Lokey's 2011 WRX (SWP Hatch) - Page 20
Page 20 of 40 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 286 to 300 of 596
This is a discussion on Lokey's 2011 WRX (SWP Hatch) within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by lokey Import Face-Off, Crofton, MD - Best Subaru How many of them were there?...
  1. #286
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by lokey View Post
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  3. #287
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Apparently, I was the only Subaru there. :-P
    Not sure. I think the ”ringers” were at wekfest.
    Sent from my Android using Forum Runner
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
  4. #288
    Jan 2011
    Crofton, MD
    My clutch has had enough and is starting to slip at wot in 4th and 5th. I plan to go with the ACT HD.
    Greg
    Build Thread
  6. #289
    U.S. Combat Veteran (3ID) Stu_Gotti's Avatar
    Jan 2011
    Southern Maryland
    I'm getting the PFFFE and P0301-0304 :/
    My Build : IAG Closed Deck Stage 2.5 ~ 427hp/399tq | Facebook | I may appear calm, but in my head I've killed you three times
  7. #290
    Jan 2011
    Crofton, MD
    Quote Originally Posted by Stu_Gotti View Post
    When did the code happen? Rough idle?
    ...I think it's the RA mudflaps.
    Greg
    Build Thread
  8. #291
    Mar 2011
    Hey Greg, have you ever had any issues with the PW TMIC vibrating at low idles? Mine vibrated at 600 rpm. I raised the idle to 900 rpm with the AP and its fine there.
  9. #292
    Jan 2011
    Crofton, MD
    Quote Originally Posted by Asharus View Post
    Somewhat, before I got tuned. Now my idle is above 1,000, so no more roughness. It's no big deal if it vibrates a little and is a really just the nature of any top mount - all the solid mounting points are at the motor and/or bell housing, not the frame. Think about how much it moves when you hit harsh bumps and such. Just be sure to tighten everything down, especially the cold side hose. I degreased the inside of all hoses and used t-clamps for all 4.
    Greg
    Build Thread
  10. #293
    Mar 2011
    Yeah, one of them already blew off a while ago, the cold side to the TB, so we replaced the clamp. I should really replace all of them...
    Then over the summer I noticed there was a squeaking noise when idling with the A/C on. We figured out it was the BPV rubbing against the hood scoop shroud that came with the PW when the TMIC was vibrating at 600RPM. We raised the idle to 900 ish and all is well.
    Thanks for the info.
  11. #294
    Jan 2011
    Southern Maryland
    Those damn flaps... lol... yea this morning I was trying to head to work and on my way in, literally just outside my condo complex, the car started to get really sluggish when I gave it gas. I turned it around and tried to see if it would work itself out, thought perhaps it was just too cold out. I eventually reflashed the ECU with the Cobb Stage 2 +SF 93 map and it didn't get any better, in fact it was a little worse for a bit. It wouldn't turn over all the way a few times before it would barely come to life before bogging down and I'd shut it off. Got a tow truck coming tomorrow to take it up to the dealership to have them take a look at it. If I had the time I'd try to do it myself but I looked it over and I couldn't find anything noticeable.
  12. #295
    Jan 2011
    Crofton, MD
    That sucks, man. I assume the filter and MAF sensor are clean. I had some pretty serious knock and idle issues on that map as well, so I may not be the best source of optimism. So you think the dealership (assuming Annapolis) is going to check it out if its stage 2+? Just for the sake of it, I went to them a few weeks ago to see if they'd give me a new clutch, since it was slipping. I realized, as they were holding back their laughter, that corn fed stage 3 cars may not qualify for clutch warranty coverage.
    Greg
    Build Thread
  13. #296
    Palmyra, NJ
    I'm calling clogged fuel filter! Replace that bish!
    Hope you work it out...Bruce (DemonWRX) is dealing with some mayhem right now as well
  14. #297
    Jan 2011
    Crofton, MD
    Any updates?
    Greg
    Build Thread
  15. #298
    Jan 2011
    Southern Maryland
    Any updates?
    Well got the car back and of course I left everything as is. Towed it to Annapolis Subaru ($138) and they called me back a few hours later saying it was done. Asked what they did they told me they uninstalled the AP and 'recalibrated the ECU' but left it with the stock map. I flashed the same stage 2 + SF map back in the Subaru dealership parking lot before leaving and drove the hour and half back South with no issues and none since. Honestly don't know, basically paid another $137 to them to 'hook it up to the machine.' I mean I'm not all too mad about that but $137 is a bit steep if you ask me. Going to call and talk with the service manager probably Tuesday. I believe he is the guy I talked to when they called me to tell me it was ready. I told him I wanted to get my throw-out bearing checked out and said that wouldn't be covered under warranty with the stuff I had done... which I thought was a little bit on the side of BS... nothing I have done, at least I don't think someone correct me if I'm wrong, should have a negative impact on a throw-out bearing chattering. I guess I'll have to get myself a new fuel filter and probably a few other small items and just get a protune done and call it a day. I'll focus on suspension after that.
  16. #299
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    You guys are cute thinking your warranties mean something.
    Lead Wrench @ WTF Tuning, LLC
  17. #300
    Jan 2011
    Southern Maryland
    Quote Originally Posted by T0rque View Post
    Haha this is true.. I preach it.. gotta pay to play.. but sounds like I just need to pay to play the better way.. moar custom tune!
