Page 3 of 30 FirstFirst 12345678910111213 ... LastLast
Results 31 to 45 of 437
This is a discussion on Lokey's 2011 WRX (SWP Hatch) within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by EJ257 Every dyno reads differently. I'm not that familiar with Agile's dyno (other than the fact it's ...
  1. #31
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Every dyno reads differently. I'm not that familiar with Agile's dyno (other than the fact it's a Dynapack), so I'm not sure how to interpret the #s. Without a before/after comparison, it's also difficult to interpret (area under the curve difference). That said, ~40whp peak gains seems about on par with StageII+Intake/TMIC.
    The only thing I don't like about the plot is the dip I mentioned, but it sounds like it will be addressed at a later date.
    The 'before' lines are actually on that crappy scan. The lines are just too thin and light for this POS scanner to pick up. I should have the electronic file posted by Monday...
    Greg
    www.modmeets.com
    ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
    Mods Blog Post
    Friends don't let friends drive Mitsubishis.
  2. #32
    Jan 2011
    Crofton, MD
    Quote Originally Posted by T0rque View Post
    Your right, it isnt an STi.. But I wasnt bashing on WRXs. Anyway, its a clean car and you have chosen some nice mods for sure.
    Thanks, man....just messing.
    Greg
    www.modmeets.com
    Mods Blog Post
  3. #33
    Quote Originally Posted by lokey
    Once you get done with any touch-ups, post up a 3rd gear log with just RPM/Boost logged
  4. #34
    Jan 2011
    Crofton, MD
    Will do.
    Greg
    www.modmeets.com
    Mods Blog Post
  5. #35
    Jan 2011
    Crofton, MD
    Just an update: So my Forge BPV came in and got installed the other day. Now that I can safely do some WOT pulls, I'll try to get some data logging done tomorrow or over the weekend.
    As for the boost plot and dip in the 3800-4400 RPM range, here's a bit from an email I got from Agile yesterday:
    "Unfortunately the MAP sensor (boost) on the dyno is broken so I don’t have a boost graph from the dyno, but Hill has been using the Cobb software to log boost while he’s tuning. He said you could do a pull while datalogging with the AP and then use Excel to graph it pretty easily. He said you should be tuned to around 20.5psi. And he said that the dip in the graph is most likely a flow dynamics issue. He sees it on most of the new model WRX’s and his guess is it’s something with the intake manifold design (but no hard proof to confirm that)."
    Attachment 100424
    Greg
    www.modmeets.com
    Mods Blog Post
  6. #36
    Registered User Eric05mx's Avatar
    Oct 2010
    PA
    Now that you had the chance to run the car hard do you feel it was worth the money over just Cobb stage 2?
    Also, did you install 1 step colder plugs? Hill told me it's not required but more of a safety factor.
    I'm still on the fence about placing my order for a Process West tmic, Perrin EBCS, Forge Motorsports bov, and heading to Agile for a protune.
    2012 WRX ice silver metallic
    Protuned by Agile Auto 315whp/342wtq @ 20.5psi
  7. #37
    Jan 2011
    Crofton, MD
    Definitely. In my opinion, it just pays to have the protune, if nothing else. Aside from the serious boost in hp an tq across the entire power band, the elimination of knock (which I was unaware of) and smoothing out those little fluctuations in the curves made it worth it. I'm not saying that Cobb's OTS tune is bad, it's just not made specifically for your car, and therefore should be tweeked. I can feeel the difference even when driving normally, especially in the smoothness of the initial acceleration. My wife even said "the car feels less jerky."
    As for spirited driving, oh yes, I can definitely feel (and hear) it. Take a look at the steepness of the torque line. 320+ ft/lbs of torque at 3500 RPMs is really nice! I'm still getting used to hearing that compressor surge sound, though.
    Greg
    www.modmeets.com
    Mods Blog Post
  8. #38
    Oct 2010
    PA
    Sounds good, thanks for the information. If you don't mind, where did you get the Process West? I'm shopping around for the best deal. $925 shipped is the lowest I found.
  9. #39
    Jan 2011
    Crofton, MD
    preracing.com...but call them for pricing.
    Greg
    www.modmeets.com
    Mods Blog Post
  10. #40
    Oct 2010
    PA
    Quote Originally Posted by lokey View Post
    Thanks man.
  11. #41
    Jan 2011
    Crofton, MD
    https://docs.google.com/open?id=0B-U...EwOTI2YmY0NWU2
    Greg
    www.modmeets.com
    Mods Blog Post
  12. #42
    For what I was looking for, just Throttle Position, RPM, and Boost should be logged. It will give better resolution = better graph
  13. #43
    Jan 2011
    Crofton, MD
    Greg
    www.modmeets.com
    Mods Blog Post
  14. #44
    Take a new datalog with just RPM, PSI, and TPS logged for me when you have a chance
    Sent from my Droid using Tapatalk
  15. #45
    Jul 2011
    West Chester, PA
    Super clean, and nice numbers!
    How are the Epics holding up on the stock struts?
