Epic win.
This is a discussion on T0rque's Build Thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Where is the like button...
Epic win.
Nice!
2011 STi Build LogOriginally Posted by Trainrex
Tomorrow will be the addition of Tein Super street coilovers, Invidia V3 down pipe, invidia q300 cat back and a WTF tuning stage 2 tune..
The car has 70,075 it is completely stock and pretty well cared for. When I picked it up I noticed a few things..
Oil leaks:
Passenger side top cam gear oil seal
Oil pan gasket
Passenger side valve cover
Belt Squeel:
PS belt glazed
Rear strut clunk:
Bad rear struts
Front strut pop:
Top hat bearings
Brake noise:
Grooved front rotors and bad pads
Grooved rear rotors and bad pads
The auction company got this car from a certified wholesaler so it has a 60 day warranty. Since I am am authorized repair facility I purchased the following parts on them..
Timing belt kit
Oem rear struts
Group n top hats (all 4)
Valve cover gaskets
Spark plug tube gaskets
Drive belts
Brembo brake pads front
Brembo brake pads rear
Brembo brake rotors front
Brembo brake rotors rear
Oil pan is just a sealant.
So I have been busy currently..
Lead Wrench @ WTF Tuning, LLC
Sweet!
- William
Nice Bo!
--Anthony 2011 DGM WRX stg2+sf intake + custom front end deer mod!
Official Subie owner as of 01/10/11![]()
Stink Eye Mob #87
Bye bye Bimmer![]()
Hellooo '11 REX
Update: Found the timing belt to be installed correctly but factory defect, when the motor was cold the car would run fine, while it warmed up the timing belt would stretch and act like it was a tooth off. Replaced the timing belt yet again and car runs fine.
Installed the Invidia V3, and Q300 car is ridiculously quiet, not sure if I will enjoy this yet or not.
Installed Tein Super Street Coilovers and did yet ANOTHER alignment to find the power steering rack is puking oil out EVERYWHERE.. Replacing the lines and rack when I get back home and doing ANOTHER alignment.
Deciding currently on rollers... Might be ordering a set of 18x10 rota svn.
Sweet STi and what a find - unmolested. Sound like once you get a few of the things mentioned above, she will be as good as new!
2012 WRX Hatchback ISM - Base Model - STI STS, SPT Boost Gauge, AEM Intake, TP Stage 1 Tune, red illumination kit, cobb shift knob, 20% tint - currently on stock wheels wrapped in Pirelli Winter Carving Edge Tires
Some cooltidbits to come...
Looks nice!
I just put a Nameless axle back on my 09 with 4" mufflers and it's a lot louder than I thought it would be. It sounds good at idle and howls at WOT with no drone at free way speeds. Good quality work, but I had to wait about a month for it because they ran out of material.
damn 18x10s??? Bit overkill isn't it?
Isaac -- 2003 WRX sedan Stg II
He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
