The Busted Bugeye
Page 1 of 3 123 LastLast
Results 1 to 15 of 39
This is a discussion on The Busted Bugeye within the Builds forums, part of the Tech & Modifying & General Repairs category; UPDATED - 12/28/15 2002 Subaru WRX Engine/Power Mods: modified "big plenum" short runner N/A Legacy intake manifold 75mm Boomba Racing ...
            MainFrame's Avatar
    Austin, TX
    The Busted Bugeye
    UPDATED - 12/28/15
    2002 Subaru WRX
    Engine/Power Mods:
    75mm Boomba Racing DBC throttle body
    75mm Straight Adaptor DBC weld on
    8mm GrimmSpeed phenolic spacers
    TGV deletes, dividers intact
    ej205 (s20) heads, chamber modified for 2.5L, intake valves deshroud, and bowl blend
    Ferrea Super Alloy valves intake & exhaust, +1mm, radius valve job
    GSC Custom non-AVCS Cams (272 / 234@ 1mm / Peak Lift 10.60mm intake, 10.65mm exhaust)
    GSC Power-Division Beehive Valve Springs w/Titanium Retainers
    Injector Dynamics 1700cc Top Feed injectors
    Aeromotive A1000-6 Injected Bypass Adjustable Fuel Pressure Regulator
    Walbro 485 Fuel Pump in tank
    Aeromotive Billet Electric Fuel Pump Controller (10ga wire from battery)
    -6 Aeroquip Startlite Racing Hose from the bulkhead on the fuel tank, all the way around back to the return hard line
    Aeroquip AN fittings all around
    Aeromotive fuel pressure gauge
    Aeromotive Top Feed Fuel Rail Kit
    Fore Innovations F-10 Inline Modular Fuel Filter (10 micron stainless steel filtration media)
    ej257 blueprinted case halves
    balanced ej257 crank
    Pauter X-Beam connecting rods
    ARP rod bolts
    Arias custom 99.54mm pistons with offset wrist pins, and molly coated skirts (~9:1 compression ratio over all)
    11mm STi oil pump deburred and one shim
    KillerB aluminium oil pan
    KillerB Ultimate Oil Pickup
    KillerB Windage Tray
    King main bearings
    ACL Race Series rod bearings
    ARP 625+ Custom Age head studs
    JE OE thickness 2.5L head gaskets
    Perrin Big Tube Equal Length header (titanium lava wrap)
    Extreme Turbo Systems Rotated V-Band Exhaust Kit (titanium lava wrap)
    Summit Racing 3" manual stainless steel exhaust cutout
    Borla Hush 3" catback
    Custom 4" aluminum intake
    AEM Dryflow air filter
    ETS 3.5" FMIC core, with custom fabricated 2.5" charge pipe
    PWR aluminum radiator
    Moroso Aluminum Coolant Expansion Tank
    Weapon R Aluminum Coolant Overflow Tank
    Samco Sport radiator hose kit
    Peterson catch can (modified for vacuum from exhaust scavenger)
    Maniac Electric 160amp high output alternator w/+.5V diode mod
    Garrett GTX3576r
    Tial Stainless V-Band Turbine Housing (.82 A/R)
    Forced Performance -4 AN inline turbo oil filter (black)
    Forced Performance turbo shaft speed sensor
    Tial MV-R 44mm EWG (1bar spring)
    custom VTA EWG dump tube
    PTP turbo blanket
    GrimmSpeed 3-Port EBCS (hybrid mode)
    Hallman Evolution RX manual boost controler kit (w/cockpit adjustment)
    AEM 3.5 bar MAP sensor
    AEM IAT sensor (threaded into a nylon fitting 3" from the throttle body)
    Optima Yellow Top battery (relocated to trunk)
    custom engine grounding kit
    "big 3" wiring additions (4 gauge)
    GM Flex Fuel sensor on bypass loop
    fully balanced rotating assembly
    8500rpm redline
    Link G4+ Plug and Play standalone ECU (flex fuel)
    Driveline/Brake mods:
    MSI Solid Aluminuim Engine Mounts
    Beatrush Pitchstop
    Torque Solutions Solid Transmission Mount
    ACT XTSS clutch
    ACT street light flywheel
    SS braided clutch line
    JDM cryo treated & micro polished STi 5MT gearset w/dual cone first gear syncro
    JDM STi 20kg heavy duty center viscous diff.
    Kartboy short shifter
    front/rear/pivot shifter bushings
    TiC 5mt shift linkage update
    Perrin rear diff. lock down system
    04 STi hubs
    Brembo GT series big brake kit for STi
    GrimmSpeed Master Cylinder Brace
    Goodridge SS braided brake lines
    18"x8.5" Rota wheels (pending change)
    235/40R/18 Falken tires (pending change)
    Suspension:
    KYB AGX gas adjustable struts
    Group N hardened tophats
    Eibach prokit springs
    Whiteline 24mm adjustable front swaybar
    Whiteline 24mm adjustable rear swaybar
    04-07 WRX rear swaybar mounts
    Kartboy swaybar endlinks
    Whiteline steering rack bushings
    TiC Lateral Link bushings
    TiC Trailing arm forward bushings
    TiC Trailing arm rear bushings
    TiC FCAR bushing
    Whiteline Plus front control arm forward bushing
    STi forged aluminum front control arms (caster adding type)
    MSI Tubular rear trailing arms with 1" correction
    Turn In Concepts Fender Cowl Braces
    front strut tower brace bar
    Exterior:
    mock carbon fiber side marker inserts
    mock carbon fiber front grill "I" badge
    Hella fog lights
    wingless debadged trunk
    window tint
    Pro-D front lip
    Beatrush undertray
    polished aluminum scoop delete
    Interior:
    reverse indiglo gauge cluster
    blue LED HVAC conversion
    AutoMeter A-Pillar 3 60mm gauge pod
    AutoMeter Black Mounting Cup for 52mm Gauge 2204
    Prosport Blue/White Exhaust Gas Temperature Gauge (pending change)
    Prosport Blue/White Electrical Oil Pressure Gauge (pending change)
    Prosport Blue/White Mechanical Boost Gauge (pending change)
    AEM UEGO Wideband O2 Gauge
    Zeitronix Ethanol Content Analizer
    Alpine iDA-x305 headunit
    Clarion EQ746 1/2 DIN Graphic Equalizer
    Alpine PDX-4.100 amplifier (133watts RMS x 4)
    Dynamat Xtreme (front doors)
    Metra 6.5" speaker spacers (front doors)
    Kenwood tweeters (front doors)
    Infinity Reference 6.5" coax speakers (front doors)
    Sony Xplod 5.25" coax speakers (rear doors)
    Cerwin Vega 5"x7" coax speakers (rear deck)
    Boss Audio BASS600 8-Inch Low-Profile Amplified Subwoofer (under driver's seat)
    14 gauge speaker wire all around
    120gb Toshiba 2.5" .mp3 hard drive
    Momo air leather shift knob
    NRG Gen 2 steering wheel quick release kit
    Momo JET35BK0B Jet Black 350mm Leather Steering Wheel
    Subaru mock carbon fiber trim inserts
    Tactrix 1.3U cable routed behind dash
    Busted Finger Motorsports AEM UEGO Logging Cable
    Passport Escort 8500 x50 hard wired
    ELM 327 Blue Tooth OBDII connector & Torque App for Android
    Grip-It phone mount
    driver's side airbag resistor mod
    hard wired power inverter between driver's seat and center console
    aluminum STi dead pedal
            MainFrame's Avatar
    Austin, TX
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    congrats on being cotm.
    Feb 2011
    Sarasota Fl.
    hey brother i have the same car color an all ill put some pics up, i just have all bolt ons im new to the wrx world and i absolutely love your indiglo gauges and the stereo color as well could you help a fellow brother out and show me were to purchase the same plz
    Thanks cant wait to here back from ya pm me
    Feb 2011
    Elkins Park, PA
    gorgeous car, man. love it
    Josh
    Blue 08 WRX Limited-Cobb AP Stage 2-AEM CAI-Perrin Short throw/bushings-Turbosmart BPV
            MainFrame's Avatar
    Austin, TX
    Sep 2011
    I wish my bugeye was like that... its kind of close... but not to the next level
    Registered User Live2drive15's Avatar
    Sep 2011
    Modesto, CA
    Nice work, looking good! Bet it is a blast to drive.
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Great vid! I mounted up a camera in the car and had some fun with video editing a while back.
    --Ray
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Was it a Go-Pro camera?
    I remember that avatar!
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Oct 2002
    The Old Folks Home
    I fabricated a mount for my rear strut tower bar, and did a whole video to a Joe Satriani tune. Can't remember if I posted it here or not.
    --Ray
    Jan 2011
    TX, NY
    i hope your oil tank comes off easier than mine. that was a PITA.
            MainFrame's Avatar
    Austin, TX
    The next step in project bugeye is nearing completion..
    zax
    zax is offline
    Nov 2008
    You would take a picture of yourself Robin.
    Facebook me here
    Palmyra, NJ
    My...what a big...blower...you have.
