Page 4 of 17 FirstFirst 1234567891011121314 ... LastLast
Results 46 to 60 of 249
This is a discussion on Hold_Fast's ESP/SM/AutoX/Track build. Because race car. within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Sasquatch Good question - I am checking with my tuner. update?...
  1. #46
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Sasquatch View Post
    update?
  2. #47
    Registered User Hold_Fast's Avatar
    Mar 2008
    Philly Burbs
    Scored a great deal on a used set of coilovers, just need some replacement parts to make them 100%.
    Pics to come when they arrive.
    ~Stan
    '04 WRB WRX Wagon (Build) - Hard Parked, AutoX Toy
    '86 BMW 325es ~ "The Chump" ~ '11 Hyundai Elantra Limited ~ Daily Driven
    "I was raised knowing there is a replacement for displacement, it's called engineering."
  3. #48
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    update?
    No.
    Quote Originally Posted by Hold_Fast View Post
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
  4. #49
    Mar 2008
    Philly Burbs
    Intake manifold is off the car. Taking it over to Area 1320 tomorrow to get the manifold P&P done and TGV deletes. In the process of removing everything, I found a whole bunch of coolant lines that need to be replaced and my upper coolant reservoir is shot. So 2 questions:
    1. Does anyone have the part # for the upper coolant reservoir? I have a feeling that the OEM one is cheaper than a Moroso replacement (<$100)...
    2. For those of you that have the Samco Ancillary hose kit, do they come with hose clamps and stuff? Just checking to see if I should order a mess a hose clamps.
    ~Stan
  5. #50
    Mar 2008
    Philly Burbs
    Also came up with another question.
    When you get rid of the "green brackets of death", how do you route the breather hose on the right side of the engine? Pictures...
    Right GBOD (see metal portion of the hose):
    Where the metal hose connects to:
    ~Stan
  6. #51
  7. #52
    Mar 2008
    Philly Burbs
    I kept mine.
    I'm opting to get rid of them. I'm probably going to install a catch can anyway, so I'll just bypass the metal section and install all new tubing going to the breather line infront of the intercooler.
    ~Stan
  8. #53
    Apr 2004
    Southeastern PA
    why are you getting rid of your misfire CELs?
    update?
    Yes, finally. I simply opened the ROM and had a closer look in the right pane. It is not enabled.
    I kept mine.
    I also kept the GBOD.
    Mods & Pics
  9. #54
    Mar 2008
    Philly Burbs
    That's good to hear. I have a ton of stuff going on now, trying to get everything sorted so I can actually get everything done "on time".
    My GBOD are going. Shave a few pounds off the front of the car, and less clutter in the engine bay. I just got a Mishimoto ancillary hose kit from my local vendor (JSC Speed), and if that doesn't come with a hose to replace it, I'll fab one up when I install my new catch cans.
    Some more parts on the way/here:
    - STRI Boost & Oil Pressure Gauges
    - Cheap Autometer triple dash pod
    - Boomba fuel rails
    - Various Aeroquip socketless hose ends and hoses
    - Saikou Michi Dual Catch Cans
    - Picked up a new OEM upper coolant reservoir, as mine was in pretty bad shape and actually leaking some coolant.
    New-to-me coilovers are sitting at my post office, since they require my signature to be delivered. I will hopefully get them delivered by Thursday so I can tear them down, clean them up, and start tearing out the rear suspension come this weekend.
    I should also have the intake manifold and TGV deletes back by then, so I can start getting that and the fuel system put together during the week. So much crap to do, so little time....
    ~Stan
  10. #55
    Apr 2004
    Southeastern PA
    As long as you are drivable by 3/3. The VM meet looks to be then.
    ... or hitch a ride with one of the Lehigh Crew.
    Mods & Pics
  11. #56
    Nov 2006
    Denver Metro Area
    shave a few pounds?? from just the GBOD? weigh them dudeski.
  12. #57
    Mar 2008
    Philly Burbs
    I'm trying my damndest to get everything back together in time. Suspension probably won't be completely done, but that isn't a huge deal.
    They are sitting on my garage floor. When I go up on Sunday, I'll bring a scale and measure them for ya .
    Every ounce counts!
    ~Stan
  13. #58
    Nov 2006
    Denver Metro Area
    I always take a dump before I race... every ounce counts
  14. #59
    Mar 2008
    Philly Burbs
    Busy weekend, as in busy not working on the car. But I at least got to swing by Area1320 on Sunday and get my TGV's and intake mani back. Hopefully this sunday will be a little more productive. I need to get some more pictures up in here.
    Man after my own heart.
    ~Stan
  15. #60
    Mar 2008
    Philly Burbs
    Pictures:
    New-to-me AMR Coilovers (missing a few pieces, but AMR is getting them to me)
    Pulled
    IM P&P and TGV's Deleted. Now I just need to clean them up, paint them and re work the fuel lines.
    ~Stan
