Holy Smokes... I've never made one of these. I should have. I've had the car since 2006 when I got back from Iraq. Kind of a present to myself. Since then it's been a massive money pit... Incredibly fun... and an insane learning project. I've finally got the funds, room, and garage together to be able to turn her into a toy that I can drive to work, and then to the track! Should be a fun close to 400whp e85 beast
I've gotten almost all of the parts from WRXPro.com, TiC, and a few from RallySportDirect.
Update:
Just got done with the new tune. Made 430/429whp
Updated Mod List (9/4/12):
Still to install:
Volk Aluminum Hubcentric Rings
Subtle - Saggy Butt Shims
Currently:
Engine Bay:
EJ25 Block with D25 Heads
Nitride Crank
STi Forged Rods
CP Forged Pistons
ARP Headstuds
Suba Performance built the engine.
K&N Typhoon Short Ram Intake
Blouch 1.5XTR 10cm with 15psi IWG Actuator
Walbro 255lph Fuel Pump
Processwest TMIC w/ Silicone piping and Shroud
SPT Radiator Shroud
Cobb Turbo Heatshield
Grimmspeed Air Old Separator
NGK -1 Plugs
Perrin Inlet
ID1000cc Injectors
Perrin Fuel Rail
Grimmspeed EBCS
Grimmspeed TGV Deletes with Coating
Grimmspeed Phenolic Spacers + Gaskets
Grimmspeed Intake manifold PnP with Coating
Grimmspeed Exhaust Manifold Pnp with High Flow Crosspipe and Coating + gaskets
Invidia heatwrapped v2 downpipe
Hanksville Hotrods Custom Catback
killer b oil pickup
Protune by Eric Minehart of Torqued Performance
Carbon Fiber Hood Struts
Traction Bits:
Enkei 17x8 45et RPF-1 Wheels
245/40/17 Hankook Ventus V12 Evo K110 Summer Tires
225/45/17 Bridgestone Blizzak LM-60 Winter Tires
STi Pink Springs
Cobb 25mm R Swaybar
Perrin 22mm F Swaybar
Perrin Spherical Bushing Endlinks
Eibach Camber Bolts
SPT F/R Strut Tower Bars
Brakes:
Brembo Calipers
Hawk HPS Pads
Goodrich SS Lines
ElF DOT 4+ Fluid
Drivetrain:
6spd STi Transmission
DCCDPro
ACT Streetlight Flywheel
ACT XTSS Clutch
STi Factory Short Shift Linkage with Kartboy Shortshifter Bushings
KB Front/Rear Shifter Bushings
TiC Shifter Linkage Bushings
KB Outrigger Bushings
KB Subframe Lock Bolts
Group N Engine Mounts
Group N Tranny Mount
TiC Tranny Crossmember Bushings
KB Pitch Stop
Interior:
Scroth QuickFit Pro Racing Harness
STi Shift Knob (Not OEM... the one from the STi/SPT Catalog)
STi Aluminum Shifter Bezel
STi Gauge Cluster
AccessPORT v2 mounted next to gauge cluster
Pioneer AVIC - F90BT
STi Floor Mats (Black)
Escort Passport 8500 Radar Detector Hardwired
OEM Style Dead Pedal
Exterior:
JDM Legacy STi Badge
GM Flexfuel Badge
RetroQuik HID Retrofit: D2S BiXenon HID Projectors with 5000k Morimoto Bulbs
STi License Plate Delete
Grimmspeed License Plate Relocation Kit
Tint
WRXPro.com Vinyl Decals on rear windows
High Output PIAA Ion Yellow Fog Lights
Update:
Still to install:
Currently:
Engine Bay:
Nitride Crank
STi Forged Rods
CP Forged Pistons
ARP Headstuds
SPT Radiator Shroud
NGK -1 Plugs
Perrin Inlet
ID1000cc Injectors
Perrin Fuel Rail
Grimmspeed EBCS
killer b oil pickup
Traction Bits:
STi Pink Springs
Cobb 25mm R Swaybar
Eibach Camber Bolts
Brakes:
Brembo Calipers
Hawk HPS Pads
Goodrich SS Lines
ElF DOT 4+ Fluid
Drivetrain:
DCCDPro
ACT XTSS Clutch
KB Pitch Stop
Interior:
STi Gauge Cluster
Exterior:
GM Flexfuel Badge
Tint
