Page 34 of 37 FirstFirst ... 2425262728293031323334353637 LastLast
Results 496 to 510 of 544
This is a discussion on Sinister's Progress Thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Sinister Sheared a brembo caliper bolt. caliper is at a machine shop as we speak Do yours ...
  1. #496
    Quote Originally Posted by Sinister
    Do yours have the bracket on them?
  2. #497
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    The kb bracket? No. I have STi spindles
  3. #498
    No, there's a support bracket on some STI calipers. They are notorious for seizing/sheering bolts during removal. Last brake job I did, both fronts seized.
  4. #499
    Boost > NA itWRXjustfine's Avatar
    Aug 2009
    Fort Riley
    What are your cold starts like in the morning? Mine are pretty bad too. How cold are the temps in the morning?
    2004 Impreza Outback Sport - Sold
    2004 WRB WRX - Sold
    2006 SGM WRX - 400AWHP - Mods
    My 2006 Build
  5. #500
    Nov 2006
    Denver Metro Area
    only like 40 degrees.
    Matt... no I don't have any brackets.
  6. #501
    Nov 2006
    Denver Metro Area
    so... "Heads By Drew" took care of the caliper. He did an awesome job. I'm overly pleased... and the price was less than I was expecting.
    I'm never changing the front rotors on my brembos again. That is the biggest son of a gun ever.
    So... since I took the caliper off... I bled a bunch of fluid. I tried just bleeding that side, but my brakes are spongier than snot. Also... the inside bleeder on the front left is stripped. That's always nice. I'm to the point where I just want someone else to do it. I'm not able to drive my car though!
  7. #502
    May 2010
    Pittsburgh, PA
    Re: Sinister's Progress Thread
    I always have to bleed each caliper a few times to get the air out.
    Make sure you open each bleeder slowly and only as much as required.
    Also.. Keep in mind you may have to pump your brakes a few times initially just to get the pads to close the distance to the rotors.
    If you are using a power bleeder keep the pressure under 15psi to avoid little micro bubbles.
    It's almost a game to get all the air out of them regardless of what order you do it in. Just keep trying and make sure you have some extra fluid. It's very frustrating though, I agree.
    I am hoping my rotors last a long time. Long enough that I will just get the KNS bbk for the fronts. It's ridiculous how easy those strip.
    2011 STi Build Log
  8. #503
    Mt. Laurel, NJ
    Those things ****ing suck! I have no idea how I didn't sheer my fronts bolts...
  9. #504
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    I have support brackets on mine, used antiseize when inserting bolts.. Doubt it'll help. As for brake bleeding brembos.. Yea dont ****in use a power bleeder, you just need to do each by hand a couple times unfotunately
    Lead Wrench @ WTF Tuning, LLC
  10. #505
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by T0rque View Post
    I've had to use the power bleeder a few times due to not having a second body to press the pedal at 4am. It'll work, just keep the pressure low or you get micro bubbles. That being said... I always would use a second person and do it normally.
    2011 STi Build Log
  11. #506
    Dec 2004
    Your Mommas
    I've used 3 different power bleeders I have and finally to get my sponginess to go away I put a person in the drivers seat, up on the lift all wheels off, all bleeders shut and each bleeder by hand twice then do it all again. Pedal is like a rock now
  12. #507
    May 2010
    Pittsburgh, PA
    Good stuff dude.
    Provided the pads are extended (after a pump or two), mine normally has about an inch of pedal travel before feeling like a rock.
    I hope the mini Cooper we were working on shows better results with a traditional flush. Otherwise it has two or three inches before settling to its (stable) compressed state.
    2011 STi Build Log
  13. #508
    Nov 2006
    Denver Metro Area
    girlfriend's leg got tired. It's not unsafe now... I can drive it. But it definitely isn't as good as it was.
  14. #509
    May 2010
    Pittsburgh, PA
    Just keep trying. Sometimes those rears cough up bubbles long after expected. It'll clear up.
    2011 STi Build Log
  15. #510
    Dec 2004
    Your Mommas
    Why did you remove the calipers? Oh yea you broke a bolt..
