My 2011 WRX - Page 6
Page 6 of 10 FirstFirst 12345678910 LastLast
Results 76 to 90 of 150
This is a discussion on My 2011 WRX within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by SRTSamb Yes absolutely! 2011-2012 Subaru WRX Whiteline Rear Subframe Bushings: JSC Speed Nice man. I've gotta say ...
  1. #76
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by SRTSamb View Post
    Nice man. I've gotta say the engine/tranny mount combo was awesome. More so the engine mounts. Not as much noise as I'd expect. A LOT of engine feel/vibration at higher RPMs. Really helped out the shifter bushings as well actually. Not sure why - balanced the tranny mount out I guess.
    Nice car =)
    2011 STi Build Log
  3. #77
    Registered User SRTSamb's Avatar
    Mar 2011
    Virginia
    Nice car =)
    Thank you!
    I bought the SMY cluster and two new gauges. I was harping on OEM
    But got such a good deal on two gauges, Pro Sport EVO. I like the idea of the digital gauges, in theory. I think what I will do is try them out and if i don't like them I will sell them and go with the original
    Plan. Now I need to to sell my SPT gauge boost gauge
    2011 OBP WRX::Invidia Catless DP::Cobb CAI::TP 93 STG2::KB STS::Perrin Sways::
  4. #78
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    I wanted to get digital AEMs at first.But then realized that since there was nothing else digital on the dashboard,it would look awkward.
    Thankfully Prosport just came out with tehir white needle gauge.
    good luck with that!
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
  6. #79
    Mar 2011
    Virginia
    Installed!
  7. #80
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    ...as it should be.
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
  8. #81
    Mar 2011
    Virginia
    Quote Originally Posted by lokey View Post
    ...as it should be.
    The install was SUPER easy
    I was taking everything a part when the UPS guy showed at 4. I took 5 minutes to look at the direction and was like WTF these are terrible. 20 minutes and I had it wired like I wanted.
    I had everything installed and back together in less than 1 hour. Anybody considering this, DO IT. For and finish is great. Gauge install is easier than it looks.
  9. #82
    Palmyra, NJ
    They were simple as hell in my 2007 STI. I had 3 prosports. Same thing...everything was done in under and hour. Toughest part of the install was trying to wedge yourself up to the grommet in the firewall under the dash
  10. #83
    Aug 2010
    Yonkers/NYC
    Looks good.
    My install took a bit longer because I had to take off the alternator to install the oil pressure gauge sender.
    And like Mikie the damn wires wouldn't go through the firewall.
    T0ny
    2011 WRX
    2012 FXT
  11. #84
    Mar 2011
    Virginia
    Quote Originally Posted by rage-wrx View Post
    Looks good.
    Yeah, I admit I didn't have to do all of that. Makes me think twice about something other than the volt!
  12. #85
    Palmyra, NJ
    Looks good.
    Smartest thing I did was go to Radio Shack and spent about $20 on a good set of connectors, crimps, and spare colored electrical wire to keep in my "electrical kit." I'd used similar stuff for a ton of Audio installs, so it made everything much easier having extra wire and connectors on hand.
  13. #86
    Aug 2010
    Yonkers/NYC
    I solder all my connections.And by now I have a huge collection of terminals & connectors.
    Best thing to get http://www.amazon.com/Bernzomatic-ST...228134&sr=8-11
    T0ny
    2011 WRX
    2012 FXT
  14. #87
    Mar 2011
    Virginia
    I just realized in the photo the battery read 9.8 i went out an fired her up, she's at 9.0 GRRRR new battery time
  15. #88
    Mar 2011
    Virginia
    Aaaassctually... Went and bought a new battery. And discovered two funny things.
    1. Gague still reads 8.0-9.5 I tested it too and it read around 11
    But if I turn my lights off it jumps up.
    2. Boost gauge works great - except if I turn my headlights on, and my interior lighting all the way up, it only reads to 16psi. If I dim it by one "click" it reads fine. WTF
  16. #89
    Jan 2011
    Crofton, MD
    Where did you get power? Clock? Fuse tap?
    Greg
    Build Thread
  17. #90
    Mar 2011
    Virginia
    Clock. I am going to try to re tap else where. Seems like really odds behavior
