Lokey's 2011 WRX (SWP Hatch) - Page 34
Page 34 of 40 FirstFirst ... 2425262728293031323334353637383940 LastLast
Results 496 to 510 of 596
This is a discussion on Lokey's 2011 WRX (SWP Hatch) within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by lokey AP, bro. Switch to 93 map when needed. I can't seem to find your dyno numbers ...
  1. #496
    Registered User wrx650's Avatar
    Feb 2012
    Cleveland, OH
    Quote Originally Posted by lokey View Post
    I can't seem to find your dyno numbers for 93. What are they?
    -Noah
    2009 Spark Silver Metallic Sedan - Stage 2+
    Stink-Eye Mob #91
    Help Me with My Build Thread : http://www.clubwrx.net/forums/builds...wrx-sedan.html
  3. #497
    Feb 2012
    Cleveland, OH
    S205?
    -Noah
    Stink-Eye Mob #91
  4. #498
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Quote Originally Posted by wrx650 View Post
    Old clutch, old injectors, but here is my comparison graph on my first E85 tune. Dotted lines are 93. *My clutch was slipping*
    Latest is on my home PC. I'll post it soon.
Name:	Lokey HPTQ 93vsE85.jpg
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
  5. #499
    Registered User nopistons93's Avatar
    Sep 2011
    Norfolk
    Not bad gains with E85. What injectors do you have now again?
  6. #500
    Palmyra, NJ
    Sorry...meanst S204 seats.
  7. #501
    Feb 2012
    Cleveland, OH
    Those look like they're more comfortable than the bobcat.
    -Noah
    Stink-Eye Mob #91
  8. #502
    Palmyra, NJ
  9. #503
    Feb 2012
    Cleveland, OH
    Thanks. Reason I'm curious is that I want to take a similar mod path to yours, but E85 isn't so plentiful here. I am just seeing if it is worth investing in a new top mount, injectors, and fuel pump if I won't be getting much out of it. BTW, the side mirrors look sweet with the vinyl.
    -Noah
    Stink-Eye Mob #91
  10. #504
    You're not going to see E85 gains by any means, but the TMIC can increase the midrange a little bit, and if you have an intake, the injectors can allow you some decent gains in the top-end. If no intake, you have a safety margin in terms of headroom, which isn't a bad thing.
    Because of the TMIC, you're typically able to run a bit more aggressive tune; higher boost due to lower pressure drop / increased ignition advance due to lower IATs (though, without relocating the sensor, you'll still have compensation tables be off). The additional airflow with an intake typically requires me to taper boost a bit more aggressively up top when mapping out a car in order to keep IDCs in check (without that restriction, some decent power can be gained).
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  11. #505
    Sep 2011
    Norfolk
    I think I'm just going to do E85, especially after lokey told me how easy it is to switch back and forth if required.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  12. #506
    Feb 2012
    Cleveland, OH
    Thanks! I have an intake right now. I will probably hold off on this stuff for a bit, but it does sound like it would be pretty noticeable when I do eventually do it.
    -Noah
    Stink-Eye Mob #91
  13. #507
    See below:
    2011 Subaru STI stage 2 plus intake. Before/After intake test. - NASIOC
    The TMIC difference isn't a factor (and you may see more power with an aftermarket one), and I doubt much of the upper RPM gains are due to the DAVCS (Intake/Exhaust - STI) vs AVCS (Intake - WRX).
    Quote Originally Posted by nopistons93
    E85 is a great source of fuel if you have ready access to it regularly. If you don't, methanol is better. If you don't go the methanol route (the kits are expensive), a good ELH would make some good gains (both on 93 and E85).
  14. #508
    Feb 2012
    Cleveland, OH
    See below:
    I already have the intake installed and tuned for. I wouldn't mind having some extra space in terms of injector duty. I was at like 95% the last time I logged if i remember correctly. Anyway, now I want meth -_- and sorry for thread-jacking, Lokey
    -Noah
    Stink-Eye Mob #91
  15. #509
    Jan 2011
    Crofton, MD
    No worries. I love good E85 pondering, so it's not thread-jacking here.
    So, this is not the final graph (just sent Agile a wtf email, waiting for Hill to send the final comparison graph), and doesn't show my comparison of 93 to E85, just E85. It does show pretty much what I ended up with after the new clutch. Notice the extra ft-lbs. I have a paper copy of my final and could take a pic of it if you need to see it now.
    Also, I switched from DW to ID injectors. I can chat about my experience with DW injectors and their customer service shortfalls via PM. Let me just say this publicly - Don't get DWs. Get IDs.
Name:	Lokey HPTG E85 JPEG.jpg
    Greg
    Build Thread
  16. #510
    Feb 2012
    Cleveland, OH
    Thanks. You're not the first person I have heard recommend ID injectors over DW. I am.gonna get some ID 1000 so I can run E85. There are a couple stations about 15 minutes from where I will be living so I probably will go ahead and do it come next summer.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    -Noah
    Stink-Eye Mob #91
