hardware stores. Check that out first. I had to do this on my old RSX when a bolt broke off on the rear rotor.... Not fun
