Page 16 of 37 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 226 to 240 of 544
This is a discussion on Sinister's Progress Thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Sinister Originally Posted by Sinister Not bad. Similar torque peaks and minimal hp drop as you approach ...
  1. #226
    Quote Originally Posted by Sinister
    Not bad.
    Similar torque peaks and minimal hp drop as you approach redline.
    Looks like a solid DD...
  2. #227
    Mt. Laurel, NJ
    Very nice numbers...good smooth curve and peak.
  3. #228
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Thanks guys!
    I haven't been on much lately, because I'd rather be driving
    Thing is unbelievable. Crazy part is the noise. I have so much interior drivetrain noise with absolutely no exhaust note. Our engines sound incredible on the group N mounts. And the rear diff outrigger mixed with botox bolts, mixed with group N engine mounts, mixed with TiC crossmember bushings... I can hear so many transmission noises, it's not even funny. I had to sound cliche, but the damned thing sounds like a rally car from the inside.... but quiet enough that I can have a conversation
  4. #229
    Driveline stuff is fun.
    Up next: trailing arm / lateral link bushings
  5. #230
    Nov 2006
    Denver Metro Area
    Updated Mod List:
    Still to install:
    Shift Linkage bushings
    KB Rear Diff Bushings
    Volk Aluminum Hubcentric Rings
    Subtle - Saggy Butt Shims
    RetroQuik HID Retrofit
    Currently:
    Engine Bay:
    K&N Typhoon Short Ram Intake
    Blouch 1.5XTR 10cm with 15psi IWG Actuator
    Walbro 255lph Fuel Pump
    Processwest TMIC w/ Silicone piping and Shroud
    SPT Radiator Shroud
    Cobb Turbo Heatshield
    Grimmspeed Air Old Separator
    NGK -1 Plugs
    Perrin Inlet
    DW 1000cc Injectors
    Grimmspeed EBCS
    Grimmspeed TGV Deletes with Coating
    Grimmspeed Phenolic Spacers + Gaskets
    Grimmspeed Intake manifold PnP with Coating
    Grimmspeed Exhaust Manifold Pnp with High Flow Crosspipe and Coating + gaskets
    Stock STi Catback
    Grimmspeed 3" to 2.5" Gaskets/adapter
    Invidia heatwrapped v2 downpipe
    Protune by Harvey Epstein at Boost Creep LLC
    Traction Bits:
    Enkei 17x8 45et RPF-1 Wheels
    245/40/17 Hankook Ventus V12 Evo K110 Tires
    STi Pink Springs
    Cobb 25mm F/R Swaybars
    Perrin Spherical Bushing Endlinks
    Eibach Camber Bolts
    SPT F/R Strut Tower Bars
    Brakes:
    Brembo Calipers
    Hawk HPS Pads
    Goodrich SS Lines
    ElF DOT 4+ Fluid
    Drivetrain:
    6spd STi Transmission
    ACT Streetlight Flywheel
    ACT XTSS Clutch
    Kartboy Shortshifter with Bushings
    KB Front/Rear Shifter Bushings
    KB Outrigger Bushings
    KB Subframe Lock Bolts
    Group N Engine Mounts
    Group N Tranny Mount
    TiC Tranny Crossmember Bushings
    KB Pitch Stop
    Interior:
    STi Shift Knob (Not OEM... the one from the STi/SPT Catalog)
    STi Aluminum Shifter Bezel
    STi Gauge Cluster
    AccessPORT v2 mounted next to gauge cluster
    Pioneer AVIC - F90BT
    STi Floor Mats (Black)
    Escort Passport 8500 Radar Detector Hardwired
    OEM Style Dead Pedal
    Exterior:
    STi License Plate Delete
    Grimmspeed License Plate Relocation Kit
    Tint
    WRXPro.com Vinyl Decals on rear windows
    High Output PIAA Ion Yellow Fog Lights
  6. #231
    Administrator TheJ's Avatar
    Dirty South
    She is mighty sweet Kevin
    -The J
    New Members, CLICK & BOOKMARK these links:
  7. #232
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    Congrats on those numbers, let's see what the STi produces at sea level
    Lead Wrench @ WTF Tuning, LLC
  8. #233
    Nov 2006
    Denver Metro Area
    Thanks Guys.
    Bo... are you going with the same turbo?
  9. #234
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    That's awesome! Congrats!
    <-------- Taylor Swift.
    99.5 Jetta...I hear they make 90 to the wheels....
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  10. #235
    Dec 2004
    Your Mommas
    Thanks Guys.
    Yea I am going to get that turbo, different intercooler tho.
  11. #236
    Mt. Laurel, NJ
    pics or it didn't happen Kev
  12. #237
    Apr 2007
    8000' up in Colorado
    That's a pretty short mod list. When are you going to really start modding it?
    Scott
  13. #238
    Oct 2005
    Late Devonian
    Nice!
    Of the mods I've done (not really many) the trailing links were the most entertaining process. I usually tend to curse at my car until I force it to be fixed, but that was more of a "holy **** I can't believe this is working" all of the way.
  14. #239
    Nov 2006
    Denver Metro Area
    Installed that godblessed KB oil pickup today. Totally not worth it. Mine looked to be in PERFECT shape. No heat marks, or anything similar to the ones that people were concerned about failing, or had failed.
  15. #240
    Registered User 2002_wagon's Avatar
    Feb 2009
    Orlando, Fl
    Just so you know ur car is my cars role model lol. Good stuff man I may be moving back up there with my family as soon as I finish this contract.
    278whp 286tq blouch 16g @ 17.5psi
    "My 02 wagon build" http://www.clubwrx.net/forums/everyd...gon-build.html
    Operation Iraqi Freedom x3
    WRX wagon MAFIA #68
