Sinister's Progress Thread - Page 2
Page 2 of 37 FirstFirst 123456789101112 ... LastLast
Results 16 to 30 of 544
This is a discussion on Sinister's Progress Thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by MainFrame I don't think the OEM pickups are even welded where they tend to fail, they're brazed.. ...
    Registered User fahr_side's Avatar
    Apr 2010
    I don't think the OEM pickups are even welded where they tend to fail, they're brazed.. cheap bastards.
    Sorry, yes... you're correct. They tend to crack several mm away from the joint, because the steel tube is thin and brittle. You can see from the bluing they overheated the part while brazing it and allowed it to become too brittle by letting it cool too quickly. Piss-poor workmanship.
    Happiness isn't just around the corner, it is the corner.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    You folks are the first I've heard of this. I'm going to have to do some Nasioc research, because I don't believe I've seen any high hp cars that I've noticed an aftermarket oil pickup on.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by fahr_side View Post
    This is exactly it! They always crack away from the actual joint, and the coloration makes it clear that the tubes have been way overheated. Which is funny, because you don't have to get something that hot to braze.
    Broken OEM Oil pickup... Pictures - NASIOC
  6. #19
    Registered User c2bcoolwrx's Avatar
    Mar 2008
    SFLA
    Yes, they are brazed (forgot that)...complete crap. They do it because it is cheap.
    I actually had a metal shop class in HS and learned how to weld (mostly spot welding and I think arc welding, cannot remember if we did any mig or tig welding). Welded car parts for the autoshop class and our teacher was and expert at it. Been a long time since I have welded anything (over 12 years) and I am sure I would suck at it now.
  7. #20
    Nov 2006
    Denver Metro Area
    It sounds like this issue is few and far between... I'm not 100% as to whether or not I'm going to do this.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  8. #21
            MainFrame's Avatar
    Austin, TX
    I'm going to be getting an ej257 pan, KillerB ultimate pickup, and KillerB windage tray in the future.. it's just good insurance. Besides, I have actually seen my OEM pickup suck air when cornering before, so I know it's something I need to get done before long.
  9. #22
    Nov 2006
    Denver Metro Area
    you've seen the pickup suck air? How...
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  10. #23
    Apr 2010
    Trunkmonkey has a cousin....
  11. #24
            MainFrame's Avatar
    Austin, TX
    Oil pressure gauge.. I took a corner, and the needle dived about 20psi. I guess I didn't physically see it suck air, but I knew the bubble was there, being forced through my bearings. The ej205 pan is so flat and shallow the oil sloshes side to side when cornering.
  12. #25
    Mar 2008
    SFLA
    Ya the 2.5L oil pans EJ255/EJ257 are a better design that allow better flow and a better baffle (windage tray), which allow the oil pickup to gain more access to the oil. Also, I believe the KillerB oil pickup also sits a bit lower in the pan again increasing its ability to gather oil.
    Pretty much All subarus are made with the crappy oil pickup, so it is a great upgrade IMHO.
    Here is a great thread on differences between oil pans:
    WRX oil pan vs STi oil pan
    If you want the highlights and most of the info skip to post #36, but the entire discussion is a good one.
  13. #26
    Nov 2006
    Denver Metro Area
    Back on it...
    Installed the KB Botox Bolts the other day. Definitely got rid of the bang between hard shifts. Thank goodness.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  14. #27
    Nov 2006
    Denver Metro Area
    trying to decide between 20gxt and 20gxtr
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  15. #28
    Aug 2010
    I had a motor go down on a broken pick up. I watched my defi oil gauge twitch a few times and whammm..
    I am running a killerbee pick up, pan and cosworth windage tray on my cosworth motor.
    2006 wrX
  16. #29
    Boost > NA itWRXjustfine's Avatar
    Aug 2009
    Fort Riley
    So is it a good idea to take your brazed pickup and put a weld on it or just get an aftermarket unit all together?
    2004 Impreza Outback Sport - Sold
    2004 WRB WRX - Sold
    2006 SGM WRX - 400AWHP - Mods
    My 2006 Build
  17. #30
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    I actually have summers right now... missed that. Updated
    How do you like those Hankook? I'm thinking of picking some up as my tires are toast. Those seem to be my best bet, good ratings and cheap.
