MY '11 WRX 5-door...Progress - Page 10
Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 136 to 150 of 188
This is a discussion on MY '11 WRX 5-door...Progress within the Builds forums, part of the Tech & Modifying & General Repairs category; Bad luck man, that sucks. I had a hell of a time with threading those bolts too. Just finally got ...
  1. #136
    Registered User Axex's Avatar
    Aug 2011
    North Cackalaky
    Bad luck man, that sucks. I had a hell of a time with threading those bolts too. Just finally got the right angle after a while. Try to get it out w/o drilling, but it might have to come to that. If you be careful it should be alright though. Good luck!
  3. #137
    Registered User GOMEZ's Avatar
    Jul 2011
    San Francisco, CA
    I've looked up certain ways to try to extract it - tap a small hole in the center and try to use an "easy out" which is essentially a broken bolt remover. The area just sucks there is almost no room to work under there. I'll have to remove the DP, which is ok because i picked up an Invidia Catted DP earlier today!
    '11 WRX 5-door Premium - Satin White Pearl
    http://www.clubwrx.net/forums/builds...-progress.html
  4. #138
    Aug 2012
    N. Shore, MA
    those rear bushings are a royal pain in the arse to install... it took me 2 hours to get both bolts alight properly to go in w/o stripping them. i'm a stubborn bastard so i got it done.
    tap and dye set? you should be able to get it out with one of those.
    2012 WRX Premium Hatch, Stage 2
    Ice Silver Metal
  6. #139
    Jul 2011
    San Francisco, CA
    STAGE 2....woohoo! Wow, the car is fast. It feels like the power and torque just pours on and doesn't want to stop. I spent the last few days installing the following:
    • Invidia Catted Downpipe (used) with new Subaru Gasket
    • Cobb Stage 2 Map ACN-91 Map
    • STI Transmission Mount
    • Whiteline Gearbox Positive Shift Kit
    • Cobb Front and Rear Shifter Bushings
    • SPT Turbo Heatshield
    My Dad and I were able to tap through the broken bolt i had stuck in the rear shifter bushing and drilled through the housing underbody. Installed the Cobb rear shifter bushing after that. Along with the front bushing, Whiteline positive shift kit, and the STI tranny mount, the drivetrain feels very direct and strong. When I get off the throttle there's less of a herky-jerky feel.
    Installing the downpipe was pretty easy; it was more difficult to angle my way in and remove the stock downpipe. The Invidia DP went in smoothly and fitment was perfect. Flashed the Cobb Stage 2 ACN91 map and went out for a test drive. The butt dyno tells me its fast, plenty fast. I'm pretty sure I won't need any power upgrades after I install my AEM intake.
    I'll be logging boost levels later. Anything else I should be looking for?
    Install notes/concerns:
    -Shifter bushings were kind of a PITA
    -I was kind of confused with what to do with the bottom portion of the old heat shield. I left it off all together. Is this incorrect?
    -Wrap the downpipe! I installed the dowpipe then realized that I should have wrapped it. I'll have it wrapped sooner or later.
  7. #140
    Palmyra, NJ
    Nice! Glad you like it...yes, the downpipe heatshield can't go back on to the Invidia just cause the size is much bigger. You can cut and rig it, but its more of a pain than its worth.
    You most likely won't feel too much from the AEM intake, though you may net 8-10whp.
    You're going to want to log Feedback knock correction, fine learning knock correction, DAM, Boost, engine speed, engine load.
    I also did all the same bushings you did: the tranny mount bushings were good. I like them. But I also realize I should have skipped the Group-N tranny Mount, and went right for a solid mount like the Beatrush or Cusco.
  8. #141
    Aug 2011
    North Cackalaky
    Sweet! It's good you were able to fix your rear shifter bushing bolt. Your car is coming along nicely though. I like all the pics!
    What's next? If you're into the bushing thing, I recommend the whiteline subframe inserts and the rear diff inserts if you don't have them. I don't have any transmission bushings, but these definitely helped the feel when taking off and letting off the clutch.
  9. #142
    Jul 2011
    San Francisco, CA
    Thanks! Up next will be SS brake lines, dot4 fluid, rotors, and my intake. Hope to install today and tomorrow.
    But looking down the road, I'd like to do the RCE/Koni combo and maybe a strut bar. After that maybe tint and new wheels.
  10. #143
    Palmyra, NJ
    Quote Originally Posted by Axex View Post
    I also have those ready to go. But honestly...I'd pay someone to have the diff bushings done. The subframe/outrigger bushings are simple...but the rear diff? Total biatch. Its not easy getting the mounting bolts out at all.
  11. #144
    Aug 2011
    North Cackalaky
    I did them myself and it was really simple! You only put the bushings in the one side so if you don't want to remove the whole mount you can do one side and swing it down. I will admit the bolts were difficult to break loose, but not impossible. Not sure if your car is different, I have a 2011 wrx, but these instructions are pretty clear: 2008 Whiteline Rear diff bushing install - Subaru Impreza WRX STI Forums: IWSTI.com
  12. #145
    Jul 2011
    San Francisco, CA
    I did a few logs earlier and here's one of them. Please let me know if anything looks concerning.
    https://docs.google.com/spreadsheet/...GpCekNoQWoxUGc
  13. #146
    Palmyra, NJ
    Ohh yeah yours are different than mine. Plus, I have a 2005 STI with 121k on the clock...tell me how simple it's gonna be again
  14. #147
    Palmyra, NJ
    Log doesn't look too bad. Some minor fine learning knock correction, but no feedback, which is what would occur if your car saw any detonation at that particular moment. Boosting is looking alright as well.
    Did you reset the ECU after flashing Stage 2?
  15. #148
    Jul 2011
    San Francisco, CA
    I actually started out with the standard ACN stage 2 map, saw a boost of 19 at one point (no logs of it), switched to lwg map but under boosted, and finally switched back to the standard stage 2 map. I guess the blip of over boost spooked me a bit. But the lwg map was not satisfactory so I switched back. I did a few more logs and they all are similar to the one I posted.
  16. #149
    Palmyra, NJ
    That's good to hear. Sometimes you can catch a spike here and there...just keep an eye on it.
  17. #150
    Jul 2011
    San Francisco, CA
    Powerslot slotted rotors, stoptech SS lines, and ATE super blue now on the car...brakes feel firm, less mushy.
    But now I'm hearing a whine when boosting. Turbo leak or exhaust perhaps?
