When ocd meets opportunity ..... The 91 Legacy ss project - Page 3
Page 3 of 14 FirstFirst 12345678910111213 ... LastLast
Results 31 to 45 of 208
This is a discussion on When ocd meets opportunity ..... The 91 Legacy ss project within the Builds forums, part of the Tech & Modifying & General Repairs category; Awesome project!...
  1. #31
    Registered User Ampliified's Avatar
    May 2012
    Warren Twp, NJ
    Awesome project!
    2012 DGM WRX - Stage Two 93 - Stink Eye Mob #908
    The Epic Life of Emily the WRX
  3. #32
    Registered User 22B05STI's Avatar
    Dec 2008
    Monterey California
    Interior:
    ·         Momo Cobra three spoke steering wheel
    ·         RA specific seat fabric (velour inserts the same as RS)
    ·         Low grade headlining
    ·         Deletion of passenger visor vanity mirror
    ·         Manual windows (RS – power windows)
    ·         Manual locking (RS central locking)
    ·         Air conditioning – factory option – none climate control version (RS – climate control)
    ·         Addition of rear scuttle brace (TBC)
    Exterior:
    ·         Rear spoiler deletion
    ·         Rear windscreen wiper washer deletion
    ·         Black side skirt deletion
    ·         Black, manual adjustment side mirrors (RS power mirrors)
    ·         Manual radio aerial – located at top of right A pillar (RS power aerial – rear left flank)
    ·         Blue tinted glass (RS Bronze)
    ·         Paint colours:
    o    Type A: Ceramic white#57
    o    Type B: Ceramic white#57
    o    Type C: Feather white#30
    o    Type D: Feather white#30  or Black mica#52
    Engine:
    ·         Internal:
    o    Hand built / blue-printed engine by STi
    o    Crank shaft, flywheel and clutch cover - balanced and hand finished
    o    Cylinder heads and intake manifold  - hand finished / casting lines and gaps removed / polished
    o    Forged pistons
    o    Forged connecting rods
    ·         Turbo (TBC):
    o    Turbine rotor diameters(in/out): 52.5 / 46.5 (RS: 52.5 / 43.0)
    o    Compressor Impellers diameters(out/in): 56.0 / 45 (RS: 56.0 / 41.2)
    o    Maximum boost pressure: 450 Hg (RS – same)
    o    Intercept point: 2,800rpm (RS: 2,400rpm)
    o    Turbine blades: 10 (RS: 9)
    ·         External:
    o    Gold painted cam covers
    o    Gold painted intercooler reservoir
    o    Intake manifold cover - deleted
    o    Twin electric radiator fans (larger capacity than RS)
    ·         Output:
    o    Power: 220 PS @ 6,400 rpm (RS: 200 PS @ 6,000rpm)
    o    Torque: 27.5 KG m @ 4,000rpm (RS: 26.6 KG m @ 3,600rpm)
    Transmission:
    ·         Close ratio gear set (Types B – D only)
    Chassis:
    ·         Aluminium sump guard – custom sub frame mounting bracket and side splash guards (plastic)
    ·         Deletion of under body sound deadening
    ·         Hardened bushes (STi grade - except rear differential mount, trailing arms, and stabilizer bars)
    ·         Hardened coil springs (measure is: KG / mm) – Front: 3.2 / Rear: 2.85 (RS: Front: 2.51 / Rear: 1.89)
    ·         Revised damper rates (measure is: pull/push and 0.3m/sec) – Front: 190 and 140 / Rear: 130 and 85 (RS: Front: 126 and 31 / Rear: 82 and 25)
             Adoption of an advan "GROVA" high grip tyre
    ·         Quicker steering ratio / rack
    ·         Deletion of driver / switch operated ‘variable assistance’ power steering
    ·         Deletion of ABS system
  4. #33
    Dec 2008
    Monterey California
    Here is a little about the real legacy RSRA
  5. #34
    Dec 2008
    Monterey California
    And here is a real RS Type RA in New Zealand
    LEGACY RS type R & type RA
    ●RS-R
    The debut of first Legacy was the end of January, 1989 (February 1 release). The turbo car was only sedan RS of 5MT at first.
    In October, the same year, RS-R is added in accordance with a debut of GT which is a turbo car of a wagon (and 4AT version of sedan RS).
    It is written with "a basic grade model of RS which is suitable as the material of a competition car for motor sports" and a new car commentary book.
    RS-R、Atype
    ●RS-RA
     In November, '89 (December 1 release), pure competition car base for motor sports, RS-RA of a STi tune appear.Therefore the position of RS-R became considerably vague debut two months later.
    It is written with a new car commentary book with "the order production RA memory model that executed engine fine-tuning same as the challenge car that 100000km speed records RS-R in a base."
    RA seems to mean, 100000km speed record challenge "RECORD ATTEMPT" instead of RA of Rally.
    (There is an opinion that RA means "Race groupA")
    RS-RA put a fine tune to a rally and a dirt trial competition to be based on RS-R more.
    As for the engine, forging piston and high resist pressure connecting rod metal are built in, and, as for the intake port and exhaust port, it is revised gap and polished up.
    A crankshaft and the flywheel which got of balance are mounted the car with.If it is a beginner's class level, suspension is strengthened to the rank who can participate as it is.Variable ratio power steering is important, too.As for this, the steering gear ratio becomes quick.
    Without close ratio transmission, it was announced as 100-limited model at first.Actually, seem to have continued job-order production of 20 monthly productions.
    Long-awaited close ratio transmission was carried than a B type from May, '90, and increased with a catalogue model.
    Engine specifications do not change from a latter period model C type, but ECU becomes 16bit, and a torque up in middle low rev .(be said by an emission control that became mild) and continued to exist to the last D type, and handed over a duty of RA of legacy to impreza WRX-RA with full model change-over, and the grade of RA disappeared from legacy.
    ↑100 limitation,A-type
    ↑close ratio transmission, B-type
    ↑After minor change model C-type
    ↑Last model D-type
    Engine
    RS-R
     The engine & Transmissions are the same as RS.
    RS-RA
    based on RS-R and handcrafted RA tuning same as 100000km speed record car(RA:RECORD ATEMPT)
    crank shaft, flywheel and clutch cover hand finish balance
    induction system(cylinder head、intake manifold) hand finish repair gaps and polishing
    A gold Alumite treatment surface cam cover
    A intake mani-fold decoration cover abolition
    An inter air conditioner case special color
    A forging piston
    forging kelmet high resist pressure connecting rod metal
    A double radiator electric fan
    close ratio transmission from B type
    engine performance curve
    → Traveling performance curve of RS
    GT RS
    Maximum power PS/rpm
    Maximum torque kg・m/rpm
    200/6000
    26.5/3600
    220/6400
    27.5/4000
    compressor Impellers diameters(out/in)
    Intercept point
    number of blade 52.5/43.0
    56.0/41.2
    450mmHg
    2400rpm
    9 52.5/46.5
    56.0/45.0
    2800rpm
    10
    ■CHASSIS
    ●RS-R
    Hardened coil spring,damper and bush(equal with STi product)
    (except rear differential mount, trailing arm rear side, a stabilizer)
    Adoption of three spoke steering MOMO "COBRA"
    Adoption of an advan "GROVA" high grip tire
    The abolition of steering assist power change over switch
    ●RS-RA
     Difference with RS-R
    A variable quick power steering
     gear ratio  In going straight:15
     (over all)  In full steering :13
    Hardened coil spring、 damper
    The level that can just participate in an intermediate class rally
    Hardened bush(equal with STi product)
    (except rear differential mount, trailing arm rear side, a rear stabilizer)
    Suspension
    GT
    SEDAN
    GT
    WAGON
    RS
    RS-R
    RS-RA
    Spring rate
    (kg/mm)
    2.5-2.8 2.3
    2.51
    1.89
    2.63
    2.17
    3.2
    2.85
    Damper damping force
    (pull/push 0.3m/sec)
    126/31
    82/25
    126/31 82/25
    146/97 112/74
    190/140 130/85
    Stabilizer
    (external diameter-mm)
    17?
    19?
    18
    18
    17
    19
    ■Body color
    Apride model→ A B C D
    RS-R Ceramic white#57
    Dark blue#56 Ceramic white#57
    Indigo blue-M#13
    Black mica#52
    RS-RA Ceramic white#57 Ceramic white#57 Feather white#30 Feather white#30
    Black mica#52
  6. #35
    Palmyra, NJ
    Best build ever.
  7. #36
    Dec 2008
    Monterey California
    Best build ever.
    Thanks, I hope it has some interesting stories along the way
  8. #37
    Dec 2008
    Monterey California
    I also added some decals to the instrument cluster which pays tribute to the old McRae 555 Legacy and STI. I have a new Tach which reads higher RPM as in the RA Legacy so I will have to re apply the decals but you can see how it will look.
  9. #38
    Dec 2008
    Monterey California
    I have been doing some projects for a local guy that owns a Subaru dealership, I fitted a small block Chev in place of a straight six in his 55
    I have some Ideas and a concept to put forward to him regarding his Subaru dealershi and I hope to form a further affilliation with that dealership and hopefully lead to some interesting things in the near future. I will hopefully have some things to talk about soon
  10. #39
    Dec 2008
    Monterey California
    The Legacy is almost ready for paint, I fit the doors and new fenders and hood today. The seam welding is all finished and the jack stand mounts are now all finished
    We will be making the WRC style stands as pictured, the mounts welded onto the Legacy are for these stands!
  11. #40
    Jan 2012
    Philly Area
    We expect moar pics!
    - Will
  12. #41
    Dec 2008
    Monterey California
    This week was a big one for the Legacy project, I received all the parts from New Zealand so I now have the intercooler, intercooler cooler and pump ( cooler mounts in front of radiator, all new lines for the intercooler to the cooler, then all new coils, a rear garnish with RA badge, two new Rear bumper covers from Japan, and one new front bumper cover from Japan.
    Also a used intake complete with all the fuel lines and wiring loom.
    I also bought a six speed trans from a Japanese spec RA with Viscous center diff and Suretrac front and rear diffs. I have already stripped and cleaned the trans and fit all the parts back on it. I also disassemed the pump
    For the intercooler and will post pics of these parts soon, the intercooler and intake and pump and cooler were all used, the price these as new parts are extremely expensive, so I had to opt for used.
    Here are pictures of some of the new parts, the front bumpers in photo shows one USDM and lower bumper in photo is JDM
    Above is the new tach fitted which is the same as the RA has with 9000 RPM
    New panels on the Legacy
  13. #42
    Dec 2008
    Monterey California
    I will post more photos soon, it has been a busy week and I have not taken as many photos as I should, however I will take some more to update this build!
  14. #43
    Dec 2008
    Monterey California
    I have been making steady progress everyday, I gave the Six speed transmission a major cleanup and it looks really good now. I stripped and rebuilt the starter which came with the six speed and painted it again, I even managed to preserve and re use the decal. The intercooler pump has been re painted also and I need to get two metric o rings and it can go back together. I will try and take some pictures on Saturday of the engine bolted to the trans, It looks great.
  15. #44
    Dec 2008
    Monterey California
    I spent the last two days working on my intake manifold from an RS Legacy. So after milling of the unwanted mounts and hours and hours with a grinder in hand here's what I came up with.
  16. #45
    Dec 2008
    Monterey California
    Here's the gearbox, I am going to mock up and check all the fit of parts so there is still the engine build yet to be done
